    How to rendering complex objects with Vray?
    renderpluginsextensions
    9 Posts 5 Posters 1.5k Views 5 Watching
    • harlesH Offline
      harles
      Hi...
      i want ask how to rendering complex objects with vray, i got problems when a rendering scene my interior design using vray didn't work and can't processing it and also alert dump error 183. my pc have 16Gb memory RAM and space HD 1 TB. what the best workflows when working with complex objects without trouble with rendering using vray ?
      Best regard,
      Harles
      • V Offline
        valerostudio
        Having 16GB of memory does you no good when rendering inside SketchUp which is limited to 4GB. That means VRay cannot use more than that. There are a lot of factors that could cause this error. Can you send more info about the model? How large is the file? Are you using any materials with displacement? What version of SketchUp and VRay?
        • andybotA Offline
          andybot
          http://sketchucation.com/forums/viewtopic.php?f=322&t=49937
          @harles said:
          Howdy....
          I want to ask about IESLights SUVray. when i use IESLights in SU vray, why IESLights not showing just dark? my SUvray version is [highlight=#ffff80:26jbvgw9]1.49.02[/highlight:26jbvgw9]. in my vray setting camera and enviroment all uncheck. thanks before for all attentions & answer.
          Best regards
          Harles
          Not to be rude or anything, but it sounds like you have an, ehem, "unsupported" version, so it's hard to troubleshoot errors when we don't know about the program you're using.
          • V Offline
            valerostudio
            Ah, the infamous 1.49.02 - Yeah, unfortunately we can't help you then. I would go get yourself a good antivirus program because you definitely have spyware on your machine now.
            • holmes1977H Offline
              holmes1977
              @harles said:
              Thanks guys for all respones and answer, after i check my workflows it turns out, i working with another PC and that's problem is all material can't unload because wrong directory. My size file 40Mb,SU version 8 pro anda Vray 1.49.02.
              Best regards
              Harles
              Although he may not understand English very well, hes polite, I'll give him that
              Exaggeration makes a dull story better.
              • harlesH Offline
                harles
                Thanks guys for all respones and answer, after i check my workflows it turns out, i working with another PC and that's problem is all material can't unload because wrong directory. My size file 40Mb,SU version 8 pro anda Vray 1.49.01.
                Best regards
                Harles
                • harlesH Offline
                  harles
                  I'm apologize incorrectly type wrong version, my correct version vray is 1.49.01.
                  • panixiaP Offline
                    panixia
                    wath's .02 about? is that the long expected new beta? πŸŽ‰
                    were i can download it? in the vray site the lastest version available is still 1.49.01 WTF?
                    http://www.vray.com/vray_for_sketchup/
                    edit: wait.. spyware???
                    • panixiaP Offline
                      panixia
                      ah.. ok.. i quick googled it and found the "official reseller" 🀣
                      edit: removed the pirate torrent link (sure.. i didn't want to promote it, just kidding.. anyway..)
