    [Plugin] Very fast texture writer
    44 Posts 18 Posters 96.5k Views 18 Watching
    • jason_marantoJ
      jason_maranto
      I'm having a few issues with this plugin when importing image libraries:
      1. The tiling settings for the images are coming in with the x and y scales reversed (the aspect ratio is reversed from the actual image).
      2. I would like to retain any "-" and "_" characters in the image name (when converted to the SKM name).
      Best,
      Jason.
        Around lines #90 and #129 it reads
        mat.texture.size = [twidth,theight]
        to swap the height/width values change it to read
        mat.texture.size = [theight, twidth]
        BUT the width SHOULD come first in the .size=[] method as it is originally coded... so I am perplexed... 😕
        Around line #59 it reads
        filename = filename.delete('^A-Za-z0-9')
        to keep the - and _ in file-names, change it to read...
        filename.gsub!(/[^A-Za-z0-9_-]/, '')
        This WILL work...
        • jason_marantoJ
          jason_maranto
          Thanks TIG, I did my own hacks to the Ruby to make it usable for right now, but your code is much nicer so I will change it out 😄
          For the record the changes I made were at lines 344 and 368 -- but I only barely know my way around a Ruby file 👊
          Best,
          Jason.
          • andybotA
            andybot
            This is a fantastic help. Thank you!
            • unclebimU
              unclebim
              Is there any chance of running the plugin in SU 2014?
                The original fast_tw.rb works in v2014, but is Ruby Console run.
                This attached version is the same as the one in the PluginStore's RBZ.
                fast_tw.rb
                The Depot's fast_tw_3.rb is menu driven and has several extra options.
                It is compatible with v2014.
                This has some issues, which my post a little earlier explained how to fix.
                This attached version has those issues fixed.
                I have incremented it to fast_tw_3a.rb
                fast_tw_3a.rb
                In an earlier post in this thread another version of the RB was attached [confusingly with the same version suffix].
                This is also menu driven and includes several additional options.
                BUT this one is full of coding issues and it is NOT compatible with v2014.
                This attached version has those issues fixed and is now v2014 compatible.
                I have renamed it fast_tw_4.rb for the avoidance of doubt.
                fast_tw_4.rb
                Because of the non-standard RB naming conventions you should ensure any older "fast_tw" RB files are removed...
                I have swapped the texture's height,width in the ..size=[], which [oddly] seems to work - if you have issues with that try editing the v3a/v4 RBs and find every ..size=[] and swap them back to be [width,height] ??
                • unclebimU
                  unclebim
                  Thank you very much, TIG!
                    AcesHigh
                    Can I make an improvement request? It would be nice if you could choose if you want the texture exported with the MATERIAL name (as it happens now) or the original texture name, if available.
                      samyell77
                      Great plugin - thanks! Always amazed by the fantastic plugins that you can find on sketchucation! Thank you...!
                      I like AcesHigh's point about material names - would be a handy feature but even without this plugin will come in very handy.
                      Sam
                      SU Pro 2016
                      Dell Precision M4800
                      PC Windows 10
                      Intel Core i7-4900MQ @ 2.80ghz
                      Nvidia Quadro K2100M
                      16gb RAM
                      • Lemoyne ArchitectL
                        Lemoyne Architect
                        I’m trying to use fast_tw on OSX 10.9.5 and SU 2015 and I’m getting file names such as "fa3c172f4fc034eb6af0489c89b26612.jpg” for everything. From the comment above, am I understanding correctly that it SHOULD save the files with the MATERIAL name you’d see in SU?
                        I’ve tried using both fast_tw_3a.rb and fast_tw_4.rb with the same results.
                          driven
                          did you the one in the PluginStore's that's a RBZ?
                          that error in the name looks like it's a Ruby Depot version...
                            Lemoyne Architect
                            I tried 3a and 4 from TIG’s post:
                            [attachment=2:3ie6v21l]<!-- ia2 -->fast_tw.rb<!-- ia2 -->[/attachment:3ie6v21l]
                            [attachment=1:3ie6v21l]<!-- ia1 -->fast_tw_3a.rb<!-- ia1 -->[/attachment:3ie6v21l]
                            [attachment=0:3ie6v21l]<!-- ia0 -->fast_tw_4.rb<!-- ia0 -->[/attachment:3ie6v21l]
                              Lemoyne Architect
                              Note these lines from above:
                              So the one in the PlugInStore is the first generation - and runs in the Ruby Console. The 3a and 4 versions are updates that run in menus.
                              But I still get the same results in any of them - that I get alphanumeric strings for file names instead of the material names that were in the SKP file.
                                Lemoyne Architect
                                Ok, I finally went in and made a copy of one of the SKM files, renamed it to .ZIP, opened it, and looked at the files. The JPG file in there has the alphanumeric filename I’m encountering. Doing the same with some other materials gets a filename based on the material name.
                                So, in this case, the materials I’m trying to work with just have random alphanumeric filenames for the JPGs they originally created the materials from - so that is all that fast_tw is able to extract. It’s a fault of the materials I’m working with and nothing to do with fast_tw.
                                  driven
                                  @lemoyne architect said:
                                  ..The JPG file in there has the alphanumeric filename I’m encountering. the same with some other materials gets a filename based on the material name...
                                  glad you resolved it, but I'm now curious did the name show as that in the material browser?
                                    Lemoyne Architect
                                    No, that was what was confusing me. I had downloaded a model from the 3DWarehouse, but wanted to modify the materials being used. There were enough that I was looking for an easy way to strip them out rather than right clicking on each and every material and editing them individually - hence doing a search and finding fast_tw.
                                    Playing around with fast_tw and other materials, most of the time someone names the JPG the same name as the material they create. In this case the materials were things like “Material001, Material002, Material003…” while the JPGs were named “4IASae2uulg1, NX054xYNCb63, QtIJ9RU2U1Mj…”
                                    To me, it would seem that would make it very difficult to keep things organized during the creation of the materials, but some people seem to just make things more difficult than they need to be.
                                      driven
                                      ahhh... Material001/2, etc and or <auto_1/2> etc... are name given when SU finds an 'unknown' material in an import or from the eyedropper...
                                      that looks like it uses the materials unique id for the jpg name...
                                      I think fast_tw could be tweaked to re-name the jpg and mat at the same time...
                                      • C
                                        Craig2014
                                        Does this work in SU2016?
                                        I cant see it anywhere after install, although the ruby script "fast_tw +" works in extracting all but 4 out of maybe 15 materials in my sample model.
                                        Is there an icon for this or menu shortcut in SU16 or is it only usable by Ruby?
                                          It's not an extension.
                                          It's some code to run from the Ruby Console.
                                          It's pretty old...
                                          It will work in v2016.
                                          You can add the menu item or toolbar yourself...
                                          There are many simple plugins from which you can crib the method[s]...
                                          Depending what you want to do with your texture images, v2016 also now has this additional thumbnail writing method [max resolution 128px] - this also includes non-textured materials.
                                          model=Sketchup.active_model
                                          folder=UI.select_directory(
                                            title; "Select Folder for Thumbnails",
                                            directory; File.dirname(model.path)
                                          if folder
                                            model.materials.each{|material|
                                              thumbnail = File.join(folder, "#{material.display_name}.png")
                                              material.write_thumbnail(thumbnail, 128)
                                            driven
                                            @TIG, is there really a size limit on a PC...
                                            I write them out at 512px in one of my plugins for mac...
                                            • 2 / 3
