    Make faces in curved frame
    8 Posts 6 Posters 573 Views 6 Watching
    • artmusicstudioA
      artmusicstudio
      hello,
      i just went thru all my rubies, but somehow i cannot find one for genereting faces in a curved frame:
      has anybody a tip for a ruby, which can generate a face in a structure, as shown in the picture atached?
      thanx a lot and merry xmas to all of you!
      stan
        Try CurviLoft or one of my ExtrudeEdgesBy... tools - e.g EEbyRails [provided that you have 4 welded curves - Divide the vertical edges into a few parts and immediately use Weld to make them into Curves]...
        OR since it looks quite simple, you could also use EEbyVector on one preselected Arc, pulling it up vertically into a surface...
        • artmusicstudioA
          artmusicstudio
          hi tig,
          hi tig,
          yes, that works, thanx for the advise of welding the lines into curves, that was , what made EE by rails (which i tried before already) not working.
          great! thank you a lot!
          merry xmas !
          stan
          • Chris FullmerC
            or more simply, use the sketchup pencil tool to draw a line between the bottom endpoints of the curve, to make a flat face. Then pull that face upwards to the top of curve and delete the extra faces that get made in the process.
            • artmusicstudioA
              artmusicstudio
              hi mr. fulmer,
              yes, i chose a wrong example, because sometimes the curve has an s-form , so connection of endpoints does not create a face (without further intersections).
              but you are right in that case....
              regards and thanx
              stan
              • cottyC
                cotty
                @artmusicstudio said:
                hi mr. fulmer,
                regards and thanx
                stan
                Not with one extra line, but with two or three ...
                my SketchUp gallery
                • massimoM
                  massimo Moderator
                  Still just one line in your example, cotty. πŸ˜‰
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    There is more than a straight line that can be used to close a face from ends of arcs. This simplify works by avoiding unnecessary intersections. See this SU file for ideas.
                    Curved face.skp
