    SketchUp Plugin Toolbars flashing SU Locks
    19 Posts 4 Posters 2.3k Views 4 Watching
    • KrisidiousK Offline
      Krisidious
      I'm having an issue for the last few weeks... When I try to bring in a component, move a large amount of geometry, run a complex plugin action, or open a large model... SketchUp starts thinking and then all of my open toolbars start rotating which one is active. you know, as in the little title bar of each toolbar becomes active and then the next one and then the next one... This continues in a loop. never ending. SU Process must be ended. Turning off all my toolbars fixes the issue. I've tried removing plugins I've added recently, to no avail.
      Any ideas?
      By: Kristoff Rand
        TIG's Half In / Half Out method.
        Isolate half your plugins and see if it occurs. If not restore the isolated half and isolate the good half and test again.
        If the problems happens with that half do the Half In / Half Out on that half and so on
        You could also try Thomthom's Batch Registry cleaner tool but you will need to rebuild your toolbars.
          Sounds like the toolbar registry is mangled.
            Krisidious
            Where do I find this tool?
            By: Kristoff Rand
              Krisidious
              I found it...
              By: Kristoff Rand
                Krisidious
                BOOOOOM! Damn I love you people. Especially you Thom. you better hope I never meet you in person. I'm gonna lay a big one right on your lips.
                By: Kristoff Rand
                  Great stuff, I rather rearrange a few toolbars than resort to the half and half scenario.
                  I met Thom at Basecamp this year...he's a great kisser. Your in for a treat πŸ‘
                    Krisidious
                    lmao...
                    By: Kristoff Rand
                      I can also touch my elbows behind my back. πŸ˜‰
                        Plasma
                          Krisidious
                          you guys kill me... 🀣
                          By: Kristoff Rand
                            Krisidious
                            Not only are my is SU fixed now but it's running like a demon. I think this might be good to do every once in a while. Actions on large models and complex plugin actions are much faster.
                            By: Kristoff Rand
                            • irwanwrI Offline
                              irwanwr
                              Is that a plugin?
                                Krisidious
                                No, it's not a plugin... It's a small batch file that ThomThom wrote. it runs in windows not sketchup.
                                Here it is...
                                404 Not Found
                                (sketchucation.com)
                                By: Kristoff Rand
                                • irwanwrI Offline
                                  irwanwr
                                  Thank you, Kris.
                                  I usually have CCleaner for registry issues checking.
                                  I'll see the batch file.
                                    I dont trust regustry cleaners. They tend to cause more trouble than they solve.
                                      +1[sup:13csfzm2]10[/sup:13csfzm2]
                                        Krisidious
                                        I use CCleaner as well... and I always make a backup before I do it.
                                        By: Kristoff Rand
                                        • irwanwrI Offline
                                          irwanwr
                                          I see.
                                          Thank you for opinions and suggestions.
                                          Actually, I have several Windows tweaker applications here. Three of them left. Those have that registry checking ability. CCleaner, Advanced System Care and TweakMe, which is do nothing but to use standard windows utility that usually hidden from common user.
                                          I always make backups too.
                                          Thanks again πŸ‘
