    Large terrain photo help
    25 Posts 9 Posters 3.4k Views 9 Watching
    • soloS Offline
      You are right, I edited my post
      • soloS Offline
        Every image gets a watermak so the whole terrain gets coved in Google watermarks.
          Some advices by DareDevil 😄 in French but...
          http://sketchucation.com/forums/viewtopic.php?f=51&t=41070&p=363944
          • AureusA Offline
            Aureus
            Not only that but you also end up with a silly outline. If you need to crop it so that you get a normal rectangular outline you can try with exploding images and drawing a rectangle over their flat surfaces. Then you have to delete unwanted area. Or if you deal with 3-d images you need to employ intersecting method with an adequate cube.
            I'm afraid watermarks are unavoidable in any case. That's Google Earth's policy: on every image you download you get some stuff so that everybody knows it's from Google Earth.
            Obviously, this can be edited in some editing software outside Sketchup.
            • daleD Offline
              dale
              There is some other satellite imagery out there, and depending on where you are sometimes it's better than Google Earth. Maybe give Flash Earth a try. http://www.flashearth.com/ I don't remember them watermarking either.
              • Chris FullmerC Offline
                There are plenty of sites that offer non-watermarked imagery and topo. You just have to learn how to navigate their websites and specify what area you need - not always very easy to do! Its not terribly expensive, but you might need someone with GIS experience to help you put it into a 3d model?
                • mitcorbM Offline
                  mitcorb
                  I input the location you gave into GE. It was interesting to note that a street address label appears a couple of hundred feet west of the apparent location, right at the edge of a grove. Did you see that, or do I need to adjust something? Also, the resolution of that area seems less than you may desire.
                  What about USGS data?
                  • soloS Offline
                    I have the terrain, I got the USGA info and used civil3D to generate the terrain as needed but do not have a good aerial photo to overlay, however I found Bing maps a better quality and will stitch a map from them....tsk,tsk Google! Bing has better maps.
                    • mitcorbM Offline
                      mitcorb
                      Yeah, but you can't measure anything- even for approximations- or I haven't found a way.
                      • wind-borneW Offline
                        wind-borne
                        If you want to stitch together some ~4000x3000 images from 2007 pm me with email address and area you want and I'll send via a Transfer Big Files link.
                        jpeg's about 3-4 MB
                        png's about 15-20 MB
                        tiff's wanna be about 38MB but my connection times out before finishing
                        A couple reduced images
                        Those property lines are deletable and a dimensioned line can be added to images to resize in SU if needed.
                        "To read between the lines was easier than to follow the text."OSX 10.11.6
                        %(#BF80BF)[SU 8 pro
                          Not everywhere. In my place, Bing map really sucks while Google is bearably average.
                          Edit: it does not even suck that much. They must have updated it. 😄
                          • 2 / 2
