    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    Real world model entirely modelled in Sketchup
    20 Posts 12 Posters 6.1k Views 12 Watching
    • pietervP Offline
      pieterv
      Hello Folks,
      I would like to share a video I've made. It is done by using the stop-motion thechnique. All the different parts are modelled in Sketchup first. I have counted them: there are 1845 different parts in total. The model is about 1m25 in heighth and at the floor it is about 1m50 x 1m50. It is build to scale 1/200, so in reality the building would be about 240 meters tall.
      Here is a link to the video on Vimeo (for higher resolution): https://vimeo.com/38913543
      This is my website:
      Citypixels - 3d Visualisatie Architectuur
      • pbacotP Offline
        Astounding work! I would like to see more "behind the scenes".
        (The beginning reminded me of "Metropolis" and early stop motion animation --should've stuck with that dramatic opening music. ๐Ÿ˜„ )
        • cottyC Offline
          cotty
          WOW! Impressive video. How long did you work on this? Did you lasercut the parts?
          my SketchUp gallery
          • orgelfO Offline
            orgelf
            excellent work ! โ˜€
            nice use of the snowflake ๐Ÿ˜„
            http://www.orgelf.com
            • pietervP Offline
              pieterv
              Thanks! ๐Ÿ˜„
              @ Pbacot: I'll add some more 'behind the scenes' materials. I think you have a good point: I could have stuck with the dramatic (North-Korean) opening music, but it was not so easy to find a piece of classical music that would fit because of the high tempo of the footage. My knowledge on different genres of music is not so great, so if anyone has a suggestion, it's always welcome!
              @ Cotty: I worked on the project (from the first sketches to the final result) for about a year (mostly in the weekends). Yes, it is lasercut.
              @ Orgelf: Thanks!
              Here is a video where you see how I cut angled corners onto the different pieces. (Do not try this at home actualy. ๐Ÿ˜„ I am not following the safety instructions closely). You can find more pictures on my blog ( http://pietervermeersch.blogspot.be ) but I'll also add some pictures here:
              http://3.bp.blogspot.com/-mk8IVAzM9SM/UETyv1d1r8I/AAAAAAAAA9k/8aeQ9fkt5QA/s1600/DSC_3496-doorsturen.jpg
              http://2.bp.blogspot.com/-Q9iDoWaPdm4/UDs5kyaxkKI/AAAAAAAAA8s/w9SWhahiGCw/s1600/maquette-021.jpg
              http://2.bp.blogspot.com/-DUZf64nN6TI/UETzOj9VddI/AAAAAAAAA-g/XKSOj7COMZU/s1600/DSC_3367-doorsturen.jpg
              About 1845 parts in total.
              http://1.bp.blogspot.com/-Wltt-daRYzs/Tlk6XeGwpUI/AAAAAAAAAqE/e2mDU5QSRw0/s1600/DSC_0117.jpg
              Sketchup construction drawings:
              http://3.bp.blogspot.com/-0i53CLLTSV8/Tt5IGUKFSlI/AAAAAAAAAtI/zsDeoddt6uU/s1600/maquette-kristal-technisch-15.jpg
              http://1.bp.blogspot.com/-FCB2B6J106U/T61C_NM9ERI/AAAAAAAAA28/gAiNKHY41WM/s1600/maquette-kristal-technisch-17.jpg
              First sketches
              http://4.bp.blogspot.com/-g1_jtyW1iw8/T60-OfofavI/AAAAAAAAA1Q/xsGhMOd5sBo/s1600/dagboek-schets-06.jpg
              This is my website:
                d12dozr
                Crazy cool! I think it deserves a place in the Sketchup Showcase: http://showcase.sketchup.com/ Have you thought about submitting it there?
                http://goo.gl/f7ooYh
                • pbacotP Offline
                  ...yes and "most impressive sketchup modelling" thread!
                  • pietervP Offline
                    pieterv
                    @d12dozr: Thanks for the tip! Maybe I'll just do that!
                    This is my website:
                      Constructivism revival! โ˜€
                      • pietervP Offline
                        pieterv
                        Here is another project where I have used Sketchup to make the illustration and the construction. You can find more photos here: http://pietervermeersch.blogspot.be/2010/09/nieuwe-fotos-project-m2.html
                        This is my website:
                        • N Offline
                          notareal
                          Quite job... I was thinking that this must be done with laser cutting ๐Ÿ˜‰
                          Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
                          • pietervP Offline
                            pieterv
                            Hey Notareal,
                            All the peices are done with lasercutting, but I have done the angled corners with the saw. ๐Ÿ˜„
                            This is my website:
                            • ToboboT Offline
                              Tobobo
                              That is very nice work.
                              Did you use layout to arrange the pieces for the laser cutter?
                              Toby
                              Philippians 4:13
                              • pietervP Offline
                                pieterv
                                Hey Tobobo,
                                Thanks, I have used illustrator to arrange the pieces.
                                This is my website:
                                • ToboboT Offline
                                  Tobobo
                                  @pieterv said:
                                  Hey Tobobo,
                                  When I did my MA, I used Illustrator to do the same thing but then had to eps it. As the driver only worked through Corel Draw.
                                  Toby
                                  Philippians 4:13
                                  • KrisidiousK Offline
                                    Krisidious
                                    That is AWESOME Pieterv...
                                    By: Kristoff Rand
                                    • boofredlayB Offline
                                      boofredlay
                                      ๐Ÿ˜ฒ
                                      Great work.
                                        cadmunkey
                                        Insanely brilliant!! Wow. ๐Ÿ‘ ๐Ÿ˜ฎ
                                          tomasz
                                          Great patience and excellent result! I admire your passion for the design & construction.
                                          Author of [Thea Render for SketchUp](http://www.thearender.com/sketchup)
                                          • pietervP Offline
                                            pieterv
                                            @ Boofredlay:
                                            @ cadmunkey:
                                            @ Tomasz:
                                            Thanks a lot! ๐Ÿ˜„
                                            This is my website:
