    Real world model entirely modelled in Sketchup
    20 Posts 12 Posters 9.8k Views 12 Watching
    • pietervP Offline
      pieterv
      Thanks! ๐Ÿ˜„
      @ Pbacot: I'll add some more 'behind the scenes' materials. I think you have a good point: I could have stuck with the dramatic (North-Korean) opening music, but it was not so easy to find a piece of classical music that would fit because of the high tempo of the footage. My knowledge on different genres of music is not so great, so if anyone has a suggestion, it's always welcome!
      @ Cotty: I worked on the project (from the first sketches to the final result) for about a year (mostly in the weekends). Yes, it is lasercut.
      @ Orgelf: Thanks!
      Here is a video where you see how I cut angled corners onto the different pieces. (Do not try this at home actualy. ๐Ÿ˜„ I am not following the safety instructions closely). You can find more pictures on my blog ( http://pietervermeersch.blogspot.be ) but I'll also add some pictures here:
      http://3.bp.blogspot.com/-mk8IVAzM9SM/UETyv1d1r8I/AAAAAAAAA9k/8aeQ9fkt5QA/s1600/DSC_3496-doorsturen.jpg
      http://2.bp.blogspot.com/-Q9iDoWaPdm4/UDs5kyaxkKI/AAAAAAAAA8s/w9SWhahiGCw/s1600/maquette-021.jpg
      http://2.bp.blogspot.com/-DUZf64nN6TI/UETzOj9VddI/AAAAAAAAA-g/XKSOj7COMZU/s1600/DSC_3367-doorsturen.jpg
      About 1845 parts in total.
      http://1.bp.blogspot.com/-Wltt-daRYzs/Tlk6XeGwpUI/AAAAAAAAAqE/e2mDU5QSRw0/s1600/DSC_0117.jpg
      Sketchup construction drawings:
      http://3.bp.blogspot.com/-0i53CLLTSV8/Tt5IGUKFSlI/AAAAAAAAAtI/zsDeoddt6uU/s1600/maquette-kristal-technisch-15.jpg
      http://1.bp.blogspot.com/-FCB2B6J106U/T61C_NM9ERI/AAAAAAAAA28/gAiNKHY41WM/s1600/maquette-kristal-technisch-17.jpg
      First sketches
      http://4.bp.blogspot.com/-g1_jtyW1iw8/T60-OfofavI/AAAAAAAAA1Q/xsGhMOd5sBo/s1600/dagboek-schets-06.jpg
      This is my website:
      Citypixels - 3d Visualisatie Architectuur
        d12dozr
        Crazy cool! I think it deserves a place in the Sketchup Showcase: http://showcase.sketchup.com/ Have you thought about submitting it there?
        http://goo.gl/f7ooYh
        • pbacotP Offline
          ...yes and "most impressive sketchup modelling" thread!
          • pietervP Offline
            pieterv
            @d12dozr: Thanks for the tip! Maybe I'll just do that!
            This is my website:
              Constructivism revival! โ˜€
              • pietervP Offline
                pieterv
                Here is another project where I have used Sketchup to make the illustration and the construction. You can find more photos here: http://pietervermeersch.blogspot.be/2010/09/nieuwe-fotos-project-m2.html
                This is my website:
                • N Offline
                  notareal
                  Quite job... I was thinking that this must be done with laser cutting ๐Ÿ˜‰
                  • pietervP Offline
                    pieterv
                    Hey Notareal,
                    All the peices are done with lasercutting, but I have done the angled corners with the saw. ๐Ÿ˜„
                    This is my website:
                    • ToboboT Offline
                      Tobobo
                      That is very nice work.
                      Did you use layout to arrange the pieces for the laser cutter?
                      Toby
                      Philippians 4:13
                      • pietervP Offline
                        pieterv
                        Hey Tobobo,
                        Thanks, I have used illustrator to arrange the pieces.
                        This is my website:
                        • ToboboT Offline
                          Tobobo
                          @pieterv said:
                          Hey Tobobo,
                          When I did my MA, I used Illustrator to do the same thing but then had to eps it. As the driver only worked through Corel Draw.
                          Toby
                          Philippians 4:13
                          • KrisidiousK Offline
                            Krisidious
                            That is AWESOME Pieterv...
                            By: Kristoff Rand
                            • boofredlayB Offline
                              boofredlay
                              ๐Ÿ˜ฒ
                              Great work.
                                cadmunkey
                                Insanely brilliant!! Wow. ๐Ÿ‘ ๐Ÿ˜ฎ
                                  tomasz
                                  Great patience and excellent result! I admire your passion for the design & construction.
                                  • pietervP Offline
                                    pieterv
                                    @ Boofredlay:
                                    @ cadmunkey:
                                    @ Tomasz:
                                    Thanks a lot! ๐Ÿ˜„
                                    This is my website:
