    Can you get a list of OSX fonts somehow?
    110 Posts 6 Posters 28.8k Views 6 Watching
      driven
      yes that does return correctly,
      which is why I can't understand why some thing get lost in transition...
      same font Stix(NON-Unicde)
      Top happens from Ruby Console as well as WebDialogs
      Bellow is the Built in Tool
        hm... I've not have any problems with it.
        Do you see this in the 3d text plugin I sent you?
          driven
          Top one... I was being discrete
          ` > a = "2撖죺".unpack('C*')
          b = a.pack('C*')
          c = puts a.inspect
          puts b.inspect
          [50, 230, 146, 150, 236, 163, 186]
          "2撖죺"
          nil`
          the puts should read [0, 50, 100, 150, 200, 250] "2撖죺"
            Why are you using "C*" in the unpack and pack - doesn't that extract a character as an unsigned integer.
            Shouldn't it be "U*" - which extracts UTF-8 characters as unsigned integers ?
              Because I actually want to see each byte. Not the Unicode ID.
                Where are these numbers from?
                Why are you expecting a NULL byte? (That's usually a string termination in C.)
                  driven
                  I think this may be the root of my issues
                  if you unpack(C), then pack(U) sh*t happens
                  > a = "2撖죺".unpack('C*') b = a.pack('U*') c = puts a.inspect puts b.inspect [50, 230, 146, 150, 236, 163, 186] "2撖죺" nil
                  and visa-versa
                  > a = "2撖죺".unpack('U*') b = a.pack('C*') c = puts a.inspect puts b.inspect [50, 25750, 51450] "2\226\372" nil
                  I think the first is happening somewhere
                    driven
                    font = Arial Unicode MS
                    SU Top again
                    WD bottom
                    look familiar
                      driven
                      http://codereview.stackexchange.com/questions/3569/pack-and-unpack-bytes-to-strings
                        That's from a questions that doesn't really make sense.
                        Also:
                        Seeing as JavaScript has 16-bit strings, I packed two bytes per character.
                        Two byte per character isn't UTF-8.
                          driven
                          I was looking for test code and only grabbed the example, I got there from the Stackoverflow 'fix' that referred back.
                          Do these work as 3D Text on the PC...
                          I ran the full gamete of unpack().pack() scenario's in console and a mismatch is the only way to get the same results as the straight input.
                          • Dan RathbunD
                            Dan Rathbun
                            @thomthom said:
                            fonts.sort! %(#008000)[# (!) Not UTF-8 compatible! But better than nothing.]
                            (1) Since this will run only on Mac, which is Unicode aware, can't you pass the list to a command shell and use the shell's built-in sort filter ??
                            For instance on WIN, in DOS command shell, you can filter output by piping it through the sort filter, thus:
                            doc_list = %x(dir "~/documents/myproject" | sort)
                            or similar.
                            You'd need to build a plain text list from the array, each element being a line, separated by " \n"
                            (2) Alternative ... build an array copy using pack, sort it, then & unpack back to strings.
                            I think I'm late posting this... you guys are posting machines!
                            I'm not here much anymore.
                              If there is such a command then I'd guess that would work. But I'm not familiar with OSX terminal. Maybe John knows?
                              I can also use JS to sort it - since I'm displaying the list in a WebDialog.
                              • Dan RathbunD
                                Dan Rathbun
                                Shell Scripting Primer: Command Line Primer
                                tcsh(1) OS X Manual Page[*]
                                Filename substitution
                                If a word contains any of the characters *`', ?', `` [' or {`' or begins with the character ~`' it is a candidate for filename substitution, also known as globbing''. This word is then regarded as a pattern (glob-pattern''), and replaced with an alphabetically sorted list of file names which match the pattern.
                                • Also do a Find on " ls-F", it is a built-in and supposed to be faster than " ls -F"
                                OS X Manual Page: ls command Reference
                                  driven
                                  This is probably my last effort on this.... circles,
                                  but, I finally figured out find in Ruby Console, escapes, escapes, escapes...
                                  THE THIRD WAY... no Font Book... no fc-list... just plain old find >> mdls... not the fastest, but not too bad.
                                  inculed is Dan's tester, these all created 3D text from console, only Font Book and usr/local/bin/fc-list do that out of the can.
                                  a=(`find /System/Library/Fonts\ /Library/Fonts\ ~/Library/Fonts\ \\( -name "*.ttf" -o -name "*.otf" \\) -type f`).split("\n").map! { |f| f.gsub(" ", "\\ ")} #need this or something to catch spaces in filenames
                                  b=(a.collect{|x| `mdls  -name com_apple_ats_name_family -raw #{x}`}).map! { |f| f.split(",")[0]} #the other items in each array are unicode strings for other languages, if you want those use Font Book
                                  c=b.map { |f| f[/[("\s]+([^"\n]+)[)"\s]+/m,1] }.uniq!.sort![2..-1] #[0] is empty, [1] is a dot file, could remove them
                                  macFonts = c
                                  chunksize = 1
                                  chunk = 1
                                  limit = macFonts.length
                                  model = Sketchup.active_model
                                  fsize = 1.0
                                  linespacing = 1.2
                                  bold = false
                                  italic = false
                                  thick = 0.05
                                  filled = true
                                  quality = 0.0
                                  i = 0
                                  while i < limit
                                    begin
                                      model.start_operation("3D Fontnames (#{chunk})")
                                        chunksize.times do |n|
                                          break if i == limit
                                          item = macFonts[i]
                                          grp = model.entities.add_group()
                                          grp.entities.add_3d_text( "#{item}", TextAlignCenter, "#{item}",
                                            bold, italic, fsize, quality, 0.0, filled, thick )
                                          grp.name= item
                                          grp.move!( Geom;;Transformation.new(Geom;;Vector3d.new(0,-(i*linespacing),0)) )
                                          i += 1
                                        end # chunk
                                      model.commit_operation()
                                    rescue Exception => e
                                      puts("\n*** macFonts group Error! ***")
                                      puts("  i = #{i}")
                                      puts("  chunk = #{chunk}")
                                      puts("  font = #{macFonts[i]}\n")
                                      model.abort_operation()
                                      puts("Error #<#{e.class.name}; #{e.message}>")
                                      puts(e.backtrace) if $VERBOSE
                                      raise
                                    chunk += 1
                                  end # while
                                  • 6 / 6
