    How can I create this?
    17 Posts 9 Posters 3.4k Views 9 Watching
    • olisheaO Offline
      olishea
      if you subdivide the initial 2D face of the hexagon it will result in a more predictable mesh if you bend/shape the design. I would suggest making a honeycomb cube primarily and then stretching out the areas you want. Even making the honeycomb cube is tricky, this is why I say subdivide the initial honeycomb 2D face or it won't stretch very well. You will also see that the edges are not really hexagons....just random shapes that fit, this will give you some freedom.
      oli
        DMZStudio
        Thanks for the answers
        • beginnerB Offline
          beginner
          Hi DMZStudio
          What about this? SKP - attached
          Push/Pull + Scale + Intersect with Selection
          You could use even more denser objects aka Equal-edge Goldberg Polyhedron
          http://sketchup.google.com/3dwarehouse/details?mid=73df5cebd07d1f182137e32e8ebf2b1&ct=mdrm&prevstart=0
          PS. I have used the Goldberg/Clinton πŸ˜‰
          This_GTM.skp
          Regards, SU 'beginner'
          • olisheaO Offline
            olishea
            great work beginner. Took me a minute to realize what you had done πŸ‘ Now time to add thickness, which is trickier than anticipated as faces are normals/reverse driections. πŸ˜† I'm still trying πŸ˜†
            oli
            • beginnerB Offline
              beginner
              Hi Olishea,
              Thank you.
              If some thickness is required I would start with Offset first...
              Offset + Push/Pull + Scale + Intersect with Selection πŸ˜‰
              • olisheaO Offline
                olishea
                Yes I have done it now, been having fun with this technique! πŸ‘
                Try this. Multiple Offset twice. select inner faces, scale smaller. Saves the push/pull πŸ˜‰ You don't need to remove any inner faces like this. Then intersect....I will post an image soon. πŸ‘
                oli
                  • Chris FullmerC Offline
                    You should get that 3d printed Rich πŸ˜„
                    • olisheaO Offline
                      olishea
                      I raise you some balls and cells. Couple more pics to come...
                      http://i654.photobucket.com/albums/uu269/olishea/test1-2_zpsd9cc9220.jpg
                      http://i654.photobucket.com/albums/uu269/olishea/test2-4_zps17b4f4fe.jpg
                      oli
                      • olisheaO Offline
                        olishea
                        and how did you do that?! πŸ˜„
                        oli
                        • beginnerB Offline
                          beginner
                          Groovy stuff... πŸ˜„
