    [Plugin] 3D Text Editor
    204 Posts 51 Posters 237.9k Views 50 Watching
      I got crashes when using a font that existed on the Mac.
        Some problems of visibility on V7 XP πŸ˜„
        (Old Explorer ? )
          Yes. Your Explorer is way too old. I doubt I'll make anything that's compatible with anything older than IE9 from now on. It's just too much work.
            As I have not more modern than IE6 πŸ˜‰
            This if needing will work on another computer πŸ˜„
              How are you even able to navigate websites with such an old browser?
              • jolranJ
                jolran
                +1
                lot of work(forIE7). CSS sheet grows large!
                OT:
                I'm trying to make IE8 compatible dialog, but when reading this I might jump up one step.
                You are still sticking to CSS2? I havent dared touching any CSS3 stuff yet,
                but some are available to IE9 by the looks of it.
                Plugin looks handy BTW πŸ˜„ πŸ‘
                  I don't use it for navigate! πŸ˜‰ It's just a spleeping one πŸ˜„
                    I'm using some CSS3 features. Gradients, rounded corners and other things. But generally the more stable CSS3 features. I have a plugin in the works, which will require IE10 - it allows you to install plugins by dragging files into a webdialog window.
                    IE has lost a lot of users - and Microsofts automatic updates are starting to make it's effect as well as they try hard to push users to keep IE up to date. I would only concern myself about anything older than IE9 if I really had a good reason - like if I made a commercial plugin where a significant amount of users has older systems.
                      Gotcha. Well, I hope you one day can upgrade. Because there really isn't much I can do with IE6. But XP supports older IE versions than IE6, why not just let it update?
                      It's 11 years old - time to let it die. Even Microsofts wants it gone: http://www.ie6countdown.com/
                      • jolranJ
                        jolran
                        Thanks for the info.
                        I will have to rethink about my css support then. I think your philosophy is sound.
                        And yeah! I had IE8 on my computer. And overnight "Badabing!" it became IE9.
                        Just like that πŸ˜„
                        Sorry sorry, back to the plugin discussion.
                          BUT is the 'font-name' you pass from your tool the exact same name as the MAC reports?
                          Or is that font perhaps in a fold-folder that Sketchup doesn't look-in, but your script does ?
                          E.g. some user or xfonts thing ?
                            I am romantic, attached to the old things! πŸ˜„
                            For 99 % my old one is sufficient! β˜€
                            I don't see any major advantage to install new things ... except for launch your very elabrated plugins πŸ˜„
                            For this if needing i can use other modern computers! πŸ˜’
                              Thomas, this is very cool. I'm using it on my MacBook Pro with 10.6.8 with no problems.
                                So my message box warning is just an annoyance then... 😲 πŸ˜•
                                  It doesn't bother me that much. πŸ˜„
                                  It may cause crashes later. I haven't used it that much.
                                    I'll let it be like this for a while and wait for the mayhem.
                                      Be sure, I'll let you know.
                                      • B
                                        Ben Ritter
                                        Thomthom, a very appreciative thank you.
                                          Thomas, I played with it a little more on my Mac and the only thing I can find is the close button doesn't do anything. No biggie for me. I'm flexible and can close it with the X button at the top left.
                                            hm... that's odd. Anything in the Ruby Console?
                                            • 11
                                            • 1 / 11
