    What's your beginners tip?
    305 Posts 169 Posters 453.9k Views 169 Watching
    • unrealVizU
      unrealViz
      There are some repetitive tasks - in modelling, texturing, rendering nearly in every phase. I always try to make notes of them - they are like algorithms. They've got to main tasks - to remind you those repetitive jobs and not have to invent the wheel from scratch and to help you in improving those jobs. From one time to the next of using such an algorithm you will try to make it better, simpler, or more effective. Every time you find a good improvement idea - change the algorithm note. That'll make your progress keep a good direction. It's nice to use some notes tools for it, like evernote or springpad. Which would be my next advice πŸ˜„. To use a useful tools!
      http://www.unrealviz.blogspot.com
        sitbaknchill
        yes I need a follow me short cut thanks. My tip from beginner (me) to beginner:
        Learn the art of mirroring, (using groups and components for such) and intersect with model. Two good videos for these are the speeded up tractor (you tube) and the sketch up help videos 'intersect with model).
          rodman100
          If you are more used to AutoCAd than SU, don't assume that layers are the same in both apps. They behave very diffrenetly in SU. In SU use 'Scenes' and 'Outliner' (under Window-Outliner)to control visibility. Consider putting all CAD info onto one layer (after cleaning up the CAD drawing first) before importing into SU. Try keep SU layers to a minimum at first.
          • porch_unpluggedP
            porch_unplugged
            if I'm importing a cad file into sketchup, I normally import it into a 'new' file (if I've been working on a model), delete all the layers and make a new one such as 'cad plan' or 'cad elevations' or whatever. then copy and paste into the main model file. no messing about with cad layers then.
            I also use prefixes for my sketchup layers, e.g. s-furniture, or s-cars. this is helpful if I import something from the 3D warehouse that has some layers in it. I can then quickly identify which layers are not my own, delete and assign the imported model to the appropriate layer.
              sitbaknchill
              not sure if already mentioned, but grouping objects with same texture/colour helps when you add said textures/colours. and check plugins for ease of use tools (ie workplane tools).
              • ivanI
                ivan
                Go to Window>Preferences>Shortcuts and assign:
                Ctrl+G to Edit/Make Group
                Ctrl+Shift+G to Edit/Item/Explode
                This way you can group and ungroup fast, change component to group...
                • B
                  bakanne
                  Know how to turn them on and off. A straight line can accidentally end up being several end-to-end segments which "endpoints" will show you. Endpoints will show intersections of very slight angles that you wouldn't otherwise notice and help you see polygons that you didn't know where there. It will help you see why some surface shapes defy closing as you draw line after line.
                  • X
                    x2nie
                    Yeah, use google (or ur favorite search-engine) when you tired to repeat your activity with SU!
                    For example, as beginner I dont know how to make a model with paper.
                    I rotate and rotate again each side of my model...
                    Luckily, there are some plugin (fold) that makes my life easier,
                    Even, I feel blessed since there are free-plugin (no cost), as I were a beginner and has no profit from my current work.
                    So? even often a stupid word (such "Sketchup print model to printer") will make us happier
                    πŸ˜„
                    Best regards,
                    ==x2nie
                      Aarhus8000
                      In woodworking/construction: Model as you are going to build. Learn the dimensions of the materials you are going to use during the build and adhere strictly to these in your model. And draw the hidden parts as well: if you for example will be using mortise and tenon in a joint then draw these too. While you draw your model as you're going to build it you will go through all kinds of considerations and you will find the best solutions for them.
                      And it's so much easier to press 'Undo' than trying to glue sawdust back together. πŸ˜‰
                      • Kristian
                      • dukejazzD
                        dukejazz
                        Tip_dj no 14
                        Alternet way to restore toolbars prosition
                        without using veiw-Toolbar - save toolbars prosition (reg ToolbarsUserCustom-Bar)
                        Ok you know that everytime you boot sketchup the tool bars are set the same as you left
                        right
                        now if you move thing around and if your tool bar get mix up by resizing sketchup bordders and you want to restore toolbars prosition to a standard view (veiw-Toolbar -restore toolbars prosition is ok to use)
                        but
                        To return to how it was when you started, just start a new sketchup instance then exit out the old then exit the new.
                        when you come back toolbar are fix to how they were πŸ˜„
                        • dukejazzD
                          dukejazz
                          Tip_dj no 1
                          This is my best tip all year of 2011
                          by dukejazz on Mon Dec 19, 2011 7:52 am
                          When sketchup starts up it doesn't see any hidden ruby files
                          (note: With windows explorer toolbar, Tools-folder options-view-show the hidden files = on)
                          You can hide what you don't need to load, and unhide the require ones that you do.
                          Later with Jim ruby toolbar you can load the hidden ones.
                          That's because your telling the script loader about the name, type and location of ea. plug-ins to load...
                          thus no need to double buffering of plug-ins in folders by loaders.
                          Also the plug-ins are in the folder that are meant to be in.
                          😍 win win!
                          Jim
                          http://forums.sketchucation.com/viewtopic.php?t=1542
                          Ruby Toolbar
                          Download here
                          http://sketchuptips.blogspot.com/2007/08/plugin-ruby-toolbar.html
                          • peter_shawP
                            peter_shaw
                            if this works you are my hero
                            @dukejazz said:
                            Tip_dj no 14
                            right
                            but
                            • RedFoxyR
                              RedFoxy
                              Some of these are really good advices. I keep having trouble with keeping things tidy, but as it was mentioned so many times, nothing makes the work easier than well created groups.
                              All i can add is that practice makes perfect so keep working with sketchup on a daily basis. Since I started my regular -couple of hours a day, everyday- practice with sketchup I have learned a lot for such a short time, the progress is easily noticeable.
                              • F
                                Futurepast
                                And it's good to "test" yourself. When I started 6 months ago I would download a random dwg file and covert it to 3d. I would spend all day trying to get it perfect. This morning I did one in less time than it took to drink my coffee, it's a boost to the ego to measure yourself.I have learned to do a full set of house plans etc. but it's still good to go back to basics once in a while and see how well you can do, as compared to a month or so before.
                                  What is a "random dwg file" ? 😲
                                  A file yet existing of some houses drawing or something else like cloud points...?
                                    mics_54
                                    my new beginners tip....if you want to highlight a portion of your model...apply transparency to the materials of the rest of the model.
                                    • Nvr2L821drN
                                      Nvr2L821dr
                                      Begin the plunge [into Sketchup] by using a venue familiar or interesting. In my case, that was woodworking. Having a more objective sight of [clear-to me] goals, I was quicker and more determined to chew deeper into the subject matter and get results. Put a lot sharper bends into my learning curve.
                                      • sfto1S
                                        sfto1
                                        Never stop searching the forums and other such websites for tips and tricks. I have been using Sketchup for a couple of years now and just discovered some cool tips from a Basecamp tips and tricks video posted to youtube in 2008. β˜€
                                        One from Chris Fulmer regarding the use of scenes as a tool for working with medium to large models. Great tip!
                                        Watching Gaieus model an Ionic column was impressive. Thanks.
                                        and Susan, thanks for pointing out that components are much more useful (to all) when constructed well.
                                        Here is the link
                                        • ariesmarzA
                                          ariesmarz
                                          hi im new here who can give me a tour on how to download vray for sketch up 2013 thanks and much apreciated your help
                                          • GaieusG
                                            Here maybe? http://www.chaosgroup.com/en/2/downloads.html?s=v-ray-sketchup
                                            (need to be registered and logged in)
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 16
                                            • 12 / 16
