    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 28.8k Views 6 Watching
      driven
      @thomthom said:
      Do you see this in the 3d text plugin I sent you?
      Top one... I was being discrete
      ` > a = "2撖죺".unpack('C*')
      b = a.pack('C*')
      c = puts a.inspect
      puts b.inspect
      [50, 230, 146, 150, 236, 163, 186]
      "2撖죺"
      nil`
      the puts should read [0, 50, 100, 150, 200, 250] "2撖죺"
        Why are you using "C*" in the unpack and pack - doesn't that extract a character as an unsigned integer.
        Shouldn't it be "U*" - which extracts UTF-8 characters as unsigned integers ?
          Because I actually want to see each byte. Not the Unicode ID.
            Where are these numbers from?
            Why are you expecting a NULL byte? (That's usually a string termination in C.)
              driven
              I think this may be the root of my issues
              if you unpack(C), then pack(U) sh*t happens
              > a = "2撖죺".unpack('C*') b = a.pack('U*') c = puts a.inspect puts b.inspect [50, 230, 146, 150, 236, 163, 186] "2撖죺" nil
              and visa-versa
              > a = "2撖죺".unpack('U*') b = a.pack('C*') c = puts a.inspect puts b.inspect [50, 25750, 51450] "2\226\372" nil
              I think the first is happening somewhere
                driven
                font = Arial Unicode MS
                SU Top again
                WD bottom
                look familiar
                  driven
                  http://codereview.stackexchange.com/questions/3569/pack-and-unpack-bytes-to-strings
                    That's from a questions that doesn't really make sense.
                    Also:
                    Seeing as JavaScript has 16-bit strings, I packed two bytes per character.
                    Two byte per character isn't UTF-8.
                      driven
                      I was looking for test code and only grabbed the example, I got there from the Stackoverflow 'fix' that referred back.
                      Do these work as 3D Text on the PC...
                      I ran the full gamete of unpack().pack() scenario's in console and a mismatch is the only way to get the same results as the straight input.
                      • Dan RathbunD
                        Dan Rathbun
                        @thomthom said:
                        fonts.sort! %(#008000)[# (!) Not UTF-8 compatible! But better than nothing.]
                        (1) Since this will run only on Mac, which is Unicode aware, can't you pass the list to a command shell and use the shell's built-in sort filter ??
                        For instance on WIN, in DOS command shell, you can filter output by piping it through the sort filter, thus:
                        doc_list = %x(dir "~/documents/myproject" | sort)
                        or similar.
                        You'd need to build a plain text list from the array, each element being a line, separated by " \n"
                        (2) Alternative ... build an array copy using pack, sort it, then & unpack back to strings.
                        I think I'm late posting this... you guys are posting machines!
                        I'm not here much anymore.
                          If there is such a command then I'd guess that would work. But I'm not familiar with OSX terminal. Maybe John knows?
                          I can also use JS to sort it - since I'm displaying the list in a WebDialog.
                          • Dan RathbunD
                            Dan Rathbun
                            Shell Scripting Primer: Command Line Primer
                            tcsh(1) OS X Manual Page[*]
                            Filename substitution
                            If a word contains any of the characters *`', ?', `` [' or {`' or begins with the character ~`' it is a candidate for filename substitution, also known as globbing''. This word is then regarded as a pattern (glob-pattern''), and replaced with an alphabetically sorted list of file names which match the pattern.
                            • Also do a Find on " ls-F", it is a built-in and supposed to be faster than " ls -F"
                            OS X Manual Page: ls command Reference
                              driven
                              This is probably my last effort on this.... circles,
                              but, I finally figured out find in Ruby Console, escapes, escapes, escapes...
                              THE THIRD WAY... no Font Book... no fc-list... just plain old find >> mdls... not the fastest, but not too bad.
                              inculed is Dan's tester, these all created 3D text from console, only Font Book and usr/local/bin/fc-list do that out of the can.
                              a=(`find /System/Library/Fonts\ /Library/Fonts\ ~/Library/Fonts\ \\( -name "*.ttf" -o -name "*.otf" \\) -type f`).split("\n").map! { |f| f.gsub(" ", "\\ ")} #need this or something to catch spaces in filenames
                              b=(a.collect{|x| `mdls  -name com_apple_ats_name_family -raw #{x}`}).map! { |f| f.split(",")[0]} #the other items in each array are unicode strings for other languages, if you want those use Font Book
                              c=b.map { |f| f[/[("\s]+([^"\n]+)[)"\s]+/m,1] }.uniq!.sort![2..-1] #[0] is empty, [1] is a dot file, could remove them
                              macFonts = c
                              chunksize = 1
                              chunk = 1
                              limit = macFonts.length
                              model = Sketchup.active_model
                              fsize = 1.0
                              linespacing = 1.2
                              bold = false
                              italic = false
                              thick = 0.05
                              filled = true
                              quality = 0.0
                              i = 0
                              while i < limit
                                begin
                                  model.start_operation("3D Fontnames (#{chunk})")
                                    chunksize.times do |n|
                                      break if i == limit
                                      item = macFonts[i]
                                      grp = model.entities.add_group()
                                      grp.entities.add_3d_text( "#{item}", TextAlignCenter, "#{item}",
                                        bold, italic, fsize, quality, 0.0, filled, thick )
                                      grp.name= item
                                      grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-(i*linespacing),0)) )
                                      i += 1
                                    end # chunk
                                  model.commit_operation()
                                rescue Exception => e
                                  puts("\n*** macFonts group Error! ***")
                                  puts("  i = #{i}")
                                  puts("  chunk = #{chunk}")
                                  puts("  font = #{macFonts[i]}\n")
                                  model.abort_operation()
                                  puts("Error #<#{e.class.name}; #{e.message}>")
                                  puts(e.backtrace) if $VERBOSE
                                  raise
                                chunk += 1
                              end # while
                              • 6 / 6
