    [Plugin] Material_Maintenance v2.2 - 2013-01-13
    155 Posts 19 Posters 55.0k Views 19 Watching
      Myhand
      I only got time to work on this again this weekend. Implemented all thomthom's tips, thanks again thomthom! πŸ‘
      Only one I did not do is 5
      @thomthom said:
      1. Model.start_operation will be much faster if you set the optional disable_ui flag to true.
      As the docs says the flag defaults to false anyway.
      I also did the following extra bits:
      1. Changed the main hash keys to symbols instead of strings - Again to avoid String comparisons. I ran a few tests and this actually makes a big difference for large strings, but in practice probably not so much here as the material names are usually not so long
      2. Now shipping as a .rbz file for easier installing
      3. Various other small performance and code complexity enhancements
      Works OK on a model of mine that has around 500k entities.
      Has anyone tried the previous version out yet?
      http://www.keepingmyhandin.com/
        Yes? The argument defaults to false - so the UI isn't disabled and you won't get the performance gain. The argument need to be true in order to get a performance gain.
        I wonder if I have misunderstood something here - or maybe you misunderstood me?
          Myhand
          Thanks thomtthom. It is me being an idiot! 😳
          Yes, you are of course right. I got the logic inverted. Changes made and the updated version has been uploaded.
            Myhand
            @thomthom said:
            I've had to set myself into C in order to make C extensions - so I get to use my curly brackets.
            Curly braces is what I miss most in Ruby πŸ˜„. And of course a good IDE would have been nice... I am generally surprised with the lack of tools and libraries. e.g. no JSON support was a unfortunate surprise, and would have made the GUI much easier.
            For this add-in I have written a simple protocol, which supports strings and arrays, but no complex objects or matrixes. Was going to show a tree of the model, but need to pass more complex data structures then, and JSON would have been perfect.
            Does the C API give you better access to the model? I would love to be able to change the layer materials (transparency and colour) as this currently requires manual setup in my plugin.
              I've got a bridge in development in my TT_Lib2 library: http://www.thomthom.net/software/sketchup/tt_lib2/doc/
              A JSON sub-class of a Hash and a bridge where I can call JS functions just with their name from Ruby and it will convert many types of objects to JS object and the return value of the JS function will be converted back into Ruby objects. Got most of the basic data types working and some of SU's custom classes, such as Vector3d and Point3d.
              https://bitbucket.org/thomthom/tt-library-2/
              Parallel to that there's a WebDialog bridge developed in SketchUp's Developer Tools they released as Open Source at last Basecamp: https://github.com/SketchUp/sketchup-developer-tools
              You could have a look at either repos if it could help you.
              It would have been interesting to create a standalone bridge as an open source project, avoiding each developer to create their own version.
              • cmdC Offline
                cmd
                When I launch the plugin, the materials list area is empty and when I select "Re-Load Materials", I receive the following error:
                "Error: #<NoMethodError: undefined method `refreshMaterials' for #MH_KeepingMyHandIn::MaterialMaintenance:0x24571cb8>>"
                You can see the attached screenshot
                Thoughts?
                CMD
                • CMD
                  @cmd
                  Do you have a Selection made before this Tool is launched ?
                  It's not obvious from your screenshot.
                  You have its 'Materials' option set to 'Select from List' and its 'Scope' option set to list for 'Selection Only'...
                  This might then invoke an untrapped error ?
                  This obviously shouldn't happen... BUT it might explain things...
                  Try using it with a selection and/or some different option settings...
                    Myhand
                    CMD
                    Hi CMD,
                    I see you are running on a MAC which unfortunately I cannot test against. It appears not to be able to find the refreshMaterials method, which is definitely there and working on windows. Only thing I can think of is that either:
                    • ruby behaves differently on a MAC (I am not a Ruby expert so might well not have the method syntax exactly right when you add modules etc, and maybe the MAC implementation is stricter that the windows)
                    • or JavaScript behaves marshals the string containing the method name differently.
                    Few questions:
                    • Do you have a windows machine you can test this on?
                    • Is this happening with all models? I suspect it is as not finding the method should not be model dependent.
