    [Plugin] Estimates (extended)
    50 Posts 23 Posters 56.7k Views 23 Watching
    • T
      thaigringo
      Great plugin.
      How can I change the default currency that loads when I create a new Model. I have added Baht (I am in Thailand) but when I load a new model the default currency is SEK and I would like it to be Baht.
      Fred
        Edit the tool's attributes.rb file with Notepad or a similar plain-text editor.
        Find the line:
        currencies={"Euro"=>"€","Dollar"=>"$","SEK"=>"SEK"}
        Add [or delete]...
        To add 'Baht' insert a new lash member at the end thus:
        currencies={"Euro"=>"€","Dollar"=>"$","SEK"=>"SEK"**,"Baht"=>"฿"**}
        Or perhaps ... **=>"B"** depending on your PC's Unicode settings ?
        Also change the line:
        curList=["Euro","Dollar","SEK"].join("|")
        to include it...
        curList=["Euro","Dollar","SEK"**,"Baht"**].join("|")
        To make that currency your default, find the line:
        $estimates_currency="Euro" if !$estimates_currency
        change it to...
        $estimates_currency=**"Baht"** if !$estimates_currency
        Hope this helps...
        • T
          thaigringo
          Thanks for the quick reply...
          Made the changes but still Defaults to SEK...
          Any other suggestions?
          Fred
            I hope that you are editing the correct 'attributes.rb' file in the 'Examples' subfolder within the 'Plugins' folder... AND restarting Sketchup so the change is activated ?
            Are you sure you added "Baht" in the 3 places just as I said ?
            There is an alternative way...
            If you are always going to use "Baht" then you could set every thing to always use that.
            Change the dialog part as follows to avoid asking about 'Currency':
            prompts = [$exStrings.GetString("Unit: "), $exStrings.GetString("Default Material cost: ")] values = [units.index($estimates_unit), $estimates_cost_default_material]
            and also the line
            dropdowns=[curList,unList]
            must become
            dropdowns=[unList,""]
            and also the line after the dialog...
            Then the line
            $estimates_currency=currencies[results[0]]
            must become
            $estimates_currency="Baht"
            or
            $estimates_currency="฿"
            to use a 'symbol'...
            The other results must also be adjusted from
            $estimates_unit=units[results[1]] $estimates_cost_default_material=results[2]
            to
            $estimates_unit=units[results[0]] $estimates_cost_default_material=results[1]
            • T
              thaigringo
              Thanks again... I have made the changes to the correct attributes file and saved it and restarted SU but it didn't change the default currency... There are two $estimates_currency="Euro" if !$estimates_currency entries one is Line 19 and again at line 374... but the one at line 374 says "SEK"...
              If I change the entry at line 374, when I go to settings it shows nothing selected in the currency dropdown... The currency list is there but the default is blank...
              I will try the new suggestion tomorrow... I'm old and need my sleep... 2"30 am here.. Will let you know what happens...
              Thanks again
              Fred
                Sorry I missed the second entry !
                The script is a little muddled in its logic.
                As well as editing the ='Euro' line, edit the later line
                def estimate_defaults() $estimates_currency="SEK" if !$estimates_currency
                to read...
                def estimate_defaults() $estimates_currency="Baht"
                Or if you were using a 'symbol' use that instead of 'Baht'...
                This will always use "Baht" as your currency !
                • C
                  chiklopes
                  %(#BF0000)["Error Loading File attributes.rb
                  undefined method `GetString' for nil:NilClass"
                  can anyone help me please?
                    Looks to me as if you haven't ticked the box for "Ruby Script Examples" in Window>Preferences>Extensions.
                    • jemagnussenJ
                      jemagnussen
                      Hi Dave,
                      I belive I have followed every instruction, but I must have overlooked something as I can't get it to work, get this error measage:
                      Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/examples/exampleScripts.rb
                      undefined local variable or method ' for main:ObjectError Loading File examples.rb undefined local variable or method ' for main:Object
                      I have used "kr" as currency, edited the example.rb in notepad, changed as advised. Replaced the script file and restarted Sketchup several times.
                      Hope you can help.
                      Best regards
                      Jesper
                      HP ZBook 15, Windows 10 64 bit
                      Intel Core i7-6820HQ @ 2.70GHz
                      32 GB Ram
                      NVIDIA Quadro M2000M
                        Did you tick the box for Ruby Script Examples under Extensions?
                        You changed your post while I was typing.
                        Do you have full administrative rights to the Plugins folder?
                          The error-message suggests that you have mis-edited the code...
                          Get a fresh copy and with it opened in Notepad do a case-sensitive find/replace for SEK and substitute Kr - in every case - that's all that's needed...
                          If it still fail;s then can you post the line/s you edited [and the lines either side of it/them] - exactly as they appear [copy+paste] - use a 'code' formating tag...
                          Alternatively PM the whole file to me - don't post it all - it's confusing for members when faulty scripts are hanging around...
                          • jemagnussenJ
                            jemagnussen
                            Hi Dave,
                            Yes, I did tick on the Ruby script Excamples ans yes, I have admin right to the folder and file.
                            Best regards
                            Jesper
                            32 GB Ram
                              I think TIG has identified the problem. 😉
                              • jemagnussenJ
                                jemagnussen
                                Hi TIG,
                                Followed you advice to take a fresh copy, replace SEK with kr (case sensitive) but still get this error meassage when opening Sketchup 8 Pro after the change:
                                Brgds
                                Jesper
                                32 GB Ram
                                • jemagnussenJ
                                  jemagnussen
                                  Hi TIG,
                                  Brgds
                                  Jesper
                                  Just for clarity, it works fine without any changes.
                                  32 GB Ram
                                  • jemagnussenJ
                                    jemagnussen
                                    Hi all,
                                    it's actually kinda strange that when I take a fresh copy it works fine, I can use €, $ or SEK in settings and it works fine. When I do a Ctrl+H (replace) with case sensitive selected and replace all instances of SEK with kr then I get the error meassage and even when trying to reverse by asking for a change back from kr to SEK, I still get the error. Tried to change from SEK to NOK, same issue..?
                                    Best regards
                                    Jesper
                                    32 GB Ram
                                      Did you change every instance of SEK?
                                        You has a very subtle problem indeed !
                                        A Ruby script is typically in "UTF-8 without BOM" text-encoding format.
                                        When you edited it with Notepad and saved it, its format changed to "UFT-8", which corrupts the text so it then fails to load properly...
                                        I will PM you a suitably encoded copy...
                                        Can I suggest you get "Notepad++" [free].
                                        It has special Ruby Syntax highlighting etc and you can set it to always open/save files with the right encoding...
                                        • jemagnussenJ
                                          jemagnussen
                                          Thank you TIG,
                                          It works like a charm, and I will rush to get Notepad++ to avoid this in the future.
                                          Thanks again to both and have a fine day,
                                          Jesper
                                          32 GB Ram
                                          • C
                                            chiklopes
                                            it is ticked but the error message is the same!
                                            • 2 / 3
