    "Save As Template..." problem
    layout
    5 Posts 3 Posters 750 Views 3 Watching
      mikehathaway
      When I click on File and then on Save As Template... the pop-up window allows me to type a Template Name, but the Template Folder is "grayed out." The Save button is also "grayed out." When I click on the "grayed out" text in the Template Folder box, it turns blue. It reads, "/Users/.../Layout/Templates". However I cannot change the text other than double-clicking and deleting it. It won't let me type in any text. Further when I go back to the finder and navigate to where others have told me the LayOut Templates are located I cannot find the folder. When I go down the hierarchy of "Users/Library/Application Support/Google SketchUp 8.0" I find two folders: SketchUp and Style builder -- but no LayOut. I also did a Spotlight search for LayOut folders but none are found. I'm running LayOut 3.0.16845 on a MacBook Pro with OS X 10.8.2.
      I'm stumped. Will one of you seasoned LayOut experts please steer me in the right direction? I'd appreciate your help!
        It's probably a 'hidden folder', the MACperts here might help you on how to reset it so you can 'see' it.
        Also it probably has limited permissions for you [hence you can't add a Template to it]... you need to reset permissions to FULL read/write for yourself...
        You'll be able to do this once you can see the folder !
        I thought MACs were easy to use πŸ˜’
          mikehathaway
          TIG, I took your advice. Searched for how to show hidden files on a Mac running OS X 10.8. The directions said to use the application Terminal and type in "defaults write com.apple.finder AppleShowAllFiles -bool true"; hit Enter; type in "killall Finder"; and hit enter. That actually worked and I could then see all the hidden files. I again worked my way down the hierarchy of folders "Users/Library/Application Support/Google SketchUp 8.0" and I find two folders: SketchUp and Style builder -- but no LayOut. I also did a Spotlight search for LayOut folders but none are found, even among the ones previously hidden. I couldn't pursue the "permissions" issue since I still can't even see the folder(s). Any other ideas? Any MacPerts who want to rise to the occasion?
          • wind-borneW Offline
            wind-borne
            You are still not on user path.
            With Finder active in menubar, click on Go Menu, hold down βŒ₯(option) key and User library will appear as item
            "To read between the lines was easier than to follow the text."OSX 10.11.6
            %(#BF80BF)[SU 8 pro
              mikehathaway
              TIG -- You, sir, are a genius! It worked just as you said it would. Many, many thanks!
