    [Plugin] Skelion (solar, shadows)
    102 Posts 45 Posters 253.7k Views 45 Watching
    • JuantxoJ Offline
      Juantxo
      @driven said:
      Sketchup installed [via the rbz] into my ~/Library/ path, not not the normal HD/Library path.
      Now is fixed. Download "skelion_v503.rbz".
        masonc
        I've tried the extension renaming trick, Sketchup still doesn't allow me to select the RBZ file. Any other way to get this done?
          You could try this plugin to help: http://forums.sketchucation.com/viewtopic.php?t=42315#p375454
          Simplifies installing .zip, .rbz, .rb, .rbs plugin files to your plugin directory.
            masonc
            @juantxo said:
            @hampson said:
            Anyway, my main question regarding the plugin is how do I get it to maximise the full area when laying down solar panels?...
            One of the features you should consider adding is a roof edge spacing, as in, I want to calculate the amount of PV on this roof, here is the panel, here is the tilt, I want to remain 18" from the edges as per best practices. It would make it easier to calculate the maximum PV given a certain roof shape.
            • JuantxoJ Offline
              Juantxo
              Ok, maybe in next release multiple offset could be added.
              If you need it a lot, you can install one of those plugins:
              Multiple face offset
              Multiple offsets
              • JuantxoJ Offline
                Juantxo
                Maybe with this video you will be able to understand better how plugin works inserting components.
                [flash=560,349:kj85orwu]http://www.youtube.com/v/kTUDK-_zJ2g?version=3&hl=en_US[/flash:kj85orwu]
                • JuantxoJ Offline
                  Juantxo
                  A new version (skelion_v504) has been released.
                  Now you can pile up components in same row and distribute rows in same grid with "rows alignment". A user's guide has been added too.
                  Sun path chart plots has been added as free features to the plugin:
                  http://skelion.net/images/forum/f6_cartesian.jpg
                  http://skelion.net/images/forum/f5_polar.jpg
                  • V Offline
                    vladglebov
                    Just purchased the Pro version but would be helpful to have a better tutorial... having lots of trouble figuring it out.
                    • JuantxoJ Offline
                      Juantxo
                      For mac users:
                      Safari 5.1.7 turns black the text boxes of plugin dialogs.
                      Read this thread to solve the problem:
                      http://forums.sketchucation.com/viewtopic.php?f=11&t=45382&hilit=black+webdialog&start=15
                        bnwitt
                        I have been using this plugin now for several months. It has changed the way I do PV system modeling. I now start every project in Sketchup with Skelion and then go to my cad program to finish the customer presentation. On some projects, I have created the entire presentation in Sketchup/Skelion.
                        What I like best about working with Skelion, is the ability to set the start time and stop time on any date for the shading from row to row and having the row spacing automatically calculated by Skelion. I have redone several system layouts with Skelion and been able to get more modules on a site then my previous calcs allowed.
                        I also love the speed at which I can complete a layout and then render it for a client in either jpeg or animation. This program has cut that time by leaps and bounds. For a ground mount where no building must be drawn I can create utility scale layouts in minutes. For projects where a structure must be created, the module layout is now the easiest part of the job. The simple rooftop layout shown in the attached file took 5 minutes and I know the row spacing is correct without doing the math. I've verified several layouts from skelion in other shading analysis programs and just by doing the math and the accuracy is excellent.
                        Figuring out the Skelion interface didn't take too long with the help of Juan Pons(the creator of Skelion)since he is so quick to reply to emails. He even added some features I requested in one of my emails. Of course a detailed manual would be great and I'm sure once the number of users gets high enough to warrant a redo Juan will do that. If you are a PV designer Sketchup is an excellent tool for Shading analysis. With the Skelion plugin added it can't be beat. I love it. πŸ˜„
                        Barry
                        C3 Solar Design
                        Simple rooftop PV layout
                          AirWindSolar
                          Maybe I'm missing something in setting up the component, but I've got a big project coming up that we might be using Zilla Cobra ( http://www.zillarac.com/Portals/0/Documents/PDF/systems/ZillaCobra_Specs_0512.pdf ) racking for. I built a component of a 280W panel attached to a single Cobra unit, and when I went to use it with Skelion, I couldn't figure out a way to get to it happily match up at the fixed spacing. (Cobra links together in columns, rather than rows.)
                            bently
                            I have been using your pro version for quite a while now, it is fantastic! I just wanted to thank you for an affordable time saver... I noticed on your new website it says the 3d model can be exported into PVSYST. Is there any instructions on that... That would be soooo helpful. PVsyst modeling is quite cumbersome!
                            Thanks again,
                            Bently
                            • JuantxoJ Offline
                              Juantxo
                              PVSYST exporter is not yest in manual but you can export pressing pvsyst icon: pvsyst_icon.JPG.
                              Buildings does not project shadows over solar panels. They are working to fix that. But size and position of solar panels are right.
                                The_Robbies
                                My latest job:
                                About 100 kWp
                                http://solar.onlinedivision.eu/images/SKUP-MAXWELL-IMAGE-002.jpg
                                  solemassoud
                                  I have been using Skelion pro for a few months and it is a great tool. lately the 'sunny area' (Moon icon) calculation tool doesn't seem to work. I normally check for shaded surfaces before laying out the panels.
                                  could you please advise if there is a bug in the plug in or if there is detailed instructions on how to use the tool.
                                  Thanks,
                                    kaiyer
                                    PVWatts is changing. There is a new version http://pvwattsbeta.nrel.gov/
                                    that will replace the v1 and v2 versions soon. How do I update to point to the new PVWatts. Is this something I can do myself? Can you update and release a new version?
                                    • Y Offline
                                      yiannosh
                                      I have just installed Skelion plugin V5.0.8 on my pc.
                                      When i pick any button on Skelion toolbar, an empty window appeared on the screen, and I can't do anything.
                                      Can anyone help me?
                                      • JuantxoJ Offline
                                        Juantxo
                                        No, you can not update yourself. You need to wait to for a new Skelion release.
                                        You are talking of a beta PVWATTS. When it will be stable Skelion will change if it is necessary.
                                          szumlanski
                                          Something doesn't seem to behave the way I expect it to work. The Space between panels [S] works well, but the "Stack Space [K]" leaves no space between panels. Also, I do not understand the use or meaning for "Stack components."
                                          Note the lack of vertical space between panels in the attached image. This occurs with embedded panel profiles and with custom loaded panels in landscape or portrait orientation. I can't figure out if I am doing something wrong, or if this is the intended result. I just downloaded the V5.08 version.
                                          No vertical space between panels
                                          • JuantxoJ Offline
                                            Juantxo
                                            Don't use stack components when coplanar. Stack components is used to insert rows with more than one panel when they have some tilt over the roof or ground.
                                            • 2 / 6
