    [Plugin] Scale Group Definition
    15 Posts 7 Posters 15.8k Views 7 Watching
      Overview
      Adds a Scale Definition menu item for groups to match the native function for components.
      Access
      Group > Context Menu > Scale Definition
      Requirements
      • TT_Lib2 (v2.7.0)
      Guide: How to install RBZ Files
      http://sketchucation.com/resources/pluginstore?pln=tt_scale_group_definition
      Guide to installing SketchUp Plugins
      Footprint
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_scale_group_definition.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      alexpacio2013A 1 Reply Last reply Reply Quote 0
        ๐Ÿ‘
        • Chris FullmerC Offline
          Cool Thom, thanks!
            dtrarch
            TT
            FYI:
            SU 8 PRO latest
            Only shows for components and no menu on selection ( rt clk)
            Does not show on groups selected (contex rt click)
            Does not show in plugins/tt menu
            (all tt others do)
            TT lib 2.7.1
            file exists in SU plugins
            dtr
              Did you install the RBZ package properly?
              If you only copied the RBZ file to the plugins folder you did it wrong. See link under download button.
                dtrarch
                Hi TT
                Yes installed properly as below
                Installed using SU Windows/preferences/System preferences etc
                As required for .rbz plugins
                dtr
                  dtrarch
                  TT
                  Double check
                  .rbz install confirms install but does not show-up in the extensions list.
                  When the .rbz is re-named .zip and opened only the .rb file is there.
                  No tt_folder exists or icons
                  dtr
                    It is not supposed to appear in the Extension list - didn't implement that feature.
                    It also doesn't have any support folders, it's just the .rb file.
                    There is only one menu item, when you right click a single group.
                      dtrarch
                      TT
                      I created 2 groups
                      1-solids
                      2-non solid
                      Rt click on either shows your menu grey'd out
                      here is the file ๐Ÿ˜ž ๐Ÿ‘Ž
                      dtr
                      test222.skp
                        Yes? Everything is working exactly as expected. None of the groups are scaled, so there is no way it can scale the definition.
                        I suspect you might be expecting a different result from what this plugin actually does.
                        Have you used the native Scale Definition feature that is available to components?
                          dtrarch
                          TT
                          Right on
                          OK now
                          Apologies for all the fuss.
                          Someone scrubbed a previous reply.
                          Thx a bunch
                          dtr
                          • bagateloB Offline
                            bagatelo
                            This plugin can be used for entire scene? This is because your plugin "CleanUp" sometimes delete faces and edges too small...
                              No, it works only on selected group. But can you not use the Tape Measure tool?
                              Sent from my LT25i using Tapatalk 2
                              • alexpacio2013A Online
                                alexpacio2013 @thomthom
                                @thomthom I would like that when selecting a group of objects or components, it defines the scale of all the elements that are inside, whether they are groups or components. Is this possible?
                                panixiaP 1 Reply Last reply Reply Quote 0
                                • panixiaP Offline
                                  panixia @alexpacio2013
                                  @alexpacio2013 it's a 12 years old plugin and Thomas rarely reads here. You most likely can reach him using email to see if he can help with your request.
