    Large terrain photo help
    25 Posts 9 Posters 3.7k Views 9 Watching
    • AureusA
      Aureus
      You open them as separate programs.
      In SU 7 'Get Current View' is View/Google/Get Current View.
      In SU 8 I think that 'Add Location' has the same function as 'Get Current View' but I'm not totally sure since at the moment I don't have Google Earth to try that.
      • Chris FullmerC
        Its the one that is completely drive from within SU. Press the icon for "add location". That brings up the window with a map. Navigate to where you want. Then set the pins and click grab or whatever it says. Thing is, you can do that over and over and over. So zoom in so that you get high quality images, and then tile them together by importing multiple zoomed in pieces.
        • AureusA
          Aureus
          True. In SU8 this can be done from within SU entirely.
          I'm just accustomed to do it in SU7.
          • Chris FullmerC
            Yeah, I kind of preferred the old way as well. I think the major improvement is just that you no longer need Google Earth installed to make it work.
            • soloS
              Ah, thanks guys I'll give it a go.
              • AureusA
                Aureus
                Something you get, something you loose. Good thing is that 'Add Location' window can be stretched...
                • AureusA
                  Aureus
                  One problem is the road names show up.
                  In my case, they disappear once the view is grabbed.
                  • soloS
                    You are right, I edited my post
                    • soloS
                      Every image gets a watermak so the whole terrain gets coved in Google watermarks.
                        Some advices by DareDevil 😄 in French but...
                        http://sketchucation.com/forums/viewtopic.php?f=51&t=41070&p=363944
                        • AureusA
                          Aureus
                          Not only that but you also end up with a silly outline. If you need to crop it so that you get a normal rectangular outline you can try with exploding images and drawing a rectangle over their flat surfaces. Then you have to delete unwanted area. Or if you deal with 3-d images you need to employ intersecting method with an adequate cube.
                          I'm afraid watermarks are unavoidable in any case. That's Google Earth's policy: on every image you download you get some stuff so that everybody knows it's from Google Earth.
                          Obviously, this can be edited in some editing software outside Sketchup.
                          • daleD
                            dale
                            There is some other satellite imagery out there, and depending on where you are sometimes it's better than Google Earth. Maybe give Flash Earth a try. http://www.flashearth.com/ I don't remember them watermarking either.
                            • Chris FullmerC
                              There are plenty of sites that offer non-watermarked imagery and topo. You just have to learn how to navigate their websites and specify what area you need - not always very easy to do! Its not terribly expensive, but you might need someone with GIS experience to help you put it into a 3d model?
                              • mitcorbM
                                mitcorb
                                I input the location you gave into GE. It was interesting to note that a street address label appears a couple of hundred feet west of the apparent location, right at the edge of a grove. Did you see that, or do I need to adjust something? Also, the resolution of that area seems less than you may desire.
                                What about USGS data?
                                • soloS
                                  I have the terrain, I got the USGA info and used civil3D to generate the terrain as needed but do not have a good aerial photo to overlay, however I found Bing maps a better quality and will stitch a map from them....tsk,tsk Google! Bing has better maps.
                                  • mitcorbM
                                    mitcorb
                                    Yeah, but you can't measure anything- even for approximations- or I haven't found a way.
                                    • wind-borneW
                                      wind-borne
                                      If you want to stitch together some ~4000x3000 images from 2007 pm me with email address and area you want and I'll send via a Transfer Big Files link.
                                      jpeg's about 3-4 MB
                                      png's about 15-20 MB
                                      tiff's wanna be about 38MB but my connection times out before finishing
                                      A couple reduced images
                                      Those property lines are deletable and a dimensioned line can be added to images to resize in SU if needed.
                                      "To read between the lines was easier than to follow the text."OSX 10.11.6
                                      %(#BF80BF)[SU 8 pro
                                      • GaieusG
                                        Not everywhere. In my place, Bing map really sucks while Google is bearably average.
                                        Edit: it does not even suck that much. They must have updated it. 😄
