    On a Mac wondering if anyone has this problem, Image on File
    30 Posts 5 Posters 4.8k Views 5 Watching
      mwm5053
      I'm guessing the only thing to do is tun off show preview column
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
      • jeff hammondJ
        hi walt.
        i'm confused.
        can you clarify a few things?
        @mwm5053 said:
        When I open finder and go to My Documents/Sketchup, (where I store my SU files)
        you have a folder on your hard drive which contains your .skp files.. ok.. i think i have this part right.
        finder can't locate the SU icon when I click on a Skp file.
        this is where i'm confused..what do you mean by 'finder can't locate the SU icon'? what are you clicking on?.. are you seeing a ghosted (or blank) icon with the name of the file underneath? is that what you're clicking on?
        I think I noticed this only recently ever since they changed to the new Icon. The reason I'm saying this is it pegs out my 4core processor and only stops when finder has located it. Actually in Activity Monitor it's the Quick Look Helper that is looking for it. Not a big deal but wondered if anyone else noticed it or having a problem.
        i would see it as a big deal (ok.. a small big_deal 😉 ).. this shouldn't be happening but it's hard to see right now where the error is.. i mean, it's definitely something happen on the OS X side of things but if it's only affecting .skp icons then sketchup.app has somehow contributed to the problem..
          mwm5053
          Not good at explaining I know for sure. First attachment is when I click once on a .skp file not open it. 2nd attacment is after 30 sec or more during this time a process called Quick Look Helper is pegging out my cpu and the only reason I brought this up was when I open a.skp then export to KT it crashes SU because the cpu is running wide open looking for the SU icon that's what started the investigation.
          2011 iMac
          V2 Twilight
            mwm5053
            Happens with other apps too but I thought one of the Mac gurus here might be experiencing the same thing.
            2011 iMac
            V2 Twilight
              driven
              I'd try resetting QuickLook first, as it's very easy from Terminal .app
              qlmanage -m
              or from 'Ruby Console' in SU, just add backticks and error return
              ` qlmanage -m 2>&1`
              if you want to test why it's playing up
              ` qlmanage -p  ~/Downloads/chain.skp 2>&1`
              [any .skp will do] should report errors.
                mwm5053
                This ia what I got from ruby
                qlmanage -p ~/Downloads/chain.skp 2>&1 Error: #<SyntaxError: (eval):3068: compile error (eval):3068: parse error, unexpected '~', expecting kDO or '{' or '(' qlmanage -p ~/Downloads/chain.skp 2>&1
                (eval):3068: unknown regexp options - cha
                (eval):3068: parse error, unexpected tINTEGER, expecting $
                (eval):3068
                First suggestion didn't change any thing.
                2011 iMac
                V2 Twilight
                • jeff hammondJ
                  ahh.. ok.. then yeah, i'd definitely say the problem is coming from within OS X itself..
                  fwiw, i just opened one of my largest folders containing a lot of 100MB+ tiffs and with that, i will experience some slowdowns.. but nothing like you're describing here. (as in, less than one second to give the preview)
                  just out of curiosity, what happens if you select (single click) a file then push the spacebar?
                  (this gives the quick look preview in a different way than the column view of finder gives)
                  does it exhibit the same type of searching behavior?
                    mwm5053
                    Same busy signal. if I go to my applications folder and navigate to SU 8 I get preview immediately. It only happens on files. I ran Disk Utility to check permissions ( Someone suggested it to someone else on Mac Forums having the same problem with there MBP) no change.
                    2011 iMac
                    V2 Twilight
                      driven
                      sorry, you DO need to change this ~/Downloads/chain.skp to a file on your computer, that ones on mine... so
                      ` qlmanage -p ~/Documents/Sketchup/Car_Body_Example.skp  2>&1`
                      unless you've moved it should work...
                      I don't have that File or Path so can't check it... but the second should have worked anyway???
                      • jeff hammondJ
                        ha.. yeah.. always with the repair permissions advice.. and it rarely rarely ever is the issue 😉
                        im definitely not recommending reinstalling OSX at this point but i would consider that as something you will need to be doing a little further down the line... (as in.. start prepping yourself now for it 😉
                        (but if you're using time machine, you might want to find a point along the way when this behavior wasn't happening then go from there..)
                        i'll poke around some more though..
                          mwm5053
                          [quote]some people recommend clearing those after a reset via qlmanage, so if it's not working from 'Ruby Console', do it from 'Terminal.app'/quote]
                          thats some useful info how do you do that
                          2011 iMac
                          V2 Twilight
                            driven
                            I really think it's a Quick Look problem, it's common for file associations to get messed up after/during an upgrade to the OS.
                            The QL cache can also swell to a massive size (++ GB's) if there's a hiccup in the associations.
                            **** should be the -r flag for reset
                            from man qlmanage
                            DESCRIPTION
                            qlmanage allows you to test your Quick Look generators and manage Quick
                            Look Server.
                             The following usages are available:
                             1.     %(#008000)[**qlmanage -r**]resets Quick Look Server and all Quick Look client's
                                      generator cache.
                             2.       qlmanage -m gets all sort of information on Quick Look server
                                      including the list of detected generators.
                             3.       qlmanage -t displays the Quick Look generated thumbnails (if
                                      available) for the specified files.
                             4.       qlmanage -p displays the Quick Look generated previews for the
                                      specified files.
                             5.       qlmanage -h displays extensive help.
                            • jeff hammondJ
                              going along with what john is saying (which i too believe to be the logical first steps in troubleshooting this)
                              force Quick Look to reload the plug-ins and its cache by running the following commands in the Terminal:
                              qlmanage -r
                              qlmanage -r cache
                              After this is done, clear out the Quick Look configuration files by going to the /username/Library/Preferences folder (in Lion press the Option key and select "Library" from the Finder's Go menu), and then removing the files called "com.apple.quicklook.ui.helper.plist," "com.apple.quicklookconfig.plist," and "com.apple.QuickLookDaemon.plist." With these files removed and the Quick Look service reloaded, try previewing your documents again.
                                mwm5053
                                I tried glmanage-r says file not found
                                2011 iMac
                                V2 Twilight
                                  mwm5053
                                  glmanage-r cache resuted in glmanage cache reset will look for those files in user/ library
                                  2011 iMac
                                  V2 Twilight
                                    driven
                                    qlmanage<space>-r
                                    • jeff hammondJ
                                      it's a Q.. as in queen
                                      or.. Quick Look manage
                                        mwm5053
                                        😳 ha what a boob
                                        2011 iMac
                                        V2 Twilight
                                          mwm5053
                                          That worked better that why I don't code
                                          and a big thanks to you too for helping this afternoon
                                          2011 iMac
                                          V2 Twilight
                                          • jeff hammondJ
                                            wait..
                                            so is it working properly now?