                    • have you tried remove the plugin manually (all files) and reinstalling
                      Myhand
                      @tig said:
                      @cmd
                      Good thought TIG, but from what I can see this should not cause the problem. I have specifically tested for no selection, and the error is also not a null pointer error. I think it has to do with it running on a MAC...
                        hm... the error is a missing refreshMaterial method - how can that be OSX specific?
                          Myhand
                          I pass the method name in from javascript... the method certainly is there, and this code works on Windows... So somehow it does not resolve in this case.
                          So as far as I can see: either the method name coming in from JS (I assume the webdialog run in Safari on OSX) is somehow corrupted - how I do not know or I am not using the robust RUBY syntax in defining the method, and Ruby on OSX cannot find it.
                          For instance should I pre-pend it with "self". I do not know and cannot debug as I do not have OSX.
                          Has anyone else had this problem in windows, or got it working in OSX?
                            Myhand
                            cmd, I have done some experiments and suspect you may have a corrupt installation.
                            You can either:
                            • fully delete the plugin. The whole ..\Plugins\Material_Maintenance folder. And the reinstall and see if you still get the problem
                            • open your ..\Plugins\Material_Maintenance\Material_Maintenance.rb file in a text editor and see if on line 150 you have the following method definition:
                              def refreshMaterials(selectionOnly, wholeModel, components)
                            • send me the ..\Plugins\Material_Maintenance\Material_Maintenance.rb file
                            • cmdC Offline
                              cmd
                              I have looked into the file and I have found the required "refreshMaterials" definition.
                              Regardless, I will test it out on my windows system through parallels and let you know what I find.
                              CMD
                              • CMD
                                Myhand
                                CMD
                                Thanks CMD, that will be very useful. I hate not being able to debug it myself!
                                  Myhand
                                  Thank you thomthom, very impressive library! πŸ‘ A shame I did not know about it before I started.
                                  Unfortunately I already developed a basic bridge so changing it now would be more work than just adding a JSON marshal class. I wrote a basic one in ruby (so probably not the most efficient but works fine for the size of objects I want to pass). Does all objects, and escapes special characters etc. and does the trick for now. I will publish the code a bit later if anyone is interested. As all of my complex objects go from ruby to JS I have not written a parser (yet).
                                  You have some experience with the C++ API. Does that give access to more attributes than the Ruby API. Specifically I want to change the material assigned to layers.
                                    The C++ SDK for for reading and writing files. It's not something you can use from within SketchUp - manipulate the active model.
                                    But if your goal it to generate a SKP file, then it might be the thing for you. However, I've not used it.
                                    Regarding the Bridge - we talked about this at Basecamp (2012). I think the topic has potential for an Open Source project. We're currently testing out the experience of open source group projects with the STL Importer/Exporter and the Development Tools that SketchUp released. I'd like to see a bridge project established - and even more projects - so we can avoid redoing the work which the next man already have done.
                                      Myhand
                                      For anyone interested here is a link to the JSON formatter class I created. I am now using this for the next version of this plugin, which will allow you to pick a component and find its parent hierarchy. i.e. components containing nested instances of the specified component.
                                      http://www.keepingmyhandin.com/Downhome/Sketchup/simplejsonserializerrubyimplementation
                                      • cmdC Offline
                                        cmd
                                        Myhand,
                                        I installed the script on my windows version and all worked fine.
                                        I also removed and reinstalled it on my Mac but I am getting the same error on launch of the script 😞
                                        Error: #<NoMethodError: undefined method `refreshMaterials' for #<MH_KeepingMyHandIn::MaterialMaintenance:0x15306b40>>
                                        CMD
                                        • CMD
                                          Myhand
                                          @cmd said:
                                          Myhand,
                                          CMD
                                          Thanks CMD, sounds like my hunch might have been right and that it is something to do with the MAC.
                                          Can anyone that has used the script on a MAC (successfully or otherwise) please let me know?
                                          Else we might have to do this the hard way... CMD, if I add some debug code to the script would you mind running it and sending me the output?
                                          Cheers,
                                          myhand
                                            rv1974
                                            Myhand, let me shake your hand!
                                            this is a real helper (especially for those who render outside SU and care about mats order).
                                            Thank you!
                                            • 2 / 8
