    Highlight or zoom-in small parts (like IKEA does...)
    layout
    17 Posts 7 Posters 2.5k Views 7 Watching
      masroor
      I'm pondering for options to highlight some of the smaller / fine parts of TV Stand woodwork project. Something similar to what IKEA does in their Assembly Instructions.
      Ideally would like to put a layer of thought circle with the small part highlighed.
        So create scenes in SU that show the details. Then create viewports for them in LO. You can draw a circle or other shape in LO and create a clipping mask with it to create a circular "window" on the viewport. I'll make an example for you.
          How about something like this?
          When I make these sorts of insets I draw the shape (circle in this case) and place it over the viewport as needed. There's no fill, just the edge. Select both the shape and the viewport, right click and choose Create Clipping Mask. Then select the clipped viewport and, in Shape Style, enable Stroke and make the desired settings for weight, color dashes, etc.
            masroor
            Awesome! This is what I was exactly looking for... In fact I noticed the 'view port' thing in the Tips, but tried to repeat/replay the tip later with no luck.
            • Chris FullmerC
              That's a nice detail there Dave!
                Thankee, sir. πŸ˜‰
                • P
                  pedrinalex
                  That's look so good, thanks Dave
                  MB ASUS x99M-WS, Xeon e5 2695 v3, 64 GB RAM 2400, 2x gforce gtx 1060, 1 SSDH 1 tb & 3 HD 1 TB c/u
                  • bmikeB
                    bmike
                    Dave, as usual, is on the case and makes a great example.
                    Never used the clipping option in LayOut, opens up possibilities.
                    I tend to do things like this:
                      Thanks, Mike,
                      Your example looks much nicer than mine. I did just make that example to answer the question, of course, but your is excellent. So are you just making sized viewports with borders?
                      • bmikeB
                        bmike
                        @dave r said:
                        Thanks, Mike,
                        Thanks Dave.
                        Yes, just viewports with borders.
                        I'll have to try out the viewport and clipping technique sometime.
                        Here are a few more:
                          I like the squares and it is less work. Of course with the clipping mask you can make it whatever shape you like.
                          • P
                            pedrinalex
                            Bmike.
                            Your work is very good.
                            Thanks for the explanation
                            Pedro
                            • bmikeB
                              bmike
                              @pedrinalex said:
                              Bmike.
                              Pedro
                              thank you.
                              note that i often have more than 1 model referenced into my LO file...
                              • C
                                Calstock
                                I've been looking how to do these circular view ports and found this reply. Thanks - it woks perfectly !
                                [attachment=0:rtc98blv]<!-- ia0 -->Inset_1_1.jpg<!-- ia0 -->[/attachment:rtc98blv]
                                When I make these sorts of insets I draw the shape (circle in this case) and place it over the viewport as needed. There's no fill, just the edge. Then I copy the shape before selecting both the shape and the viewport, right clicking and choosing Create Clipping Mask. Then I hit Edit>Paste (Ctrl+V) to paste the circle over the clipping mask. Finally, I select all of it and group it.
                                • C
                                  Charlie__V
                                  Shure would be nice if a clipping mask could have a "stroke" option.
                                  Perhaps I missed that.
                                  C
                                    • C
                                      Charlie__V
                                      DOH!
                                      Thanks Dave.....silly me....I was still doing the copy/paste in place method just the other day. 😳
                                      Charlie
