    Sketchup is Inacurrate???
    513 Posts 38 Posters 105.4k Views 38 Watching
    • mitcorbM Offline
      mitcorb
      I have been following this thread. And I care, if it is do-able.
        You then need to shorten the road on the left AND increase the radius !
        Robust again โ˜€
        So if for any reason I don't want elongate or shorter in straight line pieces of road on the left and the right connection with tangency is impossible ?
        Said a "plumber" who has not straight tubes but any curvated one ๐Ÿ˜„
        • jgbJ Offline
          jgb
          ๐Ÿ™‚
          Despite of all that, what is the best connection between 2 parts of any inclined roads on a flat terrain?
          This is a standard "OGEE" Curve problem of joining 2 non parallel roads. โ˜€
          Did it in High School (that's 53 years ago ๐Ÿ˜‰ ) with pencil, compass, slide rule, protractor and ruler. No such thing as a pocket calculator then, let alone Sketchup.
          But damned if I could remember how I did it!!! ๐Ÿ˜’ ๐Ÿ˜•
          Played in SU for 29 min and got nowhere. ๐Ÿ˜†
          So the attached drawing is a "Sketch" of what the solution would be.
          Not calculated, just by eye.
          The "road" rectangles are drawn overlaid on Pilou's ROAD.JPG.
          This is a sketch of a solution, not an accurate drawing.
          jgb
          • jeff hammondJ Offline
            ๐Ÿ™‚
            (in any progs of course just in theory with same width on the path)
            Compass+ Protractor + Set Square + Ruler
            Arc circle + tangency
            Blend + tangency G1, g2, g3...+ Bulge
            Fillet G1, g2, g3...+ Bulge
            Sweep variation
            Conics
            Offset of one jointure ๐Ÿ˜„
            From a joined yellow line then propagate a perpendicular width segment
            (here connection wanted on the top)
            in sketchup, you can use bezierSpline to get a tangent b-spline for one connection.. as far as accurately offsetting that curve, i don't know how to.. the maths go beyond my knowledge at that point and i'd rather just have software do the proper calculations for me ๐Ÿ˜‰
            (and actually, i don't know the maths to even see if the sketchup drawn b-spline is in fact correct.. and this is an instance where, to me, it's required that i'm using an app that i can fully trust to give the right solutions.. goes back to what i was saying about knowing the numbers.. i don't know the numbers here and neither does the app so i'm screwed..)
            โ€ข draw an extended line to the one you would like to connect tangentially to..
            โ€ข using uniform B-spline set to an order of 4 at least, make 4 clicks, (first tangent point, end of it's extended line, end of the other side's extended line, second tangent point)
            but assuming that curve is in fact correct, i have no idea how to proceed with offsetting properly (as in, arcs are easy to understand.. these types of curves?.. well, let's just say i was never taught about them in school..
            but hey, in sketchup, i could definitely come up with something that looks ok.. ๐Ÿ˜‰
              Seems very cool too! โ˜€
                or, using the ArcBlend command, you'd play with it for 29 seconds and see all possible solutions.. ๐Ÿ˜‰
                  oh. i thought that was a standard approach in france.. don't all the roads look like this over there?
                  ๐Ÿ˜‰
                  • gillesG Offline
                    gilles
                    Sorry Driven but already done ๐Ÿ’š
                    http://sketchucation.com/forums/viewtopic.php?f=15&t=44142&start=480#p453462
                    But
                    pilou wrote:
                    And if for any reason I don't want elongate in straight line the piece of road on the right ?
                      Damned: Imperial measures can be readable as hours minutes second! ๐Ÿ˜ณ
                      (maybe it is ? )
                      The funny thing is that tool who is named in Fance "pistolet" (pistol, gun)
                      is named on the new world a "French Curve" I don't know why! ? ๐Ÿ˜ฎ
                      http://ecx.images-amazon.com/images/I/41QJM-HlJ1L._SL500_SS500_.jpg
                      ๐Ÿ’š
                        driven
                        @gilles said:
                        Sorry Driven but already done :mrgreen:
                        back to the round about then... cheers
                        • gillesG Offline
                          gilles
                          With bezeir classic + component stringer + polyline= tedious.
                          bezier-road_V6.skp
                            driven
                            a more serious reply... for an even curve from both directions.I did trim the fussy edges...
                            edit.. took the skp off as it's a repeat of earlier offer.
                              here's one done in rhino then brought into sketchup and segmented.. it looks as if this version has the 5m crosslines perpendicular to the curves whereas yours look to be leaning..
                              thing is, i can't figure out how someone could calculate where exactly perpendicular to a curve like this is in a polygon app.. have a look at this .skp and see if you can find any sort of method/reasoning to achieve it manually..
                              bez0ffset.skp
                              as far as i can gather at this point, the best we could hope for in sketchup along these lines would be some sort of educated guess ?? (actually, i bet it's possible to do it accurately with a segmented modeler but at that point, the app would have enough info to display the true line so why bother segmenting it)
                                here's another example of sketchup acting in an intelligent manner with regards to its arcs..
                                if you use the arc tangent snap on another arc, it acts appropriately and accurately..
                                then explode the other arc and you'll see it gives a different result (the correct result for that situation)..
                                i was a bit surprised to see sketchup handle this properly (it's different than other 'smart' examples i've given because in this case, sketchup is correctly identifying whether pre-existing geometry is an arc or a series of edges (even though the look identical) then reacting accordingly
                                but it's a good example of how sketchup could also be identifying whether the user has an arc or edges drawn prior to offsetting/followme_ing and reacting correctly..
                                  or maybe showing it this way makes it more clear..
                                  the top row consists of the same radius half-circle with the only difference between the three being the number of segments in the arc (2, 6, & 12 segments)
                                  i then drew tangent arcs using the arc tool's tangent snap.. notice all three radii are the same.. (it wasn't paying attention to the half-circle's segments.. only the fact that it was an arc entity that it was connecting to)
                                  the bottom row is a copy of the top row except the half-circle have been exploded into individual segments..
                                  trying the same thing with the tangent snap now considers only the last segment and goes tangent off it..
                                  • jgbJ Offline
                                    jgb
                                    Using Bezier curves does create an elegant solution, BUT, NOT for real road design. You do not want a changing curve for a real road, as most drivers would not be able to accurately (and safely) negotiate the curve. That is the reason why road curves are mainly true circular arcs; they are a constant turn angle for the driver. Aside from that, road construction is easier and cheaper.
                                    Take a look again at Pilou's picture of the winding mountain road. All the curves are circular arcs. Using Bezier curves would have made a nicer looking road, but far more difficult to drive on (as if THAT road were easy ๐Ÿ˜† ).
                                    jgb
                                      Judicious remark ! โ˜€
                                      • 22
                                      • 23
                                      • 24
                                      • 25
                                      • 26
                                      • 26 / 26
