    Jean Prouvé - Antony chair - 1950
    17 Posts 10 Posters 1.3k Views 10 Watching
      Cool design for this French craftsman in iron and designer! 👍
      • massimoM
        massimo Moderator
        Thanks a lot guys. 😄
          sepo
          Looks great Massimo
          • massimoM
            massimo Moderator
            Thank you Sid. 😄
            • hellnbakH
              hellnbak
              Not the kind of chair I would buy, but very nice work 👍
              • massimoM
                massimo Moderator
                Thanks Steve. 😄
                • cheddaC
                  chedda
                  Looks good Massimo i especially liked the way you got the edge of the wood to map correctly. Any clues in how you did this ?
                  Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                  • massimoM
                    massimo Moderator
                    I've used this one. Even if Fredo said that is not a texturing tool, don't believe him. 😉 On the contrary it's really a great one. For the edge of the wood you have to choose the "quad mesh UV" option. Model and add textures at a bigger size (e.g. x100) and then shrink the model at the end. I've found that the tool works better that way.
                    • alvisA
                      alvis
                      • massimoM
                        massimo Moderator
                        Thank you very much Alvis. 😄
                          Added to Gallery
                          404 Not Found
                          (sketchucation.com)
