    [Plugin] bim-tools 0.13.4(june 22, 2015)
    206 Posts 37 Posters 263.6k Views 37 Watching
    • ludnidL
      ludnid
      Splendid Plugin. Works like a charm but for a minor bug so i'll need someone to confirm please. After installing a couple of plugins the day before, sketchup crashed while working within a group and specifically while trying to use the paint bucket tool. Removing the recent installations found bim tools to be the culprit πŸ˜„. Does anyone have the same problem?
      NB: I also noticed the crash happens on my second trial just after ive closed the scripts dialogue.
      If you don't ask, the answer will always be no.
      • brewskyB
        brewsky
        I have finally taken the time to set up a website for the project. πŸ˜„
        Check it out on:
        http://www.bim4sketchup.org/
        It's very basic, but it already contains some documentation.
        I will add more along he way...
        Cheers!
        Jan
        Sketchup BIM-Tools - http://sketchucation.com/forums/viewtopic.php?p=299107
        • I
          ivreich
          Revit Import Error
          Hi Jan
          Thanks for this incredible effort.
          I'm having some problems importing the IFC file into Revit 2013. I've attached the Revit error message and my skp file for you to look at.
          Also, will it be possible to create bim elements with more complex surfaces, e.g. quad-based surfaces generated from curviloft, EEby, soap skin bubble etc?
          Cheers
          Joel
          Revit error message
          SU file
          • brewskyB
            brewsky
            I will look into it, it should never interfere with your day-to-day SketchUp-ing!
            It probably has something to do with the observers the plugin uses.
            The first thing I want to do is make a on/off button that disables the observers(or even the entire plugin if possible). That should make sure there occur any problems when not using the plugin itself.
            Does anyone have tips on implementing this? I think it would be nice if I could minimize the toolbar to a single button to show that the plugin is not active...
            • brewskyB
              brewsky
              Hi Joel!
              Thanks for sharing this model!
              It points me to some "internationalization" bugs I wasn't yet aware of(mixing up commas and dots in numbers and the like).
              Is it possible to get a more detailed report from the revit ifc-importer?
              I can't make out the id's it reports in the screenshot.
              I still have a lot of ideas to improve the plugin. πŸ˜„
              The greatest challenge will be to translate things like complex surfaces to a usable/editable object in revit through IFC.
              Cheers!
              Jan
              • H
                hygicell
                when starting sketchup after installing BIM tools I get an error:
                Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb
                undefined local variable or method `ο»Ώ' for main:Object
                please help
                Frank
                • brewskyB
                  brewsky
                  Error Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb undefined local variable or method `ο»Ώ' for main:Object
                  Too bad that I can't reproduce the error, and I don't really understand it either.
                  It seems that it tries to load an unnamed method for the main ruby object. πŸ˜•
                  Is there anyone who can give me any tips on troubleshooting this?
                  I learned a thing or two about better usage of "modules".
                  I'm currently implementing this, I hope it will fix this error too.
                    Do a find in your .rb files' code for a loose `
                    Perhaps someone open the .rb in a wordprocessor and added formating to the text πŸ˜•
                    • brewskyB
                      brewsky
                      While searching for a loose ` with grep, grep showed some strange characters before the first character of the script in the file mentioned in the error. I checked the formatting, and this file seems to be the only one encoded in UTF-8 with BOM(some microsoft addition to UTF-8: "Byte Order Mark"), while the others are without BOM. Could this explain the error?
                      I have not yet found a loose `, but I will also check the rest of the files.
                      I found that the "normal" ruby error is something like "NameError: undefined local variable or method `a' for #", where it uses two different markers surrounding the method/variable name. Only in the case of my plugin there is nothing between the markers...
                      • brewskyB
                        brewsky
                        Hi Frank!
                        Can you give this version a try?
                        I removed the offending file πŸ˜„, see if it helps...
                        bim-tools-0.12.1.zip
                        Cheers!
                        Jan
                        • Dan RathbunD
                          Dan Rathbun
                          @brewsky said:
                          YES. For maximum cross-platform compatibility set Notepad++ defaults for .rb files to "UTF8 without BOM (ANSI as UTF8)" with UNIX end of line chars.
                          I'm not here much anymore.
                          • brewskyB
                            brewsky
                            Thanks Dan!
                              Why UNIX EOL?
                              • Dan RathbunD
                                Dan Rathbun
                                @thomthom said:
                                @dan rathbun said:
                                YES. For maximum cross-platform compatibility ... with UNIX end of line chars.
                                Why UNIX EOL?
                                Well do you really want to have to distribute your plugins in two editions, one with Mac EOLs and one with DOS/Windows EOLs ?
                                Remember that Ruby was developed on Unix-like systems, and loves UNIX EOLs. MS Windows hates files with Mac EOLs. The Mac OSX descends from BSD Linux, so has no problem with UNIX EOLs, and I'm not sure about DOS/Windows EOLS.
                                It makes sense to set your code editor's default EOL to something that both platforms can read without problems.
                                  I have written all my plugins with Windows EOL (CR+LF) and I've never had any problems using them on OSX due to EOL.
                                  • brewskyB
                                    brewsky
                                    EOL and BOM seem as different things, other than they are probably both part of the used UTF format(microsoft or Unix).
                                    Is that correct?
                                      Is that correct?
                                      EOL is just End Of Line characters - used in any encoding. But there are different mutations.
                                      BOM is a Unicode feature indicating the endianness of the current Unicode encoding.
                                      • H
                                        hygicell
                                        Hi Jan,
                                        somehow I must have forgotten to click on a "follow this post button",
                                        I thought this would go automatically
                                        so it is only now I see your prompt reactions, folks, sorry for that !!
                                        and thanks to all
                                        first I tried installing the new version using Thomthom's installer directly over the old one
                                        same error result
                                        next I first deleted the bim tools folder before reinstalling, again with Thomthom's installer
                                        errors eliminated as far as Bim tools is concerned
                                        thanks
                                        Frank
                                        @brewsky said:
                                        Hi Frank!
                                        [attachment=0:1h3u0vc0]<!-- ia0 -->bim-tools-0.12.1.zip<!-- ia0 -->[/attachment:1h3u0vc0]
                                        Cheers!
                                        Jan
                                        • brewskyB
                                          brewsky
                                          Great! Thanks for testing it!
                                          • I
                                            ivreich
                                            @brewsky said:
                                            Or place self-cutting components! http://support.google.com/sketchup/bin/answer.py?hl=en&answer=114533
                                            I've tried many times to create self-cutting components, but it never ever works. Have followed every single step to the letter in the instructions, but components refuse to cut through single surfaces.
                                            Anyone else having this problem? I'm running Sketchup Pro v8.0.14346...
                                            Joel
                                            • 11
                                            • 8 / 11
