    On a Mac wondering if anyone has this problem, Image on File
    30 Posts 5 Posters 4.5k Views 5 Watching
      mwm5053
      Same busy signal. if I go to my applications folder and navigate to SU 8 I get preview immediately. It only happens on files. I ran Disk Utility to check permissions ( Someone suggested it to someone else on Mac Forums having the same problem with there MBP) no change.
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        driven
        @mwm5053 said:
        qlmanage -p ~/Downloads/chain.skp 2>&1
        First suggestion didn't change any thing.
        sorry, you DO need to change this ~/Downloads/chain.skp to a file on your computer, that ones on mine... so
        ` qlmanage -p ~/Documents/Sketchup/Car_Body_Example.skp  2>&1`
        unless you've moved it should work...
        I don't have that File or Path so can't check it... but the second should have worked anyway???
        • jeff hammondJ
          ha.. yeah.. always with the repair permissions advice.. and it rarely rarely ever is the issue 😉
          im definitely not recommending reinstalling OSX at this point but i would consider that as something you will need to be doing a little further down the line... (as in.. start prepping yourself now for it 😉
          (but if you're using time machine, you might want to find a point along the way when this behavior wasn't happening then go from there..)
          i'll poke around some more though..
            mwm5053
            [quote]some people recommend clearing those after a reset via qlmanage, so if it's not working from 'Ruby Console', do it from 'Terminal.app'/quote]
            thats some useful info how do you do that
            2011 iMac
            V2 Twilight
              driven
              I really think it's a Quick Look problem, it's common for file associations to get messed up after/during an upgrade to the OS.
              The QL cache can also swell to a massive size (++ GB's) if there's a hiccup in the associations.
              **** should be the -r flag for reset
              from man qlmanage
              DESCRIPTION
              qlmanage allows you to test your Quick Look generators and manage Quick
              Look Server.
               The following usages are available:
               1.     %(#008000)[**qlmanage -r**]resets Quick Look Server and all Quick Look client's
                        generator cache.
               2.       qlmanage -m gets all sort of information on Quick Look server
                        including the list of detected generators.
               3.       qlmanage -t displays the Quick Look generated thumbnails (if
                        available) for the specified files.
               4.       qlmanage -p displays the Quick Look generated previews for the
                        specified files.
               5.       qlmanage -h displays extensive help.
              • jeff hammondJ
                going along with what john is saying (which i too believe to be the logical first steps in troubleshooting this)
                force Quick Look to reload the plug-ins and its cache by running the following commands in the Terminal:
                qlmanage -r
                qlmanage -r cache
                After this is done, clear out the Quick Look configuration files by going to the /username/Library/Preferences folder (in Lion press the Option key and select "Library" from the Finder's Go menu), and then removing the files called "com.apple.quicklook.ui.helper.plist," "com.apple.quicklookconfig.plist," and "com.apple.QuickLookDaemon.plist." With these files removed and the Quick Look service reloaded, try previewing your documents again.
                  mwm5053
                  I tried glmanage-r says file not found
                  2011 iMac
                  V2 Twilight
                    mwm5053
                    glmanage-r cache resuted in glmanage cache reset will look for those files in user/ library
                    2011 iMac
                    V2 Twilight
                      driven
                      qlmanage<space>-r
                      • jeff hammondJ
                        it's a Q.. as in queen
                        or.. Quick Look manage
                          mwm5053
                          😳 ha what a boob
                          2011 iMac
                          V2 Twilight
                            mwm5053
                            That worked better that why I don't code
                            and a big thanks to you too for helping this afternoon
                            2011 iMac
                            V2 Twilight
                            • jeff hammondJ
                              wait..
                              so is it working properly now?
                                driven
                                that's why I use Copy/Paste code blocks
                                But, I should have done -r in the first place....
                                EDIT:had a typo in my code block
                                  mwm5053
                                  Sorry guys still getting this took 45 sec for icon to load that's ok I don't want to take up all your time, I probably owe you at least a 6 pack for sure by now.
                                  2011 iMac
                                  V2 Twilight
                                  • jeff hammondJ
                                    nah man.. it's ok.. i'm youtubing on one computer.. messing around in two other apps.. and reading two forums..
                                    whheeeeeeeee
                                    • jeff hammondJ
                                      at this point then, we would be getting into some areas of riskier things to try which i personally would do on my computers but i'm not going to advise someone else.. i'm not confident enough in my knowledge of the depths of OSX to be talking about it.. (i.e.- i know osx strictly from a user's point of view.. but there comes a point where i have absolutely no idea what these cupertino boys have going)
                                        driven
                                        It's the only place I'm allowed to smoke, and there's snow outside,,,
                                        close all QuickLook windows
                                        In Activity Monitor
                                        type in Qu to get to bring QL to the top
                                        if it's not there, then that's good... it's not being used
                                        if it is, select it
                                        then hit you Sample Process button
                                        try and work out what's keeping it turned on...
                                        simple
                                          driven
                                          the other simpler test is
                                          click on your Macintosh HD folder Icon in the sidebar then
                                          Finder>>View>>Arrange By>>None
                                          it should remove any 'fancy' labelling and can be turned back on if it's not the culprit...
                                            slbaumgartner
                                            You could also try the sketchup quicklook generator I posted in
                                            404 Not Found
                                            (sketchucation.com)
                                            I had issues early on because SketchUp did not register a quicklook generator of its own, which somehow caused quicklook to try to treat a .skp file as text. It took a long time and then displayed useless info.
                                            Steve
