    Motocross - CR 250 from first poly-up
    24 Posts 9 Posters 3.3k Views 9 Watching
      pixelmonkey380
      @motojoel_07 said:
      Nice Model
      Will you be putting the engine logo on the side of the engine case?
      havent really started on the motor yet. just threw a eyeball guess at the clutch and ignition covers size and position. thinking i'll snap several photos over the weekend and have a good portion of the motor completed for next weeks post.
      been having a few problems with random lines wanting to be visible after hiding them on the frame and other parts of the bike. I think i'll start locking a few of the components and see if it solves the problem.
      chris<pixelmonkey>:D
        pixelmonkey380
        getting closer!
          Looking even better πŸ‘
            pixelmonkey380
            front number plate and re-grouped cross bar pad added
              pixelmonkey380
              a few more updates. also want to note no image maps are used for the end result. all decals and parts are made via poly.
              • axeonaliasA Offline
                axeonalias
                Ouch! Its really a simple process adding the images onto the model,cutting the face has al sorts of implications,or is there a specific reason behind it? Btw nice bike πŸ˜„
                https://sketchfab.com/Axeonalias
                  pixelmonkey380
                  unlocked model on the warehouse
                  been working on other projects. unlocked this one a few weeks ago.
                  mostly complete. i fear adding the final few parts will bring it over the 10mb size limit.
                  • Bryan KB Offline
                    Yeow and wow!
                    How are you making the more complex curved surfaces?
                    • cheddaC Offline
                      chedda
                      The bike looks great nice job. Axeonalias how do you suggest adding decals without creating geometry i had this problem a while back. Intersecting geometry leads to other problems notably smoothing etc.
                      Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
                      • pbacotP Offline
                        great model ! πŸ‘ πŸ‘
                        Please show wireframe detail or explain the poly decals πŸ‘ πŸ‘ πŸ‘
                          pixelmonkey380
                          @bryan k said:
                          Yeow and wow!
                          lots of trial and error!
                          I was having the same problem which is why i created the decal separately.
                          I've never been able to get an image map to stay in the correct location, or have the color correct. It's just been easier to create the decal and have the clean edge and colors. Most of the decals, excluding the radiator shrouds, were made flat and then turned or laid to the next flat surface after being broken apart.
                          The decals on the Radiator shrouds were made with a duplicate of the shroud, sliced, then re-colored. From that point, the position was moved 1/32" from the surface of the shroud and adjusted as needed.
                          feel free to look around the models i've posted on the warehouse. Over the last year or so, i've gotten a much better grasp of the application.
                          pixelmonkey380 models on the warehouse
                          • 2 / 2
