    Platanus
    17 Posts 6 Posters 738 Views 6 Watching
    • massimoM Offline
      massimo Moderator
      Sorry not SU related, but I think it can be interesting anyway. πŸ˜„
      I stole my sister's ipad and played with treesketch. This is my first try ...
      The model was converted from .fbx to .obj and directly opened in Thea and
      textured there. Just a slight post pro with Magic bullet photolooks.
      • Rich O BrienR Online
        I've about 200+ tree from that app. Though they look like no trees that grow on this planet. πŸ˜•
        That is a great result. Except for the hardship your sister is now experiencing knowing her brother is a thief. πŸ˜‰
        • massimoM Offline
          massimo Moderator
          Really? Well a bit of practice is needed I believe. It seemed to me a wonderful program with a lot of potential.
          πŸ˜†
          • hellnbakH Offline
            hellnbak
            Looks incredible! Is treesketch only for the ipad? Any equivalent available for pc's?
              jpalm32
              You would think uh?
              Pretty stupid not having some of these apps available to desktop people.
              Just my take!
                Stupid?
                There's tons of free tree generating apps.
                http://arbaro.sourceforge.net/
                404 Not Found
                (www.frecle.net)
                Not as tactile as TreeSketch but as good.
                • massimoM Offline
                  massimo Moderator
                  Sadly yes.
                  Well never really tried arbaro & treed, just ngplant long time ago, but the I have to say that Treesketch's results and features seem really better. Aren't you agree Rich?
                  • hellnbakH Offline
                    hellnbak
                    Those apps look pretty good, but after seeing what Treesketch can do I'll always be wishing I could get results like that πŸ˜’
                      TreeSketch results are phenomenal when you spend time with it.
                      But treeD gives you way more control over the vert count.
                      • massimoM Offline
                        massimo Moderator
                        Just a quick shot (8 passes). Here you can see the "structure" of the tree.
                        • CarlohC Offline
                          Carloh
                          nice model, but the bark needs a better texture. it looks like a digital-camouflage pattern of the us. army πŸ˜‰
                          • massimoM Offline
                            massimo Moderator
                            That's how the real bark is. πŸ˜‰
                            • CarlohC Offline
                              Carloh
                              lawyered! πŸ˜„ it indeed looks like a camouflage pattern...but i have to repeat that in the rendering the texture doesn't look realistic.
                              i don't know if this is platanus x hispanica but the platanus trees here in germany have a much lighter bark. it more looks like this
                              http://www.derkleinegarten.de/500_firma/510_parkplatz/bilder/platanus_acerifolia_platane_borke_rinde_london_plane_tree_moon_tree_sycamore.JPG
                              ...of course it too depends on how old the tree is.
                              • massimoM Offline
                                massimo Moderator
                                Yeah it should be a Platanus x hispanica or acerifolia. πŸ˜„
                                  sepo
                                  How do you actually collect the tree after making it? It mentions something to do with ITunes.
                                  • massimoM Offline
                                    massimo Moderator
                                    Well Sid I know nothing about ipad, itunes etc. Anyway you have to save the tree, give a name to it then go to object manager menu and click on export, then...
                                    Plug your iPad into your computer, open iTunes, select your iPad on the left bar, then click on "apps" along the top. This is the screen where you can choose which apps you want to sync.
                                    If you scroll down on that screen you will see a section titled "File Sharing". Select TreeSketch from the list of apps and all your exported trees will appear.
                                    It is generally best to name your tree's before exporting so that they are easy to find here.
                                    Best of luck
                                    -Steven Longay
                                    Then you have to drag&drop the model from that list into your computer.
                                      sepo
                                      Thanks Massimo.... πŸ‘
