    [Plugin] Slicer5
    338 Posts 83 Posters 394.1k Views 82 Watching
    • OxerO
      Oxer
      Hi TIG,
      I have a similar error like pbeseda:
      @pbeseda said:
      Error; #<TypeError; reference to deleted Face>
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `pushpull'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `fatten'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2041;in `each'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2035;in `each'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;2035;in `fatten'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;1612;in `run'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;793;in `initialize'
      > C;/Program Files (x86)/Google/Google SketchUp 8new/Plugins/TIG-Slicer/TIG-Slicer.rb;657;in `new'
      This is my Console Ruby Error:
      Error
      I work on Mac OSX Mountain Lion 10.8.2 and SU Pro v 8.0.1517
        Here's v5.14 http://sketchucation.com/forums/viewtopic.php?p=374969#p374969
        It adds a submenu item to activate/deactivate its toolbar without having to search through the View>Toolbars list...
        It also traps errors that can occur with the Outline option etc where tiny edges can fail to form properly [size related issue].
        Now if they do fail then the tool continues, so now the outline might have a few tiny bits missing, but the tool doesn't 'crash-out'.
        Oxer: I hope this addresses your issue.
        If not, then try Scaling everything up x10 or x100, doing the 'slotting' [making due allowance for the size changes], then Scaling back down to the original size.
        The small geometry can exists, it just has problems in its creation.
        By now we should all be aware of the tiny edge/facet creation issues, which prevent some native-tools and also some scripted equivalents from successfully making very small geometry...
          Clever, I'd never had thought of such cool feature πŸ˜‰
          • OxerO
            Oxer
            Thanks TIG, I'm going to test the version v5.14.
            EDIT: The same error message in the Console Ruby with v5.14
            • jim smithJ
              jim smith
              thanks for the update!
              "Out of clutter find simplicity,
              from discord find harmony,
              In the middle of difficulty lies opportunity"
              Albert Einstein
                Can you post the SKP or PM it if you like... with details about what you are trying to do [settings etc]...
                Have you noted the issues about smallness?
                It can also apply to largeness too...
                SketchUp/OpenGL can't cope with very tiny or very gigantic geometry and some edges/facets can fail to form... Also have the objects miles from the origin can also cause issues.
                Obviously I'd prefer that my tools don't 'fail', but sometimes it's the nature of SketchUp and not my code.
                If I can see the issue first hand I can perhaps see if I can trap for such errors better, or at least advise on the best way to model to avoid the issue...
                • OxerO
                  Oxer
                  It's a very simple geometry, a cube and you can see the settings in the image below:
                  Perhaps there is a conflict with another plugin, i'm going to uninstall other plugins.
                    The following are the usual suspects [messing with base-class/methods ill-advisedly etc]...
                    SketchyPhysics [current version]
                    Podium [some earlier version]
                    SunPosition [all versions]
                    Matchbox [all versions]
                    • OxerO
                      Oxer
                      I have uninstalled all plugins except Slicer.rb and the problem persists, don't worry TIG, i'll use SliceModeler.rb
                        @oxer said:
                        I have uninstalled all plugins except Slicer.rb and the problem persists, don't worry TIG, I'll use SliceModeler.rb
                        That's not the point!
                        Are you using Slicer5 or Slicer - I am confused ?
                        Can you please PM a copy of the SKP that has the problem, and the settings you are trying to use...
                        This ought to work without issues ??
                        • N
                          nmballa
                          New Sketch Up user. Having difficulty installing on apple OS X running free Sketch Up 8. Do you have instructions posted anywhere on the steps.
                          • N
                            nmballa
                            So my aim is to use this tool to create corrugated cardboard furniture. The pieces will be cut and glued together. Should the spacing be set to the same as the thickness. Will this slice the pieces so that they lay face to face.
                            Also, when slicing it is prompting me if I would like to "Add the Outlines of Adjacent Slices ?" What does this mean?
                            • N
                              nmballa
                              Any idea why I am loosing slices? Seems to be doing some odd stuff and loosing data. See the attached photos.
                              Screen Shot 2012-11-23 at 1.36.01 AM.pngScreen Shot 2012-11-23 at 1.35.15 AM.pngScreen Shot 2012-11-23 at 1.34.53 AM.png
                              • OxerO
                                Oxer
                                I have used Slicer always but like the last version don't work for me i use SlicerModeller v1.3 now.
