    [Layout Tip] - improving workflow
    layout
    25 Posts 13 Posters 4.6k Views 13 Watching
    • FrederikF Offline
      Frederik
      Yep - great organization indeed...! πŸ‘
      I'd be interested in this template...
      Are you interested in sharing it...?
      Cheers
      Kim Frederik
      • porch_unpluggedP Offline
        porch_unplugged
        cheers for the tip utiler πŸ‘
          ArCAD-UK
          Wish I was as organised!
          You do raise some interesting points on the scrapbook dropper issue. Hopefully someone influential is reading this and can appreciate that each drawing element e.g. text, rectangle, line picked from the toolbar should retain its own layer, colour and linetypes and not scramble the selection each time you pick something with the dropper.
          • bmikeB Offline
            bmike
            this is great utiler, similar to where i've been headed, as i find the scrapbook useless.
            i have 1 page setup with my layers, and on each side of the drawing i have common text, dimensions, etc.
            i have not added fills or other specifics, but your page gives me some ideas.
            i too used to have 3-4 common pages in my template, i now only have 1, which i duplicate as i go through.
            • utilerU Offline
              utiler
              Thanks guy, glad you find it interesting.
              @pbacot - elevations from scratch in LO must be laborious!!!! You really need to bring in scenes from SU and automate... my layer setup is pretty simple:
              @frederik - happy to share, mate! The only thing you'll find is that your system will replace text style as I have a custom typeface for my work. I'll just delete my titleblock:
              utileTemplate-A3L.layout
              @porch_unplugged - cheers!!
              @ArCAD-UK - really, there should be two types of eyedropper samplers; one being purely 'select this and match that' and the other being a sampler that is a 'match @ go' type tool.
              Say you want to write text and you have notes already in the screen that contain all the attributes you want. Rather than my workaround of sampling the text, cancel and then select the text tool [making sure you've gone and changes layer manually, aaggghhhhhh!!!] the 'match & go tool would adopt all the layer, text type, colour, etc info from the text you click on and put you in the text routine ready to select you start point.
              Same applies for drawing a line; sample a line of the same attributes, 'match & go' then start drawing!!
              BTW, I have requested this for future releases to the powers that be.
              @bmike - thanks mate. Yes, the idea of scrapbook is neat but really needs an overhaul!
              πŸ‘
              Just Curious...
              • pbacotP Offline
                Thanks for the layer setup.
                I mean that I do the model in SU. But for every project I have to set up the ortho views (use command 3, 4 etc, change to parallel projection, save scenes). Then in Layout import and arrange on a page. Add the titles etc.
                I am thinking what if you have a special elevations SU file that is ready for your model. You bring the model in from the main file, place it in the right place. The scenes are already set up and already linked to arranged windows in a LO file. Perhaps you need to adjust each time for the different sized buildings....
                Your match idea is like a CAD tool I have (you might too). Actually you can choose what attributes to match, linetype layer etc. I usually match all. It can apply these to a group or individual objects (per preset) or apply (the style attributes)to a tool.
                • utilerU Offline
                  utiler
                  I see, my bad...
                  Just Curious...
                  • bmikeB Offline
                    bmike
                    I do this for sales proposals. I take a model and copy and paste it into a SketchUp file named 'sales' with views setup. Then I open a LayOut file that is already keyed to that model. When I'm done I do a save as of each to the company or client folder.
                    I do have to tweak scenes a bit sometimes, or zoom in or out. But it speeds things up a bit. I then export to PDF and combine that with a proposal generated in a word processor.
                    This works pretty well for projects that are all a similar size. (House size for me). I tried it with a few production sets of drawings but it was too much of a hassle to get the section cuts an layering right, as there is usually enough variation from one project to the next.
                    • FrederikF Offline
                      Frederik
                      Thank you SO MUCH for sharing, Utiler...! πŸ‘
                      Cheers
                      Kim Frederik
                        JuanV.Soler
                        That is a great help , thanks utiler
                        • utilerU Offline
                          utiler
                          No worries guys, glad to help.... πŸ‘
                          Just Curious...
                          • RichardR Offline
                            Richard
                            Nice stuff Andrew!!
                            This certainly does highlight some of the issues with scrapbook and layout in general. I'm not sure if you have ever used indesign? But the ability to handle styles is one of it's strengths. I'd be loving that sort of functionality to be introduced to Layout, so anything assigned a "style" can be updated globally! EG all text in a document can be changed to another font!
                            BUILTBRAND.COM.AU
                              tim
                              Just for fun and maybe for the benefit of those of use that live in non-metricland, I reworked utiler's template for 36x24" sheet with 1:12/24/48 scales, imperial dimension stuff etc.
                              With your permission, may upload it here?
                              • utilerU Offline
                                utiler
                                Sure Tim, go for your life!
                                Never use InDesign, Rich although I know you have referred to its strengths in the past; just wish I had time to go surfing and trialing new stuff...
                                πŸ‘
                                Just Curious...
                                • RichardR Offline
                                  Richard
                                  Beers NEXT WEEK mate! Really looking forward to it!
                                  BUILTBRAND.COM.AU
                                  • utilerU Offline
                                    utiler
                                    You bet! I was just thinking about that last night.... πŸŽ‰
                                    Just Curious...
                                    • emerald15E Offline
                                      emerald15
                                      I've not thought of working this way before - definitely going to try it. Many thanks for sharing the template.
                                      • dcauldwellD Offline
                                        dcauldwell
                                        I have been using a similar Layout set-up, including copying sheet one once I've added job title etc to avoid having to keep copying it. However your is so neat, comprehensive and organised, I just had to download it and give it a try.
                                        Thanks for generously sharing. Cheers.
                                        Sketchup 2017
                                        (vray 2.00)
                                        • zx10r_GazZ Offline
                                          zx10r_Gaz
                                          @utiler said:
                                          πŸ‘
                                          Nice work around, I can see the benefits immediately.
                                          Thanks for sharing.
                                          Gaz...
                                          • utilerU Offline
                                            utiler
                                            No problem, guys, happy you find it helpful.... πŸ‘
                                            Just Curious...
