    Sun not Rendering in any of my render plugins
    13 Posts 5 Posters 1.3k Views 5 Watching
      Can you draw a rectangle under the block and person and see if it picks up the shadows.
      Look like there's nothing there to cast shadows on.
      • shannakaeS
        shannakae
        No even when i add a ground surface under them I still do not get any shadows or sun.
        • shannakaeS
          shannakae
          Ok i re installed sketchup, (this time I added sketchup pro trial version), then I re installed I render. I did not do anything with Podium, Still no shadows or sun in Irender but the shadows are now showing up in Podium both in Podium and sketchup environments....
          • Chris FullmerC
            There is a toggle in SU to turn on or off shadows. Do you need to have them on in SU to have them show up in the renders?
            • shannakaeS
              shannakae
              I am pretty sure i have them on, under "view" I have shadows checked.... Is there another place i can turn on/off the shadows or sun settings in sketchup. Yes most of the renders do require shadows to be turned on I am pretty sure, and I do have them on (as noted above but maybe I am missing something???)
                Do see shadows in the model space when Shadows is checked in the View menu? If not, perhaps you need to make adjustments to the Light and/or Dark sliders in the Shadows window. Go to Window>Shadows and look at the sliders. Maybe post a screen shot of it.
                • shannakaeS
                  shannakae
                  Yes the shadows are very clear in the model space.... and now they are rendering in Podium as they should but irender is stil rendering everything flat with no sun to speak of. It seems liek i was able to render ok a couple of times on my new windows 8 computer before this all started but maybe not? Maybe it is a windows 8 thing?
                    Could be a display issue with iRender and Win8.
                    • shannakaeS
                      shannakae
                      Some screenshots...
                      here is a new render i did using the default exterior with sun settings, Irender.
                      Here are my shadow settings I tried adjusting them and checking and un checking use sun for shadows settings.. with the same results.
                      Shadows on in my model
                        Can you post your skp file 'save as V6' (for a more large audiance) πŸ˜‰
                        I have any special problem with a very old free version of Podium without any regulate! πŸ˜„
                        Shadow of the cube is even drawn on the "inexistant background" ! πŸ˜„
                        • shannakaeS
                          shannakae
                          Looks like it was probably just an irender issue, the latest version apparently has a bug that is not rendering the sun... so they sent me the link to the previous version for now... http://www.mediafire.com/file/bvnh6y91oqlk2nx/IRender_5_LL15nxt.zip I am seeing sun and shadows again. So that it good! Thanks for all the input... I think this has fixed the issue for now I will up date this post when they have it fixed.
                            Excellent! I'm glad you got it sorted out and thanks for letting the rest of us know.
