    Empty groups get deleted?!
    19 Posts 7 Posters 1.2k Views 7 Watching
    • N Offline
      niccah
      Hi!
      I have a strange problem...
      Following situation:
      • I open a new Sketchup file
      • insert an empty group
      • this group gets a name and a description
      At first, everything is fine... but...
      when I will draw something, this empty group will get deleted... but why?
      I need this empty group, because it gets filled step by step...
      Do you know this situation? Or do you know, how I can solve it?
      Thanks a lot for your help!
        Aerilius
        Do you have a reference to the group?
        I assume SketchUp cleans up empty groups as they would otherwise clutter with zero-size elements that the user won't ever be able to select or re-use manually.
        Similar to that, Ruby cleans up unused references when it is sure that the reference won't ever be used again (garbage collection). If you need a reference later again (to draw entities into the group), the reference must live in the same scope as the drawing method.
        You could for example use a module variable instead of a local variable.
        • N Offline
          niccah
          Thanks a lot for your fast reply!
          I agree with you - MANUALLY, I'm not able to use this group again. But with Ruby, I can find this group again by its name...
          Hm, can I insert something invisible?! In the worst case, I have to insert a line, hide it, and when the user starts so insert something in this group, I delete this invisible line at first...
          What do you think?
          • N Offline
            niccah
            okay, I insert now a small edge and hide the full group... when the user insert his first objects, I delete this line and make the group again visible...
            Thanks Aerilius for the hint with the garbage collector!
            • jolranJ Offline
              jolran
              Use a constructionpoint instead. May be lesser code.
                Aerilius
                Do you have a code sample that shows this?
                I highly doubt we have to insert a DrawingElement (if such a hack is necessary, then that behavior is a bug in SketchUp). I wonder why the group is garbage-collected, maybe we have to check again what kind of variable is used.
                • jolranJ Offline
                  jolran
                  Maybe the code is between a start and commit operation? Doesent Sketchup garbage collect then?
                  I don't think this is unusual, seen several hacks around conserning this. But they where rather old and I can't remember where I saw it. Maybe there's a better fix as Aerilius says...
                    SketchUp will remove empty definitions from the model. Even definitions of ComponentInstances. Think it usually happens on commit - but there might be other triggers as well. Always seen this as part of the automatic cleanup.
                    • Dan RathbunD Offline
                      Dan Rathbun
                      definitions ??
                      I thought it was empty instances that were GC'd ?
                      I'm not here much anymore.
                        It's a know way of removing an unused definition from the Component Browser without recourse to definitions.purge_unused, which of course might also remove components that the users has not yet got inserted, but would like to keep for later...
                        definition.entities.clear!
                        within a start/commit block will remove the definition.
                        Similarly group.entities.clear!, although in that case group.erase! will work BUT can can fall foul of some new BIMish ill-advised entities-observers... πŸ˜’
                          @dan rathbun said:
                          definitions ??
                          Instances are just references to definitions. And it's not garbage collection - if it had been then they would not have disappeared when you have reference to them. It's SketchUp cleaning up.
                            @dan rathbun said:
                            definitions ??
                            You're not talking about Ruby instances, right?
                              Dan Rathbun
                              No. Back on the topic of the OP,... he was asking about group instances that get GC'd before he can use them, because they are empty.
                                Andreas as the first one to mention the GC. The OP only said the group was deleted - which is what happens to definitions when they are empty.
                                Why not create the group only right before you need to add something to it?
                                • N Offline
                                  niccah
                                  At first! Thank you very much again for all your comments! I'm always learning a lot, "listening" to your discussions!
                                  Following idea:
                                  • the user can create a "project" => so, in my code, I create at first an empty group
                                  • all the projects will be listed in a table
                                  • now, the user can add to a single project some "parts"
                                  So, my current problem:
                                  • user create a project, and then he / her starts to draw the "part" => during drawing, the empty project group will be removed by GC...
                                  My hidden line in the groups works perfect! I know, it not realy smart, but...
                                    That's where I ask: why do you need to create the group in advance before you actually make use of it? Seems to me it complicates things a little when you try to fight SketchUp for the group - slapping its wrist using hidden temp geometry.
                                    • N Offline
                                      niccah
                                      πŸ˜„ Okay, let me "answer" with a new question - what can I do else? πŸ˜„ The user would like to create a project => so, somewhere I have to save this information about the projects (name, options, etc, ..). And the user could create a project and close Sketchup => so, the information about the new project has to be saved somewhere "for ever".
                                      I realy agree, my way is realy complicated...
                                        Dan Rathbun
                                        OK major problem with your logic.
                                        In Ruby you can cause the current editing context (the "project" group,) to be exited, via:
                                        model#close_active()
                                        BUT there is no API method to enter INTO an editing context. (You cannot cause the "project" group to become active for edit.)
                                        • Chris FullmerC Offline
                                          Use an attribute dictionary to attach information to the model. It will stay with it after the model is closed and opened.
                                          Single Dictionatires
                                          http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionary
                                          Collections of multiple dictionaries
                                          http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionaries
                                          This is a much more stable way to maintain data in the model from session to session.
