    Can't get the color white from both sides
    14 Posts 4 Posters 955 Views 4 Watching
    • jeff hammondJ Offline
      @dave r said:
      Is this a 3D shape you are talking about? Is the "gray" really gray or is it blue?
      [just a note-- it's possible he's using one of the architecture templates which does have white/grey faces by default]
        Thanks for that Jeff. I haven't used any of them for years and had forgotten about the backfaces being gray in those templates. I don't use the blue either.
          ha.. yeah.. i remember a model you posted here a year or two ago and you were running some greenish-browns at that time
            I use a green color that I would never intentionally use in the model. For me the green is easier to pick out against the white background and white or gray faces than the default blue is. I can even pick out a tiny hole that displays only a few pixels across. This makes it easier to see and fix visible back faces.
              i;ve never really had my colors set up to my optimum liking i don't think..
              maybe that can be my assignment while i'm waiting in the dentist office for my daughter today β˜€
                There you go. Better that reading back issues of the Highlights magazine.
                  LOL
                  (and yes.. i know exactly what you're talking about)
                  • KrisidiousK Offline
                    Krisidious
                    I use hot pink for backfaces when I cannot have any outward. you know it a mile away and you must destroy it!
                    By: Kristoff Rand
                      I used to use a strong magenta color but switched to the green because it is easier on the eyes. I often change the back face color to black, dark gray or brown when exporting images without edges so the backface color doesn't show.
                      • smarqueS Offline
                        smarque
                        Many thanks to Dave R, Krisidious and Jeff Hammond for the in-depth answer.
                        It was a shadow thing. I followed your advice and my problem is solved. I had 2 vertical section cuts through the same room in a house model, each facing in the opposite direction and each one captured on it's own scene. All the parameters for each scene were identical. As I would toggle between the 2 scenes I would get "white" walls / "gray" (shadow / shading) walls effect. It was rather daunting.
