    Entity info not showing volume?
    14 Posts 10 Posters 8.0k Views 10 Watching
    • O Offline
      otb designworks
      Tried deleting the preference file with no luck.
      The entity info box shows the first two text fields, and so shows square footages/linear footages, but it won't show the third field with volume
      annoying me right now!
      Cheers, Chuck
      OTB Designworks is on Youtube
        Drag the size-gripper to resize the window.
        • O Offline
          otb designworks
          @thomthom said:
          [attachment=0:3vq0rtpj]<!-- ia0 -->DragHandle.png<!-- ia0 -->[/attachment:3vq0rtpj]
          Yeah, I tried that. It would just expand horizontally and not vertically.
          Ended up trashing everything to do with sketchup 8, re-downloaded the most recent version, transferred my application support files from my mirror drive, and rebuilt my preferences. a nice wasted hour, but at least it is working again.
          Cheers, Chuck
          • bazB Offline
            baz
            Had the same problem but discovered that the 'volume' option is only available on groups or comps in their unedited but selected mode. In other words, if you enter edit mode in a group or comp the volume option is unavailable even if you select everything, which I think is counter intuitive.
            I'm not sure that is what was happening with Chuck though.
              The reason is that the volume field only appears for solids and "solids" are only (otherwise) solid groups or components in SU. That's the "definition" of solids here (not definition by word but by programming).
              • O Offline
                otb designworks
                No, this was a definite window clipping issue.
                I could see that the window had expanded to show the volume field, but I just couldn't see the last bit of the window, no matter what I did.
                This was/is a big, for sure.
                Cheers, Chuck
                  Next time try resetting the workspace.
                  This happened to me recently, too. This fixed the problem. πŸ˜‰
                  • O Offline
                    otb designworks
                    That never crossed my mind; I will definitely try that next time.
                    Thanks Dave
                    Cheers, Chuck
                      caleb
                      I have this same issue- Resetting workspace doesn't fix it... Reinstalling SketchUp ... Getting sick of mac
                      • jeff hammondJ Offline
                        do you mind showing another app on mac that does this?
                          ryaneiferd
                          I had the same issue. Dave, your suggestion worked for me.
                          Thank you!
                            Campbell Architecture
                            Had this problem on 2014 pro also, put up with it for ages. then found 'reset workspace', so simple.. doh.. I worked for me
                              jjccchhhh
                              [attachment=0:3ig1rkuu]<!-- ia0 -->Reset.png<!-- ia0 -->[/attachment:3ig1rkuu]
                              thanks, it worked for me