                                SKP file and settings that i'm using:
                                SU file and settings.zip
                                Remember I work on Mac.
                                • OxerO
                                  Oxer
                                  Excuse me, excuse me, excuse me TIG!!!! 😳 😳 😳
                                  The problem were that I haven't installed the font txt_____.ttf
                                  this happens to me for not having read the first post entirely.
                                  Excuse me again TIG.
                                    @nmballa said:
                                    Any idea why I am loosing slices? Seems to be doing some odd stuff and loosing data. See the attached photos...
                                    If you look where the slices are failing to form it where you have a curved corner. I suspect that you have made a very segmented arc in the extrusion, although even 12 segments at that small size means that the facets forming the curve are very narrow.
                                    As explained in other posts SketchUp open GL has problems working with very tiny edges or facets, as their end points converge in tolerances and are considered equal and therefore no faces form.
                                    This limitation extends from the native-tools into their API Ruby based equivalents.
                                    Slicer uses 'Intersect'. It iterates across 3d space and loops of edges are obtained by intersecting a temporary 'disc' with your selected object at each step. This loop should then form faces which are extruded using PushPull to the desired thickness [other convoluted operations are used to add slots when slicing in two directions, add outlines of one slice on the adjacent slice if they are touching etc, are done as your settings].
                                    IF the slice's loops of edges are incomplete then there is no face available to PushPull, so the slice is either 'empty' or perhaps only partially formed. The missing tiny pieces of the loop are a result of SketchUp's limitations when cutting through the tiny facets on your rounded corners, the Intersection fails to form the tiny lengths of edges and the face can't form.
                                    If you must include these tight rounded-corners then try fewer segments in them.
                                    Alternatively scale your whole model up, slice [using suitably adjusted settings] then scale down.
                                    A simple 'trick' if you are working in 'cm' is to draw a line 100cm long in the model, then set your Model Info > Units to 'meters', without a units prefix and 0.0 accuracy etc.
                                    Use the Tapemeasure tool to pick the start/end points of the 1m line, the VCB says 1.0, you type in 100 + <enter> and answer Yes to rescale the whole model.
                                    Now do your Slicing, set the values in the dialogs as if they were 'cm' [they are actually in meters but as there are no units shown, who cares?]
                                    The slices form and because the object's facets that are getting sliced are now 100 times larger there should now be no issues with missing faces etc.
                                    When you are done slicing, and before exporting etc, change your Model Info > Units back to 'cm' and repeat the Tapemeasure trick, this time the VCB says 10000, type in 100.
                                    the model scales down back to its original size. Tiny edges/facets can survive, it's just their creation that has difficulties... Now when you export the slices' sizes should be as expected and they should all have been perfectly made...
                                      πŸ˜’ OK, I never thought of that omission !
                                      On a PC if you don't have that TXT ttf font then the last used font is automatically used by 3dtext anyway, but on a MAC it just crashes out unexpectedly. The TXT 'stick' font is the best for CNC engraving of the slices references [important on complex slicing to keep track of the pieces], because this font is as near to a single stroke in 3dText as we can get.
                                      TXT is one of the oldest AutoCAD fonts, made for use in really old pen-plotters - this is the TTF version of their even older SHX shape font [because SUp needs TTF for its 3dText]...
                                      Anyway... I hope it's now working OK for you... πŸ˜„
                                      • N
                                        nmballa
                                        Hmmm... Having issues with defining the value of the segments in the arc. You are correct, it is defaulted to 12. Not sure how to change it. Will try scaling and report back.
                                        • N
                                          nmballa
                                          And now on to my next issue. I am trying to slice this file down to 1/4 inch or even 1/8 inch. Seems its just too much processing and the program locks up. Running processor 1.86 GHz Intel Core 2 Duo, 4 GB of Ram. It only seems to happen in the Y axis. Z is not an issue. Thoughts?
                                            In the Y axis you are slicing down a round edge.
                                            Which has issues...
                                            In the other [Z] direction you are perhaps cutting across them ?
                                            If the screen goes white and says it's 'unresponsive', it does NOT mean it's broken, just that it's taking a lot of brain-power to do its tasks...
                                            Have patience...
                                            If the 'Task Manager' shows SketchUp is still working away then let it try to finish...
                                            Go have your dinner and come back - then cancel it IF it seems stuck.
                                            Often a little patience will let a long running process complete successfully.
                                            • 16
                                            • 17
                                            • 8 / 17
