    Vintage Zenith television
    13 Posts 12 Posters 771 Views 12 Watching
    • unigamiU Offline
      unigami
      SketchUp and Kerkythea. My interest in creating this model was to see if I could accurately portray the picture tube.
        πŸ‘
        crazy.... 😲
        • dereiD Offline
          derei
          The material for the CRT is awesome ! indeed you achieved your goal ! Care to share the technique ? πŸ‘
          • marked001M Offline
            marked001
            ...and you were successful πŸ˜„
            http://www.revision21vis.com
            instagram: revi21on
            • unigamiU Offline
              unigami
              I created a 3D lens shape, because in Kerkythea you need an airtight object to use the dielectric glass. I rounded the edges of the glass lens and make the outside curve a bit different than the curve of the plastic bezel and moved it back a bit - all this to give a bit of a shadow around the edges like you usually see.
              Then, behind the glass lens inside the case I placed a screen to use as a background for the gray. I figured I could play with this material in Kerkythea and adjust it until I was happy with the color.
              Thanks for the nice comments!
              • allanxA Offline
                allanx
                Very cool Rick, the picture tube is awesome...
                allanx
                [Portfolio](https://www.coroflot.com/designers/work-stream?id)
                  Wow! Just wow!
                  • irwanwrI Offline
                    irwanwr
                    πŸ‘ awesome. five stars.
                    • hellnbakH Offline
                      hellnbak
                      Amazing work! πŸ‘
                      All it needs now is a wire clothes hanger for an antenna (maybe with a little aluminum foil) πŸ˜†
                        jpalm32
                        Real nice!!!
                        • Bryan KB Offline
                          Daaannnggg. 😲
                          • RichardR Offline
                            Richard
                            The material for the CRT is awesome ! indeed you achieved your goal ! πŸ‘
                            Absolutely! Nailed it perfectly!
                            [BUILTBRAND.COM.AU](http://builtbrand.com.au/)
                              Must be in the must impressive Gallery β˜€
