    [Tutorial] DR Spawner V-ray 1.49.01
    renderpluginsextensions
    41 Posts 20 Posters 25.7k Views 20 Watching
      j40
      I connected with a LAN cable a notebook (4 cores) to my MacBook Pro (2 cores).
      I don't know if it should be like that, but the second pc kicks in only in the rendering phase, meaning that in the LC calculating phase it's only my main pc working.
      Oh, and I did have some problem with the textured geometry, that came out rendered as solid color. It took me a while to figure out that all it takes is to check the "Asset Collection" box. Maybe you could add that to the tutorial.
      btw is it better to use LAN connection rather wifi?
      Top3D Studio
      • rodrigonotorR Offline
        rodrigonotor
        Added "asset collection" settings to the tutorial.
        That depends on your wireless connection, if you have the same speed as your wired connection is the same thing. If not, the wired connection, most of the times is much faster than the WI-FI connection.
        Regards
        • Sketchando.net • www.arqcad.net •
          LAN is better than WLAN. Even if you have a WLAN with good speed, it's less reliable - random drop in connectivity etc.
            j40
            I thought so... for example the LAN Cable that I'm using is CAT5e 1000 Mbps. I don't think that Wifi can beat that... (?)
            BTW did someone tried to render IES lights with DR Spawner ?
            Top3D Studio
              It's not even about speed - it's about reliability. Just a minor drop in connectivity which you might not notice while browsing can cause havoc for your render.
                akaaka
                I'm trying to run a DR render on two mac. Unfortunately, during the rendering, it is used only computer's master processor. Below is the content of the window (10.0.1.19 is the address of the customer):
                Last login: Thu Nov 15 18:06:30 on ttys000
                MacBook-Pro:~ MD$ /Applications/ASGVIS/DRSpawner/XMLDRSpawner ; exit;
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:47: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                self.message = messages[errorCode] % msgargs
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:47: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:48: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                Exception.init(self, self.message, args)
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Lib/init.py:48: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                e.message),
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:583: DeprecationWarning: BaseException.message has been deprecated as of Python 2.6
                e.message),
                /Library/Frameworks/ASGVIS.framework/Versions/A/Frameworks/Python.framework/Versions/2.6/lib/python2.6/site-packages/Ft/Xml/Catalog.py:584: DeprecationWarning: functions overriding warnings.showwarning() must support the 'line' argument
                FtWarning)
                FtWarning: Catalog resource (file:///usr/local/share/4Suite/default.cat)
                disabled: Error retrieving resource 'file:///usr/local/share/4Suite/default.cat
                (/usr/local/share/4Suite/default.cat)': [Errno 2] No such file or directory:
                '/usr/local/share/4Suite/default.cat'
                Successfully initialized spawner. Waiting for jobs...
                Starting DR session from 10.0.1.19
                Receiving DR scene from 10.0.1.19
                Error receiving DR scene (0), closing DR session
                  rodrigonotor
                  Very good point. 👍
                    carconcal
                    Hellooo … i have a problem making this thing… when i render a light model it takes me the slaves but when i make a big model it says on the slaves…error receiving scene… thank you for your help
                      adityapretzelz
                      I'm having troubles syncing my textures properly. How exactly do we create access to the texture folder in a 'single network', and what about the textures that are in sketchup's temp folder? Ive been able to be partially successful by copying the texture folder on each computer, but It's a hassle to always update them for each render, and the temp folder content is always changing too. Is there also a way to change the default sketchup texture temp folder through some settings?
                        pazzero
                        I handle it with a networkdrive. I enabled the networksharing for my folder with my stored textures on my source computer and connect each other computer and the source computer itself in the exact same way. So each computer is able to access any used texture in the model. For example "R:\Textures\Tile.jpg". But i don't have any idea for the tempfolder. Maybe make sure that you use only Textures from the shared folder?!
                          m_swieboda
                          Hello,
                          I'm trying to set up Distributed Rendering Spawner according to the tutorial but can somebody explain me what exactly must be turned on on 'slaves' and what on 'leading computer'? I've been looking for the answer on the forums but I havent't found it. I've tried different possibilities and during rendering I can see that DR Spawner is turned on but 'the slave' isn't working.
                          Thanks for help
                            rspierenburg
                            You need to run DR Spawner on Slave computers and set your master computer to use Distributed Rendering.
                              cbuchert
                              This is surprisingly still relevant five years later. Works like a boss with Amazon's EC2 servers. Thanks, Rodrigo!
                                Dimethil
                                Can someone indicate me if that's possible tostart a render on slave computers only, in order to keep the main computer available for working on sketchup during render ?
                                  Only with the latest 1.6 beta.
                                    benoitdu77
                                    hello, when i used dr spawner with 2slaves i can see in my rendering scene. i have just 4 region pcmaster.
                                      rodrigonotor
                                      Your welcome cbuchert, but not are five years, only two 😉
                                      Regards
                                        gunfighter77
                                        I been scanning forums relating to this topic. Although old, this thread seems to be the only and most recent discussion regarding the sharing of textures.
                                        When enabling a texture folder to be shared on the network, are you setting that folder location in the sketchup system preferences under files?
                                        It seems to me that sketchup resamples the texture within the file and when you open it, then dumps the resamples into the temp folder. Because when I open a sketchup file in a different machine, it still has retains all the textures?
                                        The problem with using spawner, is that SKU is not open and the spawner isn't linked to the temp folder with the resample textures?
                                        I can get the render farm to work, but it appears that the slave machine isn't rendering any material that isn't default?
                                        I'm probably expecting too much, the added speed is already nice. I just thought if I could resolve the texture issue I can increase the speed.
                                          rspierenburg
                                          I believe (and anyone correct me if I'm wrong) that at the time of rendering it no longer has anything to do with SKMs and their location. You need to ensure that there is a folder that all nodes (main and slaves) have access to. This is where Vray will dump its material information for all the slaves to read.
                                          Rob
                                            Dimethil
                                            I'm working on a PC, with skp8 & vray 1.49.01 installed, but I also have 3 imacs available. I'd like to set distributed renders on the 3 macs, from my PC... (all machines are working on the same gigabit network, whit a storage nas)
                                            SO I installed vray DRspawner on the iMacs, but I'd like to know if that's possible to set a DR between mac & PC ?
                                            All the materials, textures & ies are stored on the same nas, accessible from all machines. SO, I tried...
                                            My main issue is that on my PC, materials path is something like Z:/FOLDERS/Material.jpg
                                            Although the macs are using this kind of path : /Volumes/FOLDERS/Material.jpg So, if I let the Z:/, the macs can't find materials...
                                            That's surprising, but when I set the "mac style path" (starting by /Volumes...) in vray (on the PC), the PC can find the textures, and of course, the imacs can find the texture too. GREAT !
                                            So, no problem for the materials, since I rewrite the paths, by replacing Z:/ by Volumes/
                                            But it's not working for IES... When I set a /volumes/ path to ies lights... The PC can't find them, and I get dark renders 😕
                                            Any idea ?
                                            Is it there an other way to set DR between mac & PC ?
                                            thx
                                            • 2 / 3
