    [Plugin] SolidSolver
    129 Posts 40 Posters 111.4k Views 40 Watching
    • guanjinG Offline
      guanjin
      Or repair unsuccessful cube to see the animation! !
        Guanjin
        You could have course use a 'make-faces' on the cube's faces beforehand... πŸ˜’
        SolidSolver is intended to fix non-solids that are at least partially right !
        I can't see why the perforated cube fails...
        When I make one that looks like that it 'solidifies' just fine...***
        Please post/attach a SKP containing it, so that I can see better how you've configured it to break SolidSolver...
        ***PS: After some further tests I now suspect that it's something to do with the 'triangular hole'...
        I'm investigating and will post an update asap...
          Here's v2.1 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
          It has some improved hole healing - especially with certain kinds of triangular holes now made more robust.
          Please report any further 'breakages' and if possible supply me with an example SKP so I can see what's up... πŸ˜•
          • guanjinG Offline
            guanjin
            Thank TIG:
            Real-time updates.
            Test no problem, tomorrow I further tests to see if.
            • guanjinG Offline
              guanjin
              Is estimated that the error caused by the triangular hole
                SteveCarney
                Just to say, this plugin saved me hours of tedious work. A true godsend....lovely!
                • john2J Offline
                  john2
                  thanks a lot !! heavy and cool stuff. this surely will make my models neat and clean. and i'll never wreck my head again while using boolean operations πŸ‘ πŸ‘ double thumbsup..thanks!
                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                    MartinK
                    Thanks TIG.
                    I haven't worked with solids much until lately. This will be extremely useful in fixing some of my my poor modeling until I get used used to modeling with "solids" in mind from the start. πŸ‘
                    • gudio83G Offline
                      gudio83
                      Wonderful. One of the best and useful plug-ins
                      • DesertRavenD Offline
                        DesertRaven
                        Hi Tig, I've a model that can not be solved by your plug-in. I don't know how to attach an image to this post. But maybe I can send you the file in question. Can I contact you via email?
                        Raven
                        simplicity is the ultimate sophistication
                          Raven
                          There is a clearly shown 'Attachment' tab below the typing-pane when you post/reply... Attach a SKP onto you post from there. You can attach many file-formats. An image is likely to be relatively useless compared to a SKP. Have you tried thomthom's 'Solid-Inspector'? This tool will 'highlight' the varying issues that prevent 'solidity': but then you have to fix them manually - or with another tool lkie SolidSolver. So... TT's tool might help you identify what makes your object 'insoluble' and thereby a permanent non-solid πŸ˜•
                          Do you understand the basic concept of what makes a 'solid' ?
                          It must be a group or component-instance.
                          It must only contain edges and faces.
                          Every single edge must have exactly two faces.
                          No more and no fewer.
                          Therefore you can't have any edges that have no faces.
                          You can't have any edges that delineate 'holes' or 'flaps' [no matter how small they are], because that leaves an edge with just one face.
                          You can't have any internal partition-faces, because that will means some edges will have three [or more] faces.
                          You can't have two seemingly solid objects touching along an edge [e.g. two cubes sharing an edge], because then that edge has four faces !
                          Obviously... other objects inside an otherwise solid object - like groups - will turn it into a non-solid, even if they themselves are also solids...
                          The rules are relatively simple.
                          If your SKP is 'confidential', and therefore not for public-gaze, then you could send a PM and attach it to that.
                          As you are trying to 'solidify' something it's unlikely to be too large, the limit is 4Mb, but if it is first purge it, then if it's still too large zip it to get it size down...
                            DesertRaven
                            @tig said:
                            Raven
                            I do think so ....
                            unfortunately the limit for attaching a file in the PM option is 2MB my file is 4 MB.
                            "Do you understand the basic concept of what makes a 'solid' ?"
                            I do think so ....
                            Cheers
                            Raven
                              The attachment limit should be 4Mb πŸ˜•
                              But a ~2Mb file seems enormous for a single solid object anyway πŸ˜•
                              A zipped file will be considerably smaller than the original.
                              A single manifold [or at least hoped to be so] solid object that is ~4Mb would be extremely complex πŸ˜•
                              A single object that is manifold is unlikely to be anything like that size !
                              I am perplexed...
                              Have you purged it ?
                              Assuming that it's as 'trim' as you can get it... can you post a single image of it so that we might envisage its complexity from that, before we go any farther down this path...
                              Why PM it?
                              Posting it for all to see is likely to get a broader response...
                              πŸ˜•
                                DesertRaven
                                I am perplexed...
                                Why PM it?
                                πŸ˜•
                                I purged and cleaned the file to the bare bones. 1 material; 1 group; 1 layer; 1 style;
                                what I can do is to isolate the area that is causing the trouble and reduce the geometry.
                                I did 3D print the object in question, and yes, it is very complex (organic shape), clean geometry save for one little area that SU just won't let me fix. Actually it's even more bizarre that Sketchup keeps fixing the problematic area to the worse.
                                I was able to manually fix the area so that I was able to get it 3D printed.
                                Meanwhile I tested your plug in and it does in fact cut off loads of time on less complex buildings.
                                I also want to say at this occasion, that the "Solid inspector tool" and now the "Solid Solver" plug in are one of the best and most useful tools ever produced by the SU community.
                                Thank you so much for all your effort and in believing in making SU a powerful tool.
                                  Here's v2.2 http://sketchucation.com/forums/viewtopic.php?p=359994#p359994
                                  'Coincident faces' are now resolved better.
                                  These sometimes occur when after intensive editing of surfaces, you end up with a set of edges that have two [or more] exactly coincident faces [parallel normals, same area and same set of outer_loop.vertices], but only one of the faces can exist if the object is to be seen as a manifold solid, because those edges will be seen as having three or more faces, rather than the requisite two...
                                  All but one of the problem faces is now erased...
                                  • cottyC Offline
                                    cotty
                                    Hi TIG,
                                    I've created the attached group which I couldn't make solid with the plugin, perhaps you find it useful for further investigations?
                                    solidproblem.skp
                                    my SketchUp gallery
                                      Thomthom's "Solid Inspector" reveals a myriad of issues.
                                      There are internal partition faces almost everywhere you could have one.
                                      SolidSolver has to make a guess at where to start chipping away at the problem, if it removes one wrong face then it unravels like a knitted jumper...
                                      What you've ended up with IS a Solid from what's left...Capture.PNGJust removing several of the internal partition-faces manually gave a better result [cut a section and use the erase tool...] when SolidSolver ran - it's now a Solid.Capture1.PNG
                                      solidproblem-1[TIG].skp
                                      • cottyC Offline
                                        cotty
                                        Thank you for this very helpful tip (and the solid model)!
                                        my SketchUp gallery
                                          bjaslagter
                                          Very, very usefull, thanks!
                                          • Z Offline
                                            zerobmeister
                                            Hi there, if I use Solidsolver ona group and it says that "the selected group is now solid", does this mean it is watertight or manifold for the purposes of 3d printing? or is there another more reliable way to find this out before sending it to a 3d printing company?
                                            • 3 / 7
