    [Plugin] Estimates (extended)
    50 Posts 23 Posters 57.2k Views 23 Watching
      I hope that you are editing the correct 'attributes.rb' file in the 'Examples' subfolder within the 'Plugins' folder... AND restarting Sketchup so the change is activated ?
      Are you sure you added "Baht" in the 3 places just as I said ?
      There is an alternative way...
      If you are always going to use "Baht" then you could set every thing to always use that.
      Change the dialog part as follows to avoid asking about 'Currency':
      prompts = [$exStrings.GetString("Unit: "), $exStrings.GetString("Default Material cost: ")] values = [units.index($estimates_unit), $estimates_cost_default_material]
      and also the line
      dropdowns=[curList,unList]
      must become
      dropdowns=[unList,""]
      and also the line after the dialog...
      Then the line
      $estimates_currency=currencies[results[0]]
      must become
      $estimates_currency="Baht"
      or
      $estimates_currency="฿"
      to use a 'symbol'...
      The other results must also be adjusted from
      $estimates_unit=units[results[1]] $estimates_cost_default_material=results[2]
      to
      $estimates_unit=units[results[0]] $estimates_cost_default_material=results[1]
      • T
        thaigringo
        Thanks again... I have made the changes to the correct attributes file and saved it and restarted SU but it didn't change the default currency... There are two $estimates_currency="Euro" if !$estimates_currency entries one is Line 19 and again at line 374... but the one at line 374 says "SEK"...
        If I change the entry at line 374, when I go to settings it shows nothing selected in the currency dropdown... The currency list is there but the default is blank...
        I will try the new suggestion tomorrow... I'm old and need my sleep... 2"30 am here.. Will let you know what happens...
        Thanks again
        Fred
          Sorry I missed the second entry !
          The script is a little muddled in its logic.
          As well as editing the ='Euro' line, edit the later line
          def estimate_defaults() $estimates_currency="SEK" if !$estimates_currency
          to read...
          def estimate_defaults() $estimates_currency="Baht"
          Or if you were using a 'symbol' use that instead of 'Baht'...
          This will always use "Baht" as your currency !
          • C
            chiklopes
            %(#BF0000)["Error Loading File attributes.rb
            undefined method `GetString' for nil:NilClass"
            can anyone help me please?
              Looks to me as if you haven't ticked the box for "Ruby Script Examples" in Window>Preferences>Extensions.
              • jemagnussenJ
                jemagnussen
                Hi Dave,
                I belive I have followed every instruction, but I must have overlooked something as I can't get it to work, get this error measage:
                Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/examples/exampleScripts.rb
                undefined local variable or method ' for main:ObjectError Loading File examples.rb undefined local variable or method ' for main:Object
                I have used "kr" as currency, edited the example.rb in notepad, changed as advised. Replaced the script file and restarted Sketchup several times.
                Hope you can help.
                Best regards
                Jesper
                HP ZBook 15, Windows 10 64 bit
                Intel Core i7-6820HQ @ 2.70GHz
                32 GB Ram
                NVIDIA Quadro M2000M
                  Did you tick the box for Ruby Script Examples under Extensions?
                  You changed your post while I was typing.
                  Do you have full administrative rights to the Plugins folder?
                    The error-message suggests that you have mis-edited the code...
                    Get a fresh copy and with it opened in Notepad do a case-sensitive find/replace for SEK and substitute Kr - in every case - that's all that's needed...
                    If it still fail;s then can you post the line/s you edited [and the lines either side of it/them] - exactly as they appear [copy+paste] - use a 'code' formating tag...
                    Alternatively PM the whole file to me - don't post it all - it's confusing for members when faulty scripts are hanging around...
                    • jemagnussenJ
                      jemagnussen
                      Hi Dave,
                      Yes, I did tick on the Ruby script Excamples ans yes, I have admin right to the folder and file.
                      Best regards
                      Jesper
                      32 GB Ram
                        I think TIG has identified the problem. 😉
                        • jemagnussenJ
                          jemagnussen
                          Hi TIG,
                          Followed you advice to take a fresh copy, replace SEK with kr (case sensitive) but still get this error meassage when opening Sketchup 8 Pro after the change:
                          Brgds
                          Jesper
                          32 GB Ram
                          • jemagnussenJ
                            jemagnussen
                            Hi TIG,
                            Brgds
                            Jesper
                            Just for clarity, it works fine without any changes.
