    Joining round to square
    39 Posts 10 Posters 3.5k Views 10 Watching
      Well, we don't have that much and you can still see the grass in some places under the ice we got on Sunday but It's like 2 degrees F with a windchill of -28 or something. Supposed to be -15 or something tonight with even lower windchill.
      • jeff hammondJ
        maybe more difficult to learn at first in curviloft but a faster method once you figure it out is to use the loft option in curviloft..
        you wouldn't need profile splines to do it this way..
        select the square and the circle
        choose loft (first icon in curviloft)
        choose one of the bezier options for 'spline method'
        click on the black preview loft which will open a separate options panel
        adjust tension accordingly (increase segments as well for a smoother transition if needed)
        doing it like that also allows you to rapidly explore different blends via the tension controls as opposed to being stuck with the manually drawn profiles then needing to start over if you don't like it..
        • gillesG
          gilles
          I would have made this.
          • jeff hammondJ
            oh.. right.. that's how it really looks anyway.. especially if it were lathed..
            πŸ‘
            • gillesG
              gilles
              πŸ’š I think they were.
                That is indeed more correct, Gilles.
                Lathed? Turned on a lathe. In woodworking, anyway, "lathe" is a noun. πŸ˜‰
                • jeff hammondJ
                  yeah.. i think lathed would mean 'applied laths' maybe? in which case, the wheelbarrow handles were more likely than not-- not lathed!
                  πŸ˜‰
                  edit- funny thing though.. i typed 'turned' then deleted it because i thought that might be confusing to some..
                  turns out, my replacement is wrong πŸ˜†
                    Maybe with this πŸ˜„
                    http://coloriage.mobi/images/taille_crayon.gif
                    • jeff hammondJ
                      nah.. hnb is looking for round to square.. not round to hexagon
                      • hellnbakH
                        hellnbak
                        I really appreciate all the suggestions. Don't know why I didn't think of Gilles idea, seems obvious now. In the meantime I ended up just doing it quick and dirty. It's just an old wheelbarrow, and will only be used as "set dressing" for a larger model, so it won't need to stand up to close scrutiny.
                        It just bugged me that I couldn't think of how to do something so simple. Gotta tackle that Curviloft plugin someday. Someday.
                        Thanks again
                        • livemixerL
                          livemixer
                          At least according to the several U.S. English dictionaries I checked, it is both a noun & a transitive verb. See for instance http://www.thefreedictionary.com/lathe.
                            Just use adapted one! πŸ’š
                            http://ecx.images-amazon.com/images/I/31Aj0dMMqQL._SL500_AA300_.jpg
                              @livemixer: Sure, it's in the dictionary as such but I don't know of any self-respecting woodworker who would say or write, "I went out to the shop today and lathed a set of table legs." Of course that's kind of odd because you might plane a board or bandsaw those table legs. πŸ˜‰
                              • livemixerL
                                livemixer
                                Funny. I sometimes hear "lathe" used as a verb in shops … but I have never before heard "bandsaw" used that way. Maybe it is a regional thing?
                                Anyway, in the sense of "shape as if by lathing" I think it is a better choice in discussions of SU tools & techniques than say "turning," which could easily be confused with rotating a shape.
                                • jeff hammondJ
                                  nah.. not regional.. i think it's fair to say the vast majority of tradespeople worldwide just make up words as they see fit.. πŸ˜†
                                  • shuraS
                                    shura
                                    just by the way,
                                    we germs have some funny terms in literary language. For example in the army a wheelbarrow is called "einachsiger Dreiseitenkipper" which could translate to "mono axial three side tipper". No idea if this sounds funny in english, but every time i come across a barrow I can't help it. πŸ˜†
                                    sorry for off topic
                                    • hellnbakH
                                      hellnbak
                                      I hurt myself trying to say that. You will be hearing from my attorney.
                                      • livemixerL
                                        livemixer
                                        It is also fair to say that every word was made up by somebody sometime. The ones that become popular enough get put in dictionaries so people like me can post annoying references to them when someone claims they aren't real words. 🀣
                                        • jeff hammondJ
                                          true..
                                          fairly recently, the word 'meh' has made it into the dictionary.. meh..
                                          then there's this one:
                                          google |ˈgo͞ogΙ™l|
                                          verb [ with obj. ] informal
                                          search for information about (someone or something) on the Internet, typically using the search engine Google:I recently googled my 7th grade teacher and found his current e-mail address| [ no obj. ] : she spent the afternoon googling aimlessly.
                                          oh.. and then there's ain't..
                                          you know how many people in the past have told me that's not a word.. πŸ˜‰
                                          • pbacotP
                                            It ain't a word.
                                            • 2 / 2
