    I need some Graphics Help / Advice Please
    21 Posts 7 Posters 1.5k Views 7 Watching
    • jeff hammondJ Offline
      When I say "save as V6", now I will say "Save as V5" πŸ˜‰
      πŸ˜† awesome
      • Joe WoodJ Offline
        Joe Wood
        Sorry folks, been away with computer and browser problems .. still using a pretty old win xp machine that's starting to act up on me.
        Thanks for that tip Jeff! So if I want to put 10 images on one 2' x 3' sheet (using Corel), what size should they be, and what image format?
        Joe Wood
        woodsshop.com/
          i can't help you with corel.. sketchup can help you figure out the layout though if you like (or at least that's what i used in this example).. but you'd basically do this same thing in any suitable app.. just a matter of figuring out how to get that app to accomplish it..
          (i'm possibly in the wrong orientation here and you'd like a landscape view.. or maybe you want some extra space somewhere for logo/contacts/notes/etc but the same idea applies)..
          the orange represents a 1" border between the sides,bottom,in_betweens.. (an actual graphic designer may want this weighted differently but just use your best judgement)
          the su drawing is showing that 10- 6"x10Β½" will fit in this layout.. in this scenario, you can drop your ppi some because it's a larger image and viewing distance will tend to be further away.. let's do 150 ppi
          6" x 150 ppi = 900px
          10Β½" x 150ppi = 1575px
          so, if you wanted the layout shown above, i'd recommend each of the 10 images at 900x1575px
          (or-- each of the 10 at 6"x10Β½" and a resolution of 150... different apps have different ways of showing this.. many apps are capable of showing both.. regardless, they mean the same thing)
          note*.. in the above example, the final flattened image ready for print will have a resolution of 3600 x 5400.. (24" & 36" multiplied by 150ppi)
          oh.. and the format.. me personally, id use .TIF
          but jpgs or pngs will be fine too..
          bringing pdf into play such as peter recommended above can be really nice because you'll get the cleanest lines vector as opposed to raster.. that's how the typical powerhouse graphic design apps function (illustrator etal)..and vector lines aren't affected by scaling in the same way raster lines are.. but your images have textures on them therefore you have to (within reason) use a raster format such as tiff,jpg,png
          that aside, layout (the app layout-- which comes with sketchup pro) would really be a great choice here.. with layout, each of those 10 pictures ive shown above would be your actual sketchup models.. you can adjust them individually if need be (as in-- orbit and zoom etc the same way you would in sketchup.. or update the geometry in sketchup and have the update transfer to your layout sheet)..
          you could also utilize it's hybrid mode in which your sketchup textures would be treated as raster BUT the line work is treated as vector (which, amongst other things, you can adjust the line weight etc.. during the layout process. you're not stuck with locked in 2D outputs.. the models are still interactive this far along in the printing procedure)
          [/salesman]
          likewise, you wouldn't have to worry about figure out these resolution dimensions.. you'd pick your 24x36 paper size and quality but layout.app will handle everything else.. just scale and move the models/frames the same as you would in sketchup.. when it's time to print, the app handles all that other stuff under the hood..
          [/salesman pt2]
          • Alan FraserA Offline
            Alan Fraser
            Hi Joe,
            Jpg is a lossy format. That is, if you mess about with it...especially resizing it...it will start to lose definition and get blurry, especially the fine lines and text. It's okay for digital photographs, when you tend not to notice these things, but not good for line drawings.
            Personally, I'd think about using Tif format. Tiffs can be very large compared to jpgs when in full colour, but a simple black and white or greyscale is usually much smaller It is also the standard image format for the publishing industry because it is lossless...lines and text will stay sharp. Png files are lossless too.
            If you're bringing them into Corel, I'd also consider not bothering to resize them beforehand. just bring them in full size (if your PC can stand it). Just import them one on top of the other, then select and resize them all in one go before arranging them on the sheet.
            Whatever size page you are contemplating, if you have to resize them, I'd work on the basis of having images of 300 dpi (dots per inch) for best quality. Therefore, whether you are having them on an 11" page or two across a 2ft sheet, either way they are going to be the best part of a foot wide and therefore would need to be approaching 3600 pixels. Maybe you could consider exporting at 3000-3500 pixels wide and not bothering to resize at all.
            3D Figures
              [alan- yes.. i agree with your methods and definitely overcook these numbers when i'm doing my own stuff.. 600ppi? sure, why not πŸ˜„]
              it's just that joe says things like "still using a pretty old win xp machine that's starting to act up on me." and "trying to keep the file size down.."
              so what i'm going for up there is minimums for an acceptable print..
