    [Talk] Plugins Index
    179 Posts 70 Posters 79.3k Views 70 Watching
    • V Offline
      victor hugo
      Hi everyone.
      Does anyone know of a good shadow analysis plugin for SU?
      Thanks.
      • Dan RathbunD Offline
        Dan Rathbun
        Hey Victor...
        Have you tried DavidBoulder's OpenStudio plugin / application combination ?
        It's free as it was developed by the US Government lab NREL (US Dept. of Energy)
        πŸ’­
        I'm not here much anymore.
        • V Offline
          victor hugo
          Thanks Dan.
          I have not tried openstudio, I was on google looking for shadow plugins and found 1001Shadows and Shadow Analysis by Tomasz Janiak, Have you tried this last two?
          Thanks.
            Dan Rathbun
            No I do not shadow analysis, myself. Was just suggesting a possibility.
              Seevee
              All,
              Where can I get BASIC beginner info on plug ins. Step by step. I've downloaded the ROUNDCORNER_Dir_23 plugin and the LIBFREDO6_Dir_47 and have no clue what to do. Nothing shows up.. do I need to open something? Thanks!
              Larryo
                Dan Rathbun
                @Jim: The [/hr] bbCode tag is no longer recognized, nor needed. It is rendering as plain text at the top of the index page (just below the horizontal rule.)
                  @seevee said:
                  All,
                  Larryo
                  Have a look at this article - see if it's of any help: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                    Seevee
                    @thomthom said:
                    @seevee said:
                    All,
                    Larryo
                    ThomThom,
                    Thx but went thu all of the options and none worked. I'm a rank beginner regarding installing stuff and extensions. Perhaps need something easier.
                    Also using Mac OS 10.8.2
                    SketchUp 8.0.15157
                    Didn't try your simple loader, believe that's Windows only?
                    Larryo
                      No - it works both. Unless it explicitly says otherwise you can assume plugins work on both Windows and OSX.
                      Install the Simple Plugin Installer. It's an RBZ file which you install by using the "Install Extension" feature under Preferences > Extensions.
                      You can then use it to install the ZIP packages which Fredo's plugins comes as.
                      (Or rename Fredo's ZIP files to RBZ files and install them directly using the "Install Extension" button under Preferences > Extensions.
                      (Out of curiosity, why did you assume the Simple Installer was Windows only?)
                      • wimveW Offline
                        wimve
                        @tig said:
                        The flightpath rb at the Depot at crai is RickW's and should work fine and doesn't include any 'linetool' calls - it appears to be just the same as the Smustard.com one.
                        The flightpathtool rb at the Depot at crai has been [clumsily] modified...It says
                        ...modified by Matt Gorbet, using tons of code by RickW
                        require 'sketchup.rb'
                        require 'linetool.rb'
                        So that's why linetool is getting called when you run that version because he changed it to use that tool ! But note that NEITHER tool is perfect either.
                        Perhaps Didier should consider removing one or both ?
                        I was (again) looking at this tool since i wanted to make a walkthrough animation of my model.
                        But flightpath only makes a lot of scenes without any respect of my camera values like angle of view.
                        Flightpath (free version) only asked for start and endpoint, units per time and then changes into nothing more the a measuring device. I get a line fixed at the start point and then nothing only the distance in the right lower corner changes.
                        Is there somebody who can fix or make a better rubby ?
                        Best regards,
                        Wim
                        Holland
                        http://www.petromax.nl/DeBeer.html
                          Have you read and understood the issues surrounding ' flightpath' and its clones.
                          Some versions work and some have severe problems.
                          All have a few issues...
                          I suggest you return to the author's original at Smustard.com
                          There is a simple 'free' or an inexpensive 'paid' version...
                          • wimveW Offline
                            wimve
                            Dear TIG,
                            I did download the script (flightpath) from Smustard. I have read that there are issues.
                            Why would I pay, even a small amount, for something I can't test or like you said and what is written under "issues surrounding flightpath" ?
                            That is why I asked if there is somebody who can fix these problems and make a good one. Which I would be happy to pay for if it does what it promises : following a line, focus point or line, FOV, etc.
                            Walking through your models would be a very very nice option.
                            Best regards,
                            Wim
                            Holland
                              @Wim
                              As far as I know ' flightpath2' from Smustard.com is the best, and it's only $7 !
                              It offers many more features than the older ' flightpath'
                              Rick Wilson its author is available via Smustard and would field any issues/questions you might have... if anyone can 'fix' things or simply advise it's him.
                              • wimveW Offline
                                wimve
                                @tig said:
                                @Wim
                                Ok, thanks.
                                Wil get that one.
                                Best regards,
                                Wim
                                Holland
                                  Amazing Artist
                                  Good Day to You All,
                                  First, let me say that I am a big fan of Sketchup and an even bigger fan of some of the writers of my favorite ruby scripts that I see here all the time.
                                  Second, let me say that if I am posting this question in the wrong place, I apologize and please send me a message so that I can post it correctly.
