    Empty groups get deleted?!
    19 Posts 7 Posters 1.1k Views 7 Watching
      SketchUp will remove empty definitions from the model. Even definitions of ComponentInstances. Think it usually happens on commit - but there might be other triggers as well. Always seen this as part of the automatic cleanup.
      • Dan RathbunD Offline
        Dan Rathbun
        definitions ??
        I thought it was empty instances that were GC'd ?
        I'm not here much anymore.
          It's a know way of removing an unused definition from the Component Browser without recourse to definitions.purge_unused, which of course might also remove components that the users has not yet got inserted, but would like to keep for later...
          definition.entities.clear!
          within a start/commit block will remove the definition.
          Similarly group.entities.clear!, although in that case group.erase! will work BUT can can fall foul of some new BIMish ill-advised entities-observers... πŸ˜’
            @dan rathbun said:
            definitions ??
            Instances are just references to definitions. And it's not garbage collection - if it had been then they would not have disappeared when you have reference to them. It's SketchUp cleaning up.
              @dan rathbun said:
              definitions ??
              You're not talking about Ruby instances, right?
                Dan Rathbun
                No. Back on the topic of the OP,... he was asking about group instances that get GC'd before he can use them, because they are empty.
                  Andreas as the first one to mention the GC. The OP only said the group was deleted - which is what happens to definitions when they are empty.
                  @niccah said:
                  okay, I insert now a small edge and hide the full group... when the user insert his first objects, I delete this line and make the group again visible...
                  Why not create the group only right before you need to add something to it?
                  • N Offline
                    niccah
                    At first! Thank you very much again for all your comments! I'm always learning a lot, "listening" to your discussions!
                    Following idea:
                    • the user can create a "project" => so, in my code, I create at first an empty group
                    • all the projects will be listed in a table
                    • now, the user can add to a single project some "parts"
                    So, my current problem:
                    • user create a project, and then he / her starts to draw the "part" => during drawing, the empty project group will be removed by GC...
                    My hidden line in the groups works perfect! I know, it not realy smart, but...
                      That's where I ask: why do you need to create the group in advance before you actually make use of it? Seems to me it complicates things a little when you try to fight SketchUp for the group - slapping its wrist using hidden temp geometry.
                      • N Offline
                        niccah
                        πŸ˜„ Okay, let me "answer" with a new question - what can I do else? πŸ˜„ The user would like to create a project => so, somewhere I have to save this information about the projects (name, options, etc, ..). And the user could create a project and close Sketchup => so, the information about the new project has to be saved somewhere "for ever".
                        I realy agree, my way is realy complicated...
                          Dan Rathbun
                          OK major problem with your logic.
                          In Ruby you can cause the current editing context (the "project" group,) to be exited, via:
                          model#close_active()
                          BUT there is no API method to enter INTO an editing context. (You cannot cause the "project" group to become active for edit.)
                          • Chris FullmerC Offline
                            Use an attribute dictionary to attach information to the model. It will stay with it after the model is closed and opened.
                            Single Dictionatires
                            http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionary
                            Collections of multiple dictionaries
                            http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionaries
                            This is a much more stable way to maintain data in the model from session to session.
