    [Plugin] ArcByTools v1.2 20120412
    19 Posts 7 Posters 18.0k Views 7 Watching
      I understand about setting the segment length...
      BUT what variables do you want to 'control'?
      e.g.
      Radius:
      Segment Length:
      Number of Segments:
      [then the Chord Length varies]
      or
      Chord Length:
      Segment Length:
      Number of Segments:
      [then the Radius varies]
      or
      Chord Offset from Center:
      Segment Length:
      Number of Segments:
      [then the Radius and Chord Length varies]
      OR perhaps all possibilities would be good?
      • EarthMoverE
        EarthMover
        Nice work TIG! This is not relevant to this plugin perhaps, but I've always been wondering if there were a way to make an arc tool that would draw arcs segmented by distance increments solely. If it were set to say, 6" a 10 linear foot arc would have 20 segments and a 20 LF arc would have 40 segments and so on. Would be great for rationing the segmentation as relative to the size of the arc. Just wondering.
        Content Creator at Skapeup
        • jeff hammondJ
          yes, i think having an entire 'arc calculator' would be really neat.. it might have to have a 'choose from list' type of interface instead of needing to remember all the variations (eg- tig.arcal) for the console?
          the configuration i'm requesting is radius, height, sector length:
          click pic -> bigger
          it's that last segment (red) which is hard to get into proper position by any method i've tried so far..
          thanks!
          edit-- oh, and I realize sketchup won't see this as an 'arc' because the last segment is at a different angle... 'curve' would be fine
          edit2-- also, the way I have the dc set up is if the last arc segment ends up being very short, it instead makes it longer than the other segments. (say the segment length is set to 20cm.. if the last on ends up being less than 2cm (or whatever) then the last segment would end up ~22cm.
          you probably have a different idea on how that should be. it's just an attempt to avoids having two vertices very close together.
            I'm on to it... I'll get back after the hols...
              Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=365402#p365402
              Draw submenu added.
              Several Extra ArcBy... functions added...
              'Radius+Length'
              'SweptAngle+Length'
              'Radius+ChordLength'
              'Radius+SegmentLength'
              'SweptAngle+SegmentLength'
              'ChordX+ChordY+SegmentLength'
              • EarthMoverE
                EarthMover
                Great!! Went through all of them and they all seemed to be working fine on my end. It would great if the arcs could be placed interactively. If perhaps after entering the parameters the first click of the mouse would set them down and establish centerpoint, then dragging the mouse would rotate the arc around the centerpoint until the second click establishes position. Just a thought.
                • jeff hammondJ
                  Draw submenu added.
                  'Radius+Length'
                  'SweptAngle+Length'
                  Nice!
                  thanks!
                  i'll be trying this out today.
                    Near the perfection from the flaw! πŸ˜„
                      drfarkos
                      Sorry for stupid question, is your plugin meant to appear in Draw menu? I placed it in plugins folder inside Sketchup package, but do not see it.
                        It does appear as a submenu under the Draw menu.
                        It is compatible with PC/MAC Free/Pro and versions 7/8...
                        So this looks like you have mis-installed it...
                        I see you are on a MAC.
                        What 'plugins' folder did you place the .rb file into ?
                        It should have been the
                        Macintosh HD/Application Support/Google SketchUp 8/SketchUp/plugins
                        folder...
                        Also ensure you have FULL read/write permissions for that folder.
                        Perhaps you need to do a little reading on MAC-specific issues with plugin installation ?
                        Why not get Thomthom's 'Simple Plugins Installer' from the SCF Plugins Index linked in the menu above... Once this has been installed it adds a toolset to the Plugins menu that automatically installs tools in their four main forms as either an RB or RBS file & extracted file-sets from RBZ or ZIP archives... It ensure the correct files are put into the correct folders, avoiding any user generated issues...
