    Another Problem :(
    14 Posts 5 Posters 613 Views 5 Watching
      benhardwick
      Oh Great, so how would I half the Boat so I can duplicate it..
      I am really sorry, I am just at the very basic level,
      thanks.
        No need to apologize. Since I can't see your SketchUp model, I can only give you generalities but I would just delete one half of the hull. You can probably just use the Eraser tool or select edges and delete them. Worry about making the copy of the half after you've drawn the half hull model.
          benhardwick
          There is an attachment on my first post.
          However there is a slight issue,some of the objects Cannot half.
          But to be perfectly honest, I do not know how to star half'ing.
          • ely862meE Offline
            ely862me
            You can draw a plane in the middle then select all the geometry ,right click and chose intersect selected then erase half of it . Still you have some holes here and there.
            What would you need the model for ?
            Elisei (sketchupper)
            Come and See EliseiDesign
              benhardwick
              Fantastic Thank you.
              I'm using this Model for an Engineering Design for my Lecture.
              I have been working on that stupid model for 3 days now haha..
              Thanks again.
              Working on it now.. Ill update you if I have succeeded or not πŸ˜„
                benhardwick
                Awesome,
                I am done it guys, thank you very much for your help with this Model. I will be now adding colours and ready for the marking process πŸ˜„
                Thank you once again guys, cannot wait for other projects. πŸ€“
                • pbacotP Offline
                  If you are adding textures, it may save time to use the soften /smooth window. Turn those many joints with low angle to a smooth surface-all of which is textured at one operation. And it makes the model look more natural. (see the example in elisei's picture if you haven't figured this out already. Switch "hidden geometry" in view to see those edges again (they don't go away--it's all an illusion). You can also "Hide" the edges down the middle..under the edit menu.
                    benhardwick
                    Great Thank you for the Advice.
                    Regards
                      jpalm32
                      You might find this interesting. Never used it but woner if it imports clean files that may solve some problems.
                      Here is free software for ship design that as Export to various 2D/3D file formats (.STL, .DXF, .OBJ, .GHS etc.)
                      http://www.delftship.net/delftship/index.php/delftship-free
                        John,
                        I was thinking about the same thing. It is a much better tool for designing boat hulls. I've used it a few times and it would be my choice over SketchUp for its intended purpose.