                                  I have designed several small woodwork projects using Sketchup, with lots of happy results. I am currently designing a piece of furniture with curves in it. My problem is as follows: I have created a bezier curve on one side of the project and need to copy and flip the curve to the other side, so they are symmetrical. I cant seem to find a "mirror" or "flip bezier curve" script. Does one exist or can anyone suggest a way to do this?
                                  I have attached a picture of what I mean and hope someone can help. This is my first time posting in one of these forums, so if I have posted in the wrong place or didn't follow a specific protocol, I apologize.
                                  I look forward to hearing from someone. Many Thanks in advance.
                                  curve on the right, copy and flip to match same position on left making the curves symmetrical.
                                  [color=#FF40FF:20ov4k9m]T[/color:20ov4k9m][color=#FF40F9:20ov4k9m]h[/color:20ov4k9m][color=#FF40F2:20ov4k9m]a[/color:20ov4k9m][color=#FF40EC:20ov4k9m]t[/color:20ov4k9m][color=#FF40E5:20ov4k9m]'[/color:20ov4k9m][color=#FF40DF:20ov4k9m]s[/color:20ov4k9m] [color=#FF40D2:20ov4k9m]m[/color:20ov4k9m][color=#FF40CC:20ov4k9m]y[/color:20ov4k9m] [color=#FF40BF:20ov4k9m]s[/color:20ov4k9m][color=#F940B9:20ov4k9m]t[/color:20ov4k9m][color=#F240B2:20ov4k9m]o[/color:20ov4k9m][color=#EC40AC:20ov4k9m]r[/color:20ov4k9m][color=#E540A6:20ov4k9m]y[/color:20ov4k9m][color=#DF40A0:20ov4k9m],[/color:20ov4k9m] [color=#D24093:20ov4k9m]a[/color:20ov4k9m][color=#CC408D:20ov4k9m]n[/color:20ov4k9m][color=#C54086:20ov4k9m]d[/color:20ov4k9m] [color=#C53A7A:20ov4k9m]I[/color:20ov4k9m][color=#CC3373:20ov4k9m]'[/color:20ov4k9m][color=#D22D6D:20ov4k9m]m[/color:20ov4k9m] [color=#DF2060:20ov4k9m]s[/color:20ov4k9m][color=#E51A5A:20ov4k9m]t[/color:20ov4k9m][color=#EC1353:20ov4k9m]i[/color:20ov4k9m][color=#F20D4D:20ov4k9m]c[/color:20ov4k9m][color=#F90646:20ov4k9m]k[/color:20ov4k9m][color=#FF0040:20ov4k9m]i[/color:20ov4k9m][color=#F9004D:20ov4k9m]n[/color:20ov4k9m][color=#F20059:20ov4k9m]g[/color:20ov4k9m] [color=#E50073:20ov4k9m]t[/color:20ov4k9m][color=#DF0080:20ov4k9m]o[/color:20ov4k9m] [color=#D20099:20ov4k9m]i[/color:20ov4k9m][color=#CC00A6:20ov4k9m]t[/color:20ov4k9m][color=#C500B2:20ov4k9m]![/color:20ov4k9m]
                                    There is my Mirror tool [a SCF Plugins Index Search should find it]...
                                    You will find that the Curve's 'Bezier-ness' will be kept after the Mirror [but include any cpoints in the Mirror if you expect to Edit the Bezier copy later on].
                                    Alternatively here is how to do it manually...
                                    Select the Curve, use the Move Tool + Ctrl to copy it off to one side.
                                    Select the Curve, use the Scale Tool, dragging a green side-handle, type in -1 + <return>.
                                    The Curve will 'Mirror' about that axis.
                                    Select the Curve and Move it to where you want it to be...
                                      Amazing Artist
                                      TIG! If you were a rockstar, I'd be your groupie! I have almost every single plug in you make!! Thank you so much!I did this manually, and it achieved exactly what I was trying to achieve!
                                        aldar
                                        thank you thank you thank you
                                        • genma saotomeG Offline
                                          genma saotome
                                          It's been some time since this list was updated. Has it fallen of of favor because of SU 2013? I hope not... I usually wait 6-12 months before changing to a major version release and so the plug-in index is still very much appreciated.
                                            There have been relatively few updates as a direct result of v2013.
                                            The PluginStore accessed off the Resources menu includes all major 'SCF-hosted' plugins [>600] and it is kept up to date on a daily basis...
                                            You can search the listings, by keyword[s]/recent/popular/category/author etc...
                                            The 'missing' plugins are some minor 'code snippets', a few plugins known to cause clashing and other issues, and some plugins that are hosted solely on other sites, and are therefore not directly download-able or auto-installable using SCF's tools... w
                                            We do seek the agreement of these scripts' authors to include them in the PluginStore, but it is not always forthcoming, and keeping on top of 'remotely stored' updated files then becomes an issue too...
                                            If you do find any scripts that are hosted at SCF but that you thing are missing from the PluginStore itself then please let an admin/mod know [PM?] and we'll check - a few might 'slip through the net'...
                                            • 9 / 9
