    [Plugin] WireTool (Catenary) (1.4.1) – updated 06.03.2013
    54 Posts 26 Posters 60.4k Views 26 Watching
      Aerilius
      • gillesG Offline
        gilles
        I notice that you specify a length you always got a approximation, not the desired length.
          Aerilius
          That has two reasons: SketchUp has no curves and like arcs, the length of these catenary curves isn't the sum of the segments.
          The other reason is that the numerical algorithm needs many many more iterations to reduce the bulge if the curve is almost straight (100% should theoretically give a straight line). I'm working on improving this.
          • gillesG Offline
            gilles
            Good work by the way, a useful one.
              Aerilius
              Just to give you an idea: I increased the number of iterations (at every mouse move) from 10 to 150 and the overlength is still half of what it was before (and 150 iterations is far too much). But at least I know which part to optimize.
              • Bob JamesB Offline
                Bob James
                @aerilius said:
                Minor update (1.4.0):- added icons and cursor
                I don't see "draw wires" in my toolbar list
                  Did you first activate its Extension under Preferences ?
                    Aerilius
                    I've uploaded a new version 1.4.1 improving the 100% curve length issue (curve was too long).
                    The previous version didn't mention any toolbar (only icon image), though as it seems nobody else has a problem with one-button toolbars I added one β˜€ . I hope it doesn't increase the toolbar mess.
                    • OxerO Offline
                      Oxer
                      Thanks Aerilius!!
                      I have saw that you have included the line for the Toolbar and spanish language, thanks again.
                      • irwanwrI Offline
                        irwanwr
                        Thank you very much for this plugin.
                          slander
                          Thanks very much for this. It produces a really lovely result for drawing thin arches.
                          I noticed a small problem when I move the endpoints of an existing catenary around - gravity seems to veer away at an peculiar angle. All plan-plane moves seem to work just fine though.
                            Aerilius
                            the resulting curve is just SketchUp geometry, and does not expose physical behavior of a wire. When moving one end point of an arc, it shows normal SketchUp behavior (ie. SketchUp tries to squeeze or stretch the arc to fit to both end points).
                            But a wire that really (physically) moves with attached objects would be a cool feature. The plugin would need observers to watch all the time on all these arcs, and recalculate an arc once an endpoint is changed.
                              Ben Ritter
                              I cannot get the plugin to work with specific inputs. It creates a the same curve no matter what I enter.
                              Can you help?
                                Ben Ritter
                                Never mind, I figured it out. You have to press Enter after entering the distance, etc.
                                • E Offline
                                  escufi
                                  Nice Plugin Aerilius , very usefull. Thanks a lot
                                  • dereiD Offline
                                    derei
                                    Very nice and useful !
                                    One question: shouldn't be better suited under DRAW menu, instead of Extensions?
                                    There is a uncanny tendency to put the plugins under Tools or Extensions menus... leaving all others with too little entries, even if the plugin in cause should better fit in other menu.
                                    Cheers.
                                      Nothing is preventing you from editing the .rb file and changing it to appear in the draw menu.
                                      • dereiD Offline
                                        derei
                                        Unless the author comes with a update at one point and the old (modified) script is replaced... that was my point. I already edited several of the plugins I use.
                                        • E Offline
                                          Einstein
                                          I'm confused.
                                          I can see this plugin had an update recently [Version Updated: 2021-04-12 09:26:24]
                                          but it's been version 1.4.1 since 2013. Why was it updated now while it's still the same version and no changes were introduced?
                                            The current version is v1.4.1
                                            https://sketchucation.com/pluginstore?pln=ae_WireTool
                                            Perhaps the author [ae] finally decided to re-sign it to suit the newer SketchUp versions, but the code was otherwise unchanged ?
                                            • 3 / 3