                            32 GB Ram
                            • jemagnussenJ
                              jemagnussen
                              Hi all,
                              it's actually kinda strange that when I take a fresh copy it works fine, I can use €, $ or SEK in settings and it works fine. When I do a Ctrl+H (replace) with case sensitive selected and replace all instances of SEK with kr then I get the error meassage and even when trying to reverse by asking for a change back from kr to SEK, I still get the error. Tried to change from SEK to NOK, same issue..?
                              Best regards
                              Jesper
                              32 GB Ram
                                Did you change every instance of SEK?
                                  You has a very subtle problem indeed !
                                  A Ruby script is typically in "UTF-8 without BOM" text-encoding format.
                                  When you edited it with Notepad and saved it, its format changed to "UFT-8", which corrupts the text so it then fails to load properly...
                                  I will PM you a suitably encoded copy...
                                  Can I suggest you get "Notepad++" [free].
                                  It has special Ruby Syntax highlighting etc and you can set it to always open/save files with the right encoding...
                                  • jemagnussenJ
                                    jemagnussen
                                    Thank you TIG,
                                    It works like a charm, and I will rush to get Notepad++ to avoid this in the future.
                                    Thanks again to both and have a fine day,
                                    Jesper
                                    32 GB Ram
                                    • C
                                      chiklopes
                                      it is ticked but the error message is the same!
                                        This error message relates to the 'language handler' system tool...
                                        There would have been more text, you curtailed it just before the line number generating the error... 😒
                                        For example .GetString("Square meters"). That is looking up the 'translation' in the '.string' file.
                                        Have you edited the file ?
                                        Have you got any text reading something like .GetString() or .GetString(**nil**) or .GetString(**any_text_without_paired_quotes**)
                                        Is the .rb file still in "UTF-8 without BOM" encoding etc ??
                                        Check that with Notepad++...
                                        Just to double-check...
                                        Do you have a file named 'langhandler.rb' in the 'Tools' folder?
                                        If not you should !
                                        Try reinstalling/repairing Sketchup to get it back.
                                        If you have a similar file in the 'Plugins' folder then remove.
                                        Have you installed one of the older rogue compilation tool-bar scripts?
                                        These can come zipped with some older SketchUp 'system' files that then get installed into 'Plugins', whereby the correct [newer] ones Sketchup provides in 'Tools' get screwed !
                                        The files they can mess with include 'sketchup.rb', 'extensions.rb' and 'langhandler.rb'.
                                        If you have any of these in your Plugins folder remove them.
                                        If you do not have them in your Tools folder reinstall/repair Sketchup...
                                        • P
                                          ptasznick
                                          I've read all posts on estimate plugin and can't find any solution for my problem. Plugin installed as in readme file. Cost settig for materials, and cost estimation by material works fine.
                                          However plugin seems to only see default Susan component despite i have 2 components in my scene.
                                          I tried this plugin on another - more complicated model - and it seems that only components which have "by" attribute filled in are listed in Your plugin. I have a scene with hundreds of components, yet only 3 of them are listed - these are downloaded form 3d warehouse and have ie. "by Google" attribute set in them.
                                          I guess it is a glitch, and it would be nice to get it fixed or some kind of workaround.
                                          I use win7 pro sketchup 8.
                                          Thanks for advice!
                                          UPDATE: My problem is that only components having an author are listed in assign cost to component dialog window. If i save a component to a different file, then open the file, claim credit to it, the go back to original file and replace all old instances to a new "credited" one, it appears in assign cost to component dialog box. It this the way it's ment to be?
                                          • brodieB
                                            brodie
                                            I seem to be having a similar issue as others have reported.
                                            When I installed the plugin via the link in this thread I got the
                                            error. So I deleted the files and installed it via the sketchucation plugin store (I'm on SU v7). It worked although the only component I could select was Susan. Based on one of the other posters I was going to try crediting a component to myself to see if that would be a workaround. After closing and reopening sketchup I now get the same error as above though and the plugin no longer shows up in my list.
                                            -Brodie
                                            Edit: I'm actually on SU 8
                                            • 2 / 3
