    Empty groups get deleted?!
    19 Posts 7 Posters 1.6k Views 7 Watching
      It's a know way of removing an unused definition from the Component Browser without recourse to definitions.purge_unused, which of course might also remove components that the users has not yet got inserted, but would like to keep for later...
      definition.entities.clear!
      within a start/commit block will remove the definition.
      Similarly group.entities.clear!, although in that case group.erase! will work BUT can can fall foul of some new BIMish ill-advised entities-observers... πŸ˜’
        @dan rathbun said:
        @thomthom said:
        SketchUp will remove empty definitions from the model. Even definitions of ComponentInstances.
        definitions ??
        I thought it was empty instances that were GC'd ?
        Instances are just references to definitions. And it's not garbage collection - if it had been then they would not have disappeared when you have reference to them. It's SketchUp cleaning up.
          @dan rathbun said:
          definitions ??
          You're not talking about Ruby instances, right?
          • Dan RathbunD
            Dan Rathbun
            No. Back on the topic of the OP,... he was asking about group instances that get GC'd before he can use them, because they are empty.
            I'm not here much anymore.
              Andreas as the first one to mention the GC. The OP only said the group was deleted - which is what happens to definitions when they are empty.
              @niccah said:
              okay, I insert now a small edge and hide the full group... when the user insert his first objects, I delete this line and make the group again visible...
              Why not create the group only right before you need to add something to it?
              • N
                niccah
                At first! Thank you very much again for all your comments! I'm always learning a lot, "listening" to your discussions!
                Following idea:
                • the user can create a "project" => so, in my code, I create at first an empty group
                • all the projects will be listed in a table
                • now, the user can add to a single project some "parts"
                So, my current problem:
                • user create a project, and then he / her starts to draw the "part" => during drawing, the empty project group will be removed by GC...
                My hidden line in the groups works perfect! I know, it not realy smart, but...
                  That's where I ask: why do you need to create the group in advance before you actually make use of it? Seems to me it complicates things a little when you try to fight SketchUp for the group - slapping its wrist using hidden temp geometry.
                  • N
                    niccah
                    πŸ˜„ Okay, let me "answer" with a new question - what can I do else? πŸ˜„ The user would like to create a project => so, somewhere I have to save this information about the projects (name, options, etc, ..). And the user could create a project and close Sketchup => so, the information about the new project has to be saved somewhere "for ever".
                    I realy agree, my way is realy complicated...
                    • Dan RathbunD
                      Dan Rathbun
                      OK major problem with your logic.
                      In Ruby you can cause the current editing context (the "project" group,) to be exited, via:
                      model#close_active()
                      BUT there is no API method to enter INTO an editing context. (You cannot cause the "project" group to become active for edit.)
                      • Chris FullmerC
                        Use an attribute dictionary to attach information to the model. It will stay with it after the model is closed and opened.
                        Single Dictionatires
                        http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionary
                        Collections of multiple dictionaries
                        http://www.sketchup.com/intl/en/developer/docs/ourdoc/attributedictionaries
                        This is a much more stable way to maintain data in the model from session to session.
