    Highlight or zoom-in small parts (like IKEA does...)
    layout
    17 Posts 7 Posters 2.6k Views 7 Watching
      So create scenes in SU that show the details. Then create viewports for them in LO. You can draw a circle or other shape in LO and create a clipping mask with it to create a circular "window" on the viewport. I'll make an example for you.
        How about something like this?
        When I make these sorts of insets I draw the shape (circle in this case) and place it over the viewport as needed. There's no fill, just the edge. Select both the shape and the viewport, right click and choose Create Clipping Mask. Then select the clipped viewport and, in Shape Style, enable Stroke and make the desired settings for weight, color dashes, etc.
          masroor
          Awesome! This is what I was exactly looking for... In fact I noticed the 'view port' thing in the Tips, but tried to repeat/replay the tip later with no luck.
          • Chris FullmerC
            That's a nice detail there Dave!
              Thankee, sir. πŸ˜‰
              • P
                pedrinalex
                That's look so good, thanks Dave
                MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                • bmikeB
                  bmike
                  Dave, as usual, is on the case and makes a great example.
                  Never used the clipping option in LayOut, opens up possibilities.
                  I tend to do things like this:
                    Thanks, Mike,
                    Your example looks much nicer than mine. I did just make that example to answer the question, of course, but your is excellent. So are you just making sized viewports with borders?
                    • bmikeB
                      bmike
                      @dave r said:
                      Thanks, Mike,
                      Thanks Dave.
                      Yes, just viewports with borders.
                      I'll have to try out the viewport and clipping technique sometime.
                      Here are a few more:
                        I like the squares and it is less work. Of course with the clipping mask you can make it whatever shape you like.
                        • P
                          pedrinalex
                          Bmike.
                          Your work is very good.
                          Thanks for the explanation
                          Pedro
                          • bmikeB
                            bmike
                            @pedrinalex said:
                            Bmike.
                            Pedro
                            thank you.
                            note that i often have more than 1 model referenced into my LO file...
                            • C
                              Calstock
                              I've been looking how to do these circular view ports and found this reply. Thanks - it woks perfectly !
                              [attachment=0:rtc98blv]<!-- ia0 -->Inset_1_1.jpg<!-- ia0 -->[/attachment:rtc98blv]
                              When I make these sorts of insets I draw the shape (circle in this case) and place it over the viewport as needed. There's no fill, just the edge. Then I copy the shape before selecting both the shape and the viewport, right clicking and choosing Create Clipping Mask. Then I hit Edit>Paste (Ctrl+V) to paste the circle over the clipping mask. Finally, I select all of it and group it.
                              • C
                                Charlie__V
                                Shure would be nice if a clipping mask could have a "stroke" option.
                                Perhaps I missed that.
                                C
                                  • C
                                    Charlie__V
                                    DOH!
                                    Thanks Dave.....silly me....I was still doing the copy/paste in place method just the other day. 😳
                                    Charlie
