    Invisible lights
    renderpluginsextensions
    8 Posts 4 Posters 746 Views 4 Watching
      decumano
      As you can see in the picture,during processing the render is possible to see the spot lights on the top... but during the last process they disappear.
      Which is the problem?
      Thanks for the answer
      • Chris FullmerC Offline
        Will you please always specify what renderer you are using when asking rendering questions? Thanks,
        • BigHandDB Offline
          BigHandD
          I think it's a V-Ray render.
          What type of lights are you using to light the scene?
            decumano
            Sorry, yes is a Vray renderer
            are all little omni lights below a spotlight (even this not rendered)
            thanks
            • mitcorbM Offline
              mitcorb
              Can this be a reversed faces problem also, as in your disappearing furniture question?
              • BigHandDB Offline
                BigHandD
                [attachment=0:28m2bxlc]<!-- ia0 -->3.jpg<!-- ia0 -->[/attachment:28m2bxlc]
                thanks
                Check your faces are not reversed and possibly change from Omni light to an IES light.
                I tend to make one spotlight, add the IES light and make both into one component than move/copy to multiply.
                  decumano
                  Yes! Solved... as in my other question-post it was a component problem. I exploded and made it again a group and now it works.
                  Ok, tomorrow i will try to use ies+spotlight lights and not omni
                  Thanks for the help
                  • BigHandDB Offline
                    BigHandD
                    Thanks for the help
                    Anytime 😄
