    Help: Dynamic
    Scheduled Pinned Locked Moved Dynamic Components
    18 Posts 3 Posters 3.1k Views 3 Watching
      Don-Quixote
      @daredevil said:
      Hard to answer without the model... Post the SU file please.
      http://www.mediafire.com/?rc5uzk9912ed2m1
      Select all and show all to see the inside axis (origin)
      PS: I forgot to write the entere code: ANIMATESLOW(RotX,0,90,180).
      I would like to turn the cube in its 3 combinations of colours
      • DareDevilD
        DareDevil
        Wow !! 27Mb !! large file for a "simple" cube 😮
        Edit : OK, you dont purge the componants and materials lib. Now is only 800kb 😉
        So, DC rotation in 3D space is hard to solve. For the DC, the rotation axes are parent componant axes. so you have to align "Skewb" axes to the "Dinamico" axes. In that case you can turn around the X axe without problem.
        The other problem is the way that DC interpret the rotation value. If you say "turn to 240°" the Rot value is not 240 but -120... And if you say "turn to -120°" it make an error creating a new value called "-120" 😠
        My way to solve it is to use a value, animate this value with only positive numbers and link the Rot to this value :
        [pre:35tf4lrj]RotX -> = Angle
        onClick -> animateslow(Angle,-0,120,240)
        Angle -> 0[/pre:35tf4lrj]
        Hope that helps you...
        Skewb_DD.skp
          Don-Quixote
          First, Thanks for your time.
          I did a little test but 😳 completely fail
          dimensions still big (5Mb) (I discovered how to reduce the dimension 👍 )
          My object don't turn (I'm feeling stupid)
          Ah! how can I upload the US file in forum without my host site?
          Ty again
          http://www.mediafire.com/?1qd0vo5psf4u69s
          (P.s sorry for my english)
          • DareDevilD
            DareDevil
            You forgot to associate Angolo and RotX with
            RotX -> = Angolo
            But in this case, the Test object will be oriented on the X world axe to turn around it.
            You must create a componant "around" the Test. Manualy turn this object with the X axe on the wanted orientation. Then, the Test object will turn around this axe.
            In the componants windows, click on the arrow and select "Purge unused elements". After, do th same in the materials windows.
            Ty again
            Go in the full editor (under the Quick Reply box), then under the text box there is a "Upload attachment" to join files.
            Sorry for my english too 😉
            You know how called a man who know three languages ? A trilingual.
            You know how called a man who know two languages ? A bilingual.
            You know how called a man who know only one language ? A french man!
            ... that's right, I'm french...
              Don-Quixote
              http://oi45.tinypic.com/28jxhg9.jpg
              I create a solid (the arrow), then I changed the axes, and I wrote in the DC:
              RotX - Angolo
              On click - Animateslow(Angolo, 0,90,180,270)
              Angolo - 0
              After this my arrow rotate on the floor
              At this moment is it all correct?
              14Kb XD
                Jim
                  Don-Quixote
                  ooooooooooh, I only wrote RotX Angolo
                  ahahaha
                    Don-Quixote
                    http://oi45.tinypic.com/24x3t00.jpg
                    .... what did I do wrong?
                      Jim
                      I do not think you have done nothing wrong - it appears, unfortunately that this is how Dynamic Components currently behave.
                        Don-Quixote
                        OOOh... so what is my next step to rotate my skuwb (I'm trying to repet step by step what DareDevil did)
                        • DareDevilD
                          DareDevil
                          You don't do wrong, you just miss a step 😉
                          The Components don't turn around own axes but around worldaxes. And the worldis the local world were they are (also called Parent).
                          If you put your arrow like you do, the world is the global Sketchup scene. If you ask to turn around the X ax, the arrow will turn around the red ax of the scene, and as you don't tell anything for Y and Z rotation, SU must choose a value to solve 3D rotation and choose 0. So your arrow align to the red ax (RotY=0 and RotZ=0) and turn around it (RotX=something).
                          To avoid it, you must create la local world around your arrow :
                          1- Draw something around your arrow (here an empty cube centered on the axes)
                          2- Select all (cube and arrow) and create a component (here called LocalWorld). Now you have a Arrowcomponent in a LocalWorldcomponent.
                          3- Change the axes of the LocalWorldto align to the Arrowaxes.
                          4- Now you can turn the LocalWorldas you want (and so the inside Arrowto).
                          5- When you ask Arrowto turn around X ax, it will turn around the LocalWorldX ax and so, the Arrow seem to turn around its own X ax.
                          Hope is better with some picts 😉
                            Don-Quixote
                            Yeeeeeees my arrow can turn now 😍 thaaanks
                            Just last question: is it normal my box inside the arrow don't turn with it?
                            http://oi46.tinypic.com/rtnvop.jpg
                              Don-Quixote
                              This project it's dedicated to DareDevil and Jim; thank you guys for helped me
                              Piramix.skp
                              • DareDevilD
                                DareDevil
                                Nice ! 👍 👍
                                I've got one when I was younger, in the 80's 😄 😄
                                  Don-Quixote
                                  Administrators can close this topic 😉
