    [Plugin] "Drill" extension for making holes
    36 Posts 22 Posters 38.7k Views 22 Watching
    • Z
      zero
      I don't know if i have something broken in my install,but i cant snap a hole on any line,construction line or point.is it normal.
      • B
        bianhai
        Ver good! 👍
        • utilerU
          utiler
          This is great mate, well done!!
          I think though; is it possible to somehow enable SU snapping [end point, midpoint, etc...] and also inference locking?
          Many thanks!!!!
          Just Curious...
          • C
            cyan.archnet
            very interesting plugin, will give it a try, THANKS!
            • K
              k2wengen
              very simple and efficient tool!! good
                m3a4
                sorry to bother the illuminatti with this, but something weird is happening to this plugin (edit: and others)
                Only seems to drill a hole size "1". I'm using a metric setup so the hole shows as 22.x mm, I assume it's defaulting to imperial units..?
                When ever I try to change the size, it still reverts and drills the hole size "1"
                more;.. oops.. just tried another plugin that had an input and that's not allowing a change - or at least taking any notice of what I write in the box.
                XP with v8
                I've broken something! I've tried the repair from install, if that doesn't work, I'll rip it all out and reinstall? but curious if this has been seen before and what caused it.
                Many thanks
                  m3a4
                  oh, as I have to "drill" about 1500 holes, THANK YOU for the plugin! 😄
                    Dadio61
                    Thanks for the plug-in. It works at drilling a hole in my panel, but the diameter doesn't adjust, even though I'm entering a number in the vcd.
                    I looked at the sript in notepad and see the diameter number. So why isn't the diameter changing? Any suggestions?
                    Regards, Les
                      Les, are you hitting Enter after typing the new dimension value? it works for me.
                      This plugin doesn't seem to utilize inferencing which makes it difficult to accurately place holes. I'd find this a really useful tool if it did.
                        Dadio61
                        Dave R,
                        Thanks for the suggestion on using the enter key. It works fine now.
                        I noticed that the unit of measure came up in the vcd also. In my case it is in millimeters.
                        tried several different hole sizes, from five millimeter to twenty millimeter, and all worked. This will work good enough for a model representation.
                        Thanks for your help.
                          RiseUp
                          I've edited the plugin to include snapping/inferencing. That was the deal breaker for me—without snapping, this plugin was not useful to me. But with it, I will be using this all the time!
                          Thank you to lunkwill (the original author) and TIG (another tweaker) for all their work!
                          Hope you find this as useful as I did.
                          Updated to include snapping/inferencing.
                          • P
                            Pants
                            Does this really work for others?
                            I just installed the latest-gen plugin, and for me, it's got a drawback that makes it unusable: the diameter of the hole can't be changed. My various entries of different diameters do show up in the text-box, but I've been machine-gunning test-holes for a few minutes, and nothing about the diameter changes from one to the next, whether I've got "0.1" in the box or "11": all measure out at 0.875" (7/8"), which is the default hole-size.
                            • G
                              glro
                              for me it is unstable
                              sometimes it works
                              most f the times it doesn't...
                                You must press <enter> after typing the new size?
                                Also that size is currently always defaulting to decimal inches.
                                BUT if you edit the file at:
                                @@drill_diameter = 0.875
                                to read
                                @@drill_diameter = 0.875**.inch*****
                                then it'll work with any units you have setup or you input, taking unsuffixed values as 'current units' or those with suffixes alternatively: so if you are working in inches but want one hole at exactly 1cm type that +<enter>...
                                ***If you normally work in say 'mm' change it to default to say '10mm' initially, if your model-units are mm then typing 12 + <enter> will make a 12mm hole...
                                I.E. @@drill_diameter = 10.mm
                                • G
                                  glro
                                  to read
                                  yes, it works now
                                  i usually use meter as default unit
                                  I changed "@@drill_diametre = 1" into " @@drill_diametre = 1.m" in the plugin, and typed "enter" after changing the diameter
                                  thank you
                                    I'm curious about why hitting the Enter key seems to be a problem with this plugin when Enter is so frequently used with the native tools and there are many other plugins that have the same requirement. The fellow who posted immediately above the post with the most recent revision had the same problem which was solved by hitting Enter.
                                    • G
                                      glro
                                      @dave r said:
                                      I'm curious about why hitting the Enter key seems to be a problem with this plugin when Enter is so frequently used with the default tools and there are many other plugins that have the same requirement. The fellow who posted immediately above the post with the most recent revision had the same problem which was solved by hitting Enter.
                                      which default tools?
                                      the VCB, Ruby console, ...?
                                      most plugins input are made through a dialog box, and in this case, it is obvious: you click "OK" on the button
                                      With the VCB, there is no button... you are just supposed to know it is necessary to hit "enter"
                                        Exactly. The native tools use the VCB and you have to hit Enter to make the setting. There are a lot of plugins which take their inputs via the VCB, Bezier.rb, BZ_Spline, Curvemaker, etc.
                                        • P
                                          Pants
                                          Yes, my mistake in not reading previous comments carefully - but as I think Glro indicates, in Sketchup, I have learned to resist what's usually the mistake of using an <enter> in the VCB, after getting used to all /other/ VCB uses (at least for me, thus far) virtually punishing me for what, in SU, is usually the MISTAKE of hitting <enter>. Yes, the <enter> requirement is typical of /other/ CAD software - and pretty much everywhere else in the world of data "entry," where nothing is "entered" until one hits "enter" - but I personally haven't used other plugins where this is the norm.
                                          Reading sloppily through the above exchanges, I'd taken the mention of using <enter> as "you did't make the mistake of using "enter," did you?" and then somehow completely missed the response - and that was before I'd installed the plugin a few hours later, by which time I'd forgotten all of that anyway.
                                          • BoxB
                                            I'm not sure I understand how you can use SU and see hitting enter as a mistake. Enter is the norm.
                                            Draw a circle, type 29s enter and it is a 29 sided circle, draw a line and type 357mm enter and it is a line 357mm long, ctrl move type 5x enter etc etc etc