                Alan Fraser
                Yes Jeff, Joe's machine is getting pretty long in the tooth now. Joe, are you still using a CRT monitor, or have you got a flatscreen yet? πŸ˜‰
                I'm very sceptical (British spelling) that it would take to kindly to being asked to handle 10 pics in a lossless format that were each over 6000 pixels wide, which is why I suggested 300 ppi. If it's good enough for book covers and glossy magazines, it's probably ok for CDs.
                3D Figures
                  @alan fraser said:
                  I'm very sceptical (British spelling) .
                  well, being the sceptic that i am.. i had to check πŸ˜†
                  but it almost looks as if it would be pronounced 'septical' (septic) when written that way.. surely not i hope πŸ˜‰
                    Sceptic vs. skeptic
                    How do you spell Sceptic vs. skeptic? Learn the correct spelling of Sceptic vs. skeptic & other commonly misspelled words & phrases in the English language. Learn more!
                    GRAMMARIST (grammarist.com)
                    • pbacotP Offline
                      What a place, huh? Start out with woodwork design, and end up with etymology. All kinds of help.
                      • Joe WoodJ Offline
                        Joe Wood
                        Darn, so sorry for not replying sooner, really appreciate all the help, I'm just preoccupied with other matters now. I'll be trying this out later and will post back if I run into any problems.
                        thanks Folks!
                        Joe Wood
                        woodsshop.com/
                        • Joe WoodJ Offline
                          Joe Wood
                          Boy, forum is very slow again today, this will take awhile.
                          OK, I’m all ready, got it all figured out about what I’d like to do πŸ™‚ now with a little help from my friends I can create a nice set of plans on two sheets of 2’ x 3’ paper.
                          I have 15 Plans Pages, plus a site plan, and the title block, to put on two sheets. I’ve been experimenting with making these plans using Corel Draw, and Corel Photo Paint. Which one should I use for this?
                          These are the Plans Pages I’ve been experimenting with, exported as jpg images at 4,000 pix wide, and resized in Picasa to 1,000 pix wide at maximum quality. I know not proper image size or type.
                          In Sup I’ve arranged my layout on a 2’ x 3’ paper, I’ve scaled all the images to 10 x 6 ½” and fit them on the paper.
                          I’ve been messing with Corel Paint. First I created a 2’ x 3’ paper size (I choose RGB), but which should I choose? B& White, Greyscale?
                          Then I used the Ruler tool to make 1” borders around the edges. I brought in a few of the resized images. I can position them fairly well, and have been grabbing corners to resize them, not quite sure what I’m doing, it would be nice to bring them in at correct size?
                          So to do this properly, from SUp how do I export and create an image at correct resolution and DPI to end up with a 10” wide image I can bring in to Corel without having to resize it in Corel?
                          How do I put a border around each image?
                          After I’ve arranged them, do I do, Object > Combine > All objects with background? What settings do I use when exporting the 2’ x 3’ image? What type image should I export to send to the local print shop?
                          This is for a local solar patio cover design, hopefully I’ll get to build it too!
                          Joe Wood
                          woodsshop.com/
                            jpalm32
                            Been to your site Joe. Found it in a search for patio roofs awhile back.
                            Real nice stuff. Clean drawings & nice layout.
                            Someone of your talent needs a proper machine.
                            • Joe WoodJ Offline
                              Joe Wood
                              Well JP it does what I ask it to, just like trusty 'ol @Last SUp Ver 5, it does what I need it to do πŸ™‚
                              sorry bout my last post, I came back here after a month and a half and didn't read what had been posted, sorry about that. All the image size Info I need!
                              so I'm experimenting with tifs, exported some at 975 x 1500 for a 6.5 x 10" , made a greyscale 2' x 3' paper size in Corel PPaint, brought in those tifs and we'll see how far I get with this!
                              Joe Wood
                              woodsshop.com/
                              • Joe WoodJ Offline
                                Joe Wood
                                allright, I do think I almost have it!
                                resized those tifs at 150 dpi, brought them into a greyscale 2x3'at 150 dpi paper,
                                and I've got them all arranged it looks like. I can't figure out how to make the image borders, then I'll Combine all objects with background,
                                then Publish > PDF ?
                                Joe Wood
                                woodsshop.com/
                                • Joe WoodJ Offline
                                  Joe Wood
                                  Should I be using Corel Draw or Photo Paint for something like this?
                                  I have it all set up in P Paint but have a nagging thought that I should be using Draw ..
                                  Joe Wood
                                  woodsshop.com/
                                  • Joe WoodJ Offline
                                    Joe Wood
                                    Well I used Corel Draw X3, and figured out how to do borders, Effects > Create Boundary.
                                    then I did > Publish To PDF.
                                    Looked at the pdf full size and it looks pretty good.
                                    before I Published it, should I have done anything to the file, like Combine with Background, or Flatten?
                                    looking back at what I did, should I have done anything differently?
                                    Joe Wood
                                    woodsshop.com/
