    Going around the bend!
    16 Posts 6 Posters 665 Views 6 Watching
      chamferman
      Done
      Cabinet top.skp
      SketchUp 8, V-Ray 1.49.01
        It works fine for me. Get rid of the roundover arc at the notch, preselect the edges you want rounded over, get Follow Me and click on the profile.
        Countertop.skp
          chamferman
          Thanks Dave
          It just worked for me πŸ˜„i am not sure what I was doing wrong, but I am guessing probably not following your instructions precisely
            Well, I'm glad you got it finally.
            Out ouf curiosity, do you want that hard transition from the front edge to the radiused corner? It seems like a smoother transition would be good.
            And considering the orientation of the counter top with the model axes, maybe that is the back edge?
              chamferman
              Your right a smoother transition would be better, can you tell me how please?
              The curve is at the front because the room that the table top was in was turned on it axes, if that make sense. I wanted to have the sun enter my room through a window without changing the time or date
                Ah. I understand.
                So when you drag out the arc, set the second point and drag back along the edge until you get a magenta arc and the Tangent to edge message.
                  chamferman
                  Thanks Dave I will give it a go.
                    @dave r said:
                    Ah. I understand.
                    Also, before that, when you have clicked to set the first end of the arc and move your cursor along the other edge, it will turn into magenta at a point - indicating that you are at the exact same distance from the corner. Click now and do what Dave posted above to get the arc magenta, too.
                      By the way, if the arc is cyan instead of magenta, it is only tangent to one edge instead of both.
                        Funny I have made that yesterday πŸ˜„
                        (sorry in French πŸ˜‰
                        http://sketchucation.com/forums/download/file.php?id=100356
