    Help: Dynamic
    Scheduled Pinned Locked Moved Dynamic Components
    18 Posts 3 Posters 2.3k Views 3 Watching
      Don-Quixote
      Hi guys, I'm creating a skewb
      http://oi50.tinypic.com/ok2b6c.jpg
      and I already completed it, but now I'm trying to move it with Dynamic Component tool...I show you my problem:
      http://oi48.tinypic.com/25dep.jpg
        Don-Quixote
        [up]
        • DareDevilD Offline
          DareDevil
          Hard to answer without the model... Post the SU file please.
            Don-Quixote
            File sharing and storage made simple
            (www.mediafire.com)
            Select all and show all to see the inside axis (origin)
            PS: I forgot to write the entere code: ANIMATESLOW(RotX,0,90,180).
            I would like to turn the cube in its 3 combinations of colours
              DareDevil
              Wow !! 27Mb !! large file for a "simple" cube 😮
              Edit : OK, you dont purge the componants and materials lib. Now is only 800kb 😉
              So, DC rotation in 3D space is hard to solve. For the DC, the rotation axes are parent componant axes. so you have to align "Skewb" axes to the "Dinamico" axes. In that case you can turn around the X axe without problem.
              The other problem is the way that DC interpret the rotation value. If you say "turn to 240°" the Rot value is not 240 but -120... And if you say "turn to -120°" it make an error creating a new value called "-120" 😠
              My way to solve it is to use a value, animate this value with only positive numbers and link the Rot to this value :
              [pre:35tf4lrj]RotX -> = Angle
              onClick -> animateslow(Angle,-0,120,240)
              Angle -> 0[/pre:35tf4lrj]
              Hope that helps you...
              Skewb_DD.skp
                Don-Quixote
                First, Thanks for your time.
                I did a little test but 😳 completely fail
                dimensions still big (5Mb) (I discovered how to reduce the dimension 👍 )
                My object don't turn (I'm feeling stupid)
                Ah! how can I upload the US file in forum without my host site?
                Ty again
                (www.mediafire.com)
                (P.s sorry for my english)
                  DareDevil
                  You forgot to associate Angolo and RotX with
                  RotX -> = Angolo
                  But in this case, the Test object will be oriented on the X world axe to turn around it.
                  You must create a componant "around" the Test. Manualy turn this object with the X axe on the wanted orientation. Then, the Test object will turn around this axe.
                  In the componants windows, click on the arrow and select "Purge unused elements". After, do th same in the materials windows.
                  Ty again
                  Go in the full editor (under the Quick Reply box), then under the text box there is a "Upload attachment" to join files.
                  Sorry for my english too 😉
                  You know how called a man who know three languages ? A trilingual.
                  You know how called a man who know two languages ? A bilingual.
                  You know how called a man who know only one language ? A french man!
                  ... that's right, I'm french...
                    Don-Quixote
                    http://oi45.tinypic.com/28jxhg9.jpg
                    I create a solid (the arrow), then I changed the axes, and I wrote in the DC:
                    RotX - Angolo
                    On click - Animateslow(Angolo, 0,90,180,270)
                    Angolo - 0
                    After this my arrow rotate on the floor
                    At this moment is it all correct?
                    14Kb XD
                      Jim
                        Don-Quixote
                        ooooooooooh, I only wrote RotX Angolo
                        ahahaha
                          Don-Quixote
                          http://oi45.tinypic.com/24x3t00.jpg
                          .... what did I do wrong?
                            Jim
                            I do not think you have done nothing wrong - it appears, unfortunately that this is how Dynamic Components currently behave.
                              Don-Quixote
                              OOOh... so what is my next step to rotate my skuwb (I'm trying to repet step by step what DareDevil did)
                                DareDevil
                                You don't do wrong, you just miss a step 😉
                                The Components don't turn around own axes but around worldaxes. And the worldis the local world were they are (also called Parent).
                                If you put your arrow like you do, the world is the global Sketchup scene. If you ask to turn around the X ax, the arrow will turn around the red ax of the scene, and as you don't tell anything for Y and Z rotation, SU must choose a value to solve 3D rotation and choose 0. So your arrow align to the red ax (RotY=0 and RotZ=0) and turn around it (RotX=something).
                                To avoid it, you must create la local world around your arrow :
                                1- Draw something around your arrow (here an empty cube centered on the axes)
                                2- Select all (cube and arrow) and create a component (here called LocalWorld). Now you have a Arrowcomponent in a LocalWorldcomponent.
                                3- Change the axes of the LocalWorldto align to the Arrowaxes.
                                4- Now you can turn the LocalWorldas you want (and so the inside Arrowto).
                                5- When you ask Arrowto turn around X ax, it will turn around the LocalWorldX ax and so, the Arrow seem to turn around its own X ax.
                                Hope is better with some picts 😉
                                  Don-Quixote
                                  Yeeeeeees my arrow can turn now 😍 thaaanks
                                  Just last question: is it normal my box inside the arrow don't turn with it?
                                  http://oi46.tinypic.com/rtnvop.jpg
                                    Don-Quixote
                                    This project it's dedicated to DareDevil and Jim; thank you guys for helped me
                                    Piramix.skp
                                      DareDevil
                                      Nice ! 👍 👍
                                      I've got one when I was younger, in the 80's 😄 😄
                                        Don-Quixote
                                        Administrators can close this topic 😉
